12,800 ISO on X-T100 — what is this sorcery?
Started Aug 16, 2020 | Photos
KneeConWon Contributing Member • Posts: 810
9
Taken with a Fuji X-T100 and Fuji 15-45mm kit lens at 12,800 ISO and 1/7 second handheld during dusk.
Image was taken in JPG with noise reduction and sharpening each set to minus 2 (the lowest setting on the camera). The only edit made in post was raising the brightness slightly (which obviously only increases noise).
I can't see any color noise, and I can only see "grain" if I zoom in to 100%. And the image appears sharp and vibrant at any normal viewing sizes.
How the heck is Fuji doing this? I'm pretty dang impressed — not only with the iso performance, but with the in-lens stabilization, and with the X-T100 + 15-45mm lens combination in general. It's so great that I haven't needed any other lenses for the system. It's effectively my perfect everyday fixed-lens compact camera that can take good photos of almost anything. I love its simplicity and versatility.
Follow my street-photo project on Instagram:
https://www.instagram.com/couplesoftraversecity/
 KneeConWon's gear list:KneeConWon's gear list
Sony a7 II Nikon D7500 Fujifilm X-T100
Comment & critique:
JayPhizzt Senior Member • Posts: 2,374
Re: 12,800 ISO on X-T100 — what is this sorcery?
Don't know what screen size you're viewing the photo at, but when viewing it naturally on my 27" screen it's definitely not sharp and pretty noisy.
ragbasti Regular Member • Posts: 321
It pretty darn good but I'd say the out of focus area in the back is what really suffers in this image.
Still, pleasently surprised how well the detail in the leaf and water drops held up.
If you want to experience the Dunning-Kruger effect first hand, then just join a forum debate about photography.
 ragbasti's gear list:ragbasti's gear list
Fujifilm X-T2 Fujifilm X-T5 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +2 more
OP KneeConWon Contributing Member • Posts: 810
Ya, no crap — it's freaking 12,800 ISO!!!
Are you saying it's soft and noisy for 12,800 ISO? That's the point.
To answer your question, I'm viewing on a 13-inch MacBook screen.
Yes, the noise is definitely more apparent in the out-of-focus areas, at least at 100% viewing. Good observation. I had never thought about noise being affected by focus.
I was too. Thanks for the feedback!
Correction to my original post: the photo was taken at 1/8 second — not 1/7 second.
Erik Baumgartner Senior Member • Posts: 6,893
If the quality of light is halfway decent, ISO 12800 is usually very usable with a modern APS-C camera. With a little additional NR and a quick tweak it looks even cleaner. That 15-45 is a good little lens. Not super sharp here, but hey, it's at 1/8". My 16-55 would likely look significantly worse. at 1/8"
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
ikaika777
ikaika777 Senior Member • Posts: 2,632
If you handheld that shot at 1/8 then from henceforth you shall be called, “The Human Tripod”. 👑
After all is said and done and your photo is hanging on the wall, no one is going to know or care what camera, lens, or what post processing you used. All they care about is if the image moves them.
I’m not hung up on the Bokeh fad because I’m too busy chasing shadows.
 ikaika777's gear list:ikaika777's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR +18 more
I didn't realize the quality of light affected the level of noise. Thanks for the insight!
Great edit! The noise is definitely smoother. I never use noise reduction in post for fear of losing detail, but I should give it consideration.
I'm surprised you were able to brighten the photo without blowing out any highlights, as I thought I had already pushed it as far as it would go before such happened. It also appears you adjusted the white balance — I'll admit I got lazy, considering Fuji's excellent auto white balance, and determined the color already looked good without needing to mess with it — either in camera or in post.
Your post has been very illuminating. Thank you!
LOL. Too funny! I'm honored.
It does seem to be harder to handhold cameras during macro shots — I'm not sure why. In any case, I usually try to never go below 1/15 second in any situation with this camera/lens, but there was hardly any light when I took the photo.
In retrospect, it would have been smarter to have taken the shot in M mode at 1/15 second (and still 12,800 ISO) and banked on having to raise the brightness more in post, but I got lucky on this occasion. Or maybe I just should have used an actual tripod!
CAcreeks
CAcreeks Forum Pro • Posts: 18,940
Yes, the X-T100 has amazing image quality for its price.
Also Erik is really good at Lightroom edits.
I'm wondering, since the X-T100 has Bayer sensor and is supported by DxO Photolab with Prime noise reduction, how would this look with Raw conversion using that software?
My question for you: what do you think about the PowerZoom aspect of the XC 15-45? Do you avoid it, does it not bother you, or would you prefer manual zoom? The 15-45 tests out to be one of Fuji's sharpest zoom lenses at 15 to 18mm.
No doubt, and I got it brand new with the lens for $399. B&H had a sale at the beginning of the year. Best purchase ever!
I can see that!
Ya that would be interesting to see. If anyone reading this wants to try that and share it here, have at it!
I would definitely prefer manual zoom, though I appreciate that the power zoom helps keep the lens small and I've gotten used to using it, so I really don't mind it now. And the lens is awesome in just about every other way — IQ, size, weight, versatile focal range of 23-69mm equivalent, macro ability.
The power zoom did get on my nerves at first. Many people call it "fiddly" and I can understand why — if you accidentally graze the focus ring while intentionally turning the power-zoom ring, it won't zoom at all! And unless you have experience using the lens, you may not understand why it's not working in that moment, which is very frustrating, especially if you just missed a shot because of it.
Once you realize how to avoid that issue, the power zoom starts becoming really easy to use, and eventually you don't even think about it. It's a non-issue after a certain amount of experience with the lens.
I would highly recommend the lens. I assumed I would be buying some Fuji primes, but honestly I don't even need them with how good and versatile the 15-45mm is.
CAcreeks
They would need the RAF. I'm not sure you have it (if you were shooting JPEG only). I don't have DxO Photolab because it doesn't run on Linux. I use Darktable, which has several methods for noise reduction, probably not better than what Erik did with Lightroom.
Thanks for your thoughts on this.
If you don't mind manual focus, there are some great bargains in old (cheap!) lenses mounted with adapter.
No, I'd say it looks good for ISO12800. However I do feel like there is a bit of motion blur in the photo as well(it's shot at 1/8s after all), so it could potentially look even better
Noise tends to become more pronounced in out-of-focus areas, yes. It's not affected by the focus per se, it's just that noise tends to become more visible in areas with little detail/texture in them. So it's not just in out-of-focus areas.
In photos with a lot of details in them the noise tends to be less visible.
bowportes Veteran Member • Posts: 4,337
I can see that!
I have my 15-45 set to "zoom by wire" so that it zooms like all the other Fuji zooms, but you use the focus ring for zooming, not the zoom ring. None of the Fuji zooms are actually manual zooms.
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-Pro3 Fujifilm GFX 50S II +15 more
boogisha
boogisha Senior Member • Posts: 2,858
Re: XC 15-45mm the only power zoom ("zoom by wire")
Unless I`m misunderstanding you, it`s quite the opposite - all Fuji zooms are manual zooms (albeit with _focus_ "by wire", being electronically coupled lenses), where you can manually zoom in/out even with lens detached from camera, while XC 15-45mm f/3.5-5.6 OIS PZ is the only "power zoom" (which is what "PZ" stands for), being "zoom by wire" as you called it, and unable to operate when lens is detached.
 boogisha's gear list:boogisha's gear list
Canon PowerShot A75 Canon ELPH 300 HS Canon PowerShot S120 Canon PowerShot G7 X Fujifilm X-E1 +15 more
texasfz8
texasfz8 Regular Member • Posts: 270
The 15-45 can be set up to use the zoom and focus rings as a two speed setup, with the zoom ring for coarse but fast adjustments and the focus ring for fine but slow  zoom adjustments instead of focus. Or you can use the focus ring to focus of course.  I hate power zoom lenses, but with the two speed setup on the 15-45 I am actually learning to tolerate it.  There is definitely no manual zoom, all power zoom.
 texasfz8's gear list:texasfz8's gear list
Fujifilm X-S1 Fujifilm X30 Fujifilm X-E3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm II +2 more
