Darker area in all (very)underexposed pictures
Started Aug 18, 2020 | Questions
Stefano A New Member • Posts: 6
Hi,
I'm trying to make some astrophotography with my nx300 but when the shutter speed is
very low (5 s and above), in every underexposed picture I see a darker area on the left of the images.
The lens is not the cause (I made pictures without lens and the result is the same).
I would like your opinion about this problem.
Thank you.
Stars (Shutter speed 8s , iso 25600, f/4.5  ,35mm,  15 stacked images)
Samsung NX300M
kypfer Contributing Member • Posts: 985
Re: Darker area in all (very)underexposed pictures
Are you incorporating "darks" and "flats" and whatever which are designed to help compensate for sensor anomalies?
Assuming of course there's not a clump of fluff floating around in front of the sensor
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
OP Stefano A New Member • Posts: 6
I used dark frames and the light frames(the images).
I noted that the darker area appears in dark frames with a combination of a high ISO and high shutter times. For example for 30s of exposure the darker area is visible for ISO over 1600. Per 1s exposure the problem is not present. The irony is that in the darker zone seems that there's less noise.
1 dark frame, shutter time 30s, ISO 3200, (Sligtly increased brightness with GIMP)
One might almost imply that there's an area of reduced sensitivity within the sensor, but I know just enough about sensors to recognise that as a very unlikely situation
It'd be interesting to see the results from another camera of the same model. I wouldn't expect the fault to be in the same place, but there might be an indication of a wider-spread issue.
Hopefully someone else with an NX300 will read this and make a hi-ISO 30sec exposure with the lens cap on for comparison.
Good luck.
Indeed It would be interesting to see another nx300, 30 s , high ISO "black" photo.
Your Samsung camera at 25600 ISO, 30s, have a uniform noise pattern in a black photo?
My NX5 only goes to 3200 ISO, but it is uniformly noisy at that setting with a 30sec exposure.
NX5 - 3200ISO @ 30sec (with lens cap on) - result enhanced to emphasise background noise.
Isola Verde
Isola Verde Forum Pro • Posts: 10,630
If of any help, these are from a JPG taken just now with my NX300 - one simply resized, the other after some overall exposure uplift in LR.... high ISO, 30 secs exposure, 30mm lens at smallest aperture in "A" mode, with the lens cap on and manual focus, and very probably with long exposure NR applied by the camera.
Hope it's what you wanted!
I'm sure I've stood on a carpet much like this!
Some slight differences perhaps, but - to me - the exposure looks fairly even across the frame?
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
Isola Verde
I'd forgotten what a nice little camera that is!
For me, the lens range just needed a lightweight, modestly good OIS telezoom, of around 40-100mm (equiv to, say, 60-150) and f/3.5-5.6, to accompany the kit PZ and pancakes - and I'd probably not have gone over to M43.
Shame....
Peter
Thank you. Now It's clear that mine is defective
Thank you. Clearly your camera have noise uniform whereas mine is defective.
