Nikon 70-200 f/4 for profesional results?
Robert 23 Regular Member • Posts: 120
I have never used any 70-200 2,8 lens just because of their weight.
Having a look at the new Nikon 70-200 2,8 S for the mirrorless line, i realized that even this lens is almost 1,5 kilo. That means we will never probably see a lightweight 70-200 2,8 lens in the future.
So actually the only option for me is the Nikon 70-200 f/4.(i am not interested in any third party lenses)
My question is:
judging just from its optical quality, would you consider the Nikon 70-200 f/4 a professional lens?
Does its quality match the optical quality of the other 70-200 2,8 Nikon lenses?
romfordbluenose Veteran Member • Posts: 4,907
Re: Nikon 70-200 f/4 for profesional results?
7
The 70-300 afp vr is a great lens and not much slower. I prefer it over the f4.
Please don't quote long posts, it just fills up the forum with repetitive information. Just replying to the poster or selectively quoting will make it all easier to read.
 romfordbluenose's gear list:romfordbluenose's gear list
Panasonic Lumix DMC-ZS30 Nikon D800 Nikon D7500 Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR +11 more
David Lal Forum Pro • Posts: 12,160
Yes!
Robert 23 wrote:
My question is:
I have long lusted after the Nik 70-200/F4 [but I still do not have the money ] and it is one of the few zoom lenses I have seen giving acceptable [though not optimal] results with a mild teleconverter.
Personally, I never use any lens wide open so the absence of an F2.8 aperture is no impediment to me and even the F4 I would close down a notch or two.
If you can afford it get it - maybe a lightly-used, dealer-warrantied secondhand one?
Pete Silver
Pete Silver Contributing Member • Posts: 871
I've used the 70-200 f4 lens in my professional work and I'm really pleased with it. Never used the f2.8 version so I can't comment on that.
Pete Silver
 Pete Silver's gear list:Pete Silver's gear list
Nikon D850 Fujifilm X-H1 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.8G Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR +2 more
OP Robert 23 Regular Member • Posts: 120
Does it work properly with your D800? I have a D800e.
Yes it works fine with the necessary firmware upgrade. It's now done 2 safaris plus lots more.
Great! Thanks a lot
Any chance of posting any link with some shots with this combination (D800 +70-300)?
a_c_skinner Veteran Member • Posts: 9,901
It is a very good lens; one of the few I truly regret selling when I left Nikon (D800).
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 80mm F2.8 Macro Fujifilm XF 27mm F2.8 +5 more
PerfectPoms
PerfectPoms Senior Member • Posts: 2,214
The Nikon 70=200 f4 lens is excellent.  Sharp wide open and fast to focus and well built.  It is definitely a 'pro' lens.  Pro build quality.
It is actually sharper than the Nikon 70-200 2.8 VR I
I loved my f4 for the very small size (very thin around), and it is almost exactly half the weight of the 2.8.
I also found it great with the 1.4 x TC.
Sadly, I never used it after getting the newest Nikon 70-200 E FL lens, so I sold it.
Don't hesitate to buy this lens.  You'll love it.
 PerfectPoms's gear list:PerfectPoms's gear list
Nikon AF-S 180-400mm F4E TC1.4 Nikon D750 Nikon D4 Nikon D300 Nikon D2Hs +16 more
Robert 23 wrote:
Great! Thanks a lot
Great shot!!! Thanks a lot...
Tbh I am afraid of a bad copy of this lens..what do you think about?
Terry Reis
Terry Reis Regular Member • Posts: 109
Been using the 70-200 f4 for a few years now. Very happy with it on FX and DX bodies. OK with 1.4 TC.
Keeping myself amused during lockdown shot flowers and birds in my garden. mostly used the 70-200 for the flowers. I also use and highly rate the 70-300mm mentioned earlier in this thread.
https://terryreis.smugmug.com/Garden-Spring-2020
 Terry Reis's gear list:Terry Reis's gear list
Fujifilm X-T20 Nikon D500 Nikon D850 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm F4G ED VR +12 more
Thanks, Terry
i am also considering the 70-300. What are your thoughts regarding the optical quality of the 70-300 comparing to 70-200?
As i previously wrote i am afraid of the possibility of a bad copy of the 70-300 af-p
Terry Reis
Robert 23 wrote:
Thanks, Terry
Can only speak for my copy, which I am happy with. As it is such a bargain I would suggest it is not a big risk.
I've never sent a lens back due to it being a bad copy. So maybe I've been lucky over the past 40 years.
Οκ i see.
Personally i sent 3 times back the 24-120 f/4 and after that, i came to the conclusion:
The cheapest the lens the bigger the risk of a bad copy.
I might be wrong but that's my experience so far..
JohnnyLuddite Senior Member • Posts: 1,236
I'm not sure what your intended use for the lens is, but my feeling is that the f4 lens isn't very good value for money against the 70-200/2.8. Particularly for events, every stop matters because it means that your ISO isn't being over-strained - it's popular with pros for a reason. The weight and size of the 2.8 is what it is for the purpose. I think the f4's expensive for what it is, the Nikon version at any rate.
If you wanted to try an incredible value lens ($100), the old 70-210/4-5.6 AF-D is a great performer. If I needed to do low-light no-flash events, I'd stump up for the 70-200/2.8 and keep it as a lightweight alternative.
 JohnnyLuddite's gear list:JohnnyLuddite's gear list
Sony RX100 Fujifilm X-E1 Nikon D750 Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF Nikkor 50mm f/1.4D +2 more
I don't do low light events so i don't need the 2,8 but I still need decent quality results from my lenses.
I tried once the 70-210 f/4 and i didn't like the results.I suppose i would have the same experience with its cheaper version.
As i previously mentioned  the weight for me is a crucial factor so any 70-200 2,8 is not my case.
scokill
scokill Veteran Member • Posts: 6,267
The 70-200 f4 is well above decent.  Professional results will be more about your skill than differences in the f4 or f2.8
 scokill's gear list:scokill's gear list
Nikon D4 Nikon AF-S 70-200mm F2.8E FL ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED
Toby43 Contributing Member • Posts: 693
My question is:
70 200 f4 for portraits. It’s a super lens. 70 300 general use. Also excellent. Can’t go wrong. 2.8 too heavy. Try doing a portrait session with it and you’ll see why you need VR!
 Toby43's gear list:Toby43's gear list
Ricoh GR II Nikon D750 Nikon AF-S Nikkor 50mm F1.4G Nikon AF Nikkor 28mm f/2.8D Nikon AF Nikkor 85mm f/1.8D +4 more
