Canon EOS Ra Sensor Measurements at PhotonsToPhotos
Started Aug 13, 2020 | Discussions
bclaff Forum Pro • Posts: 13,922
5
Not intended for terrestrial photography.
There seems to be no attempt to balance the channels for the increased red sensitivity.
This separation, highlighted on the left, is unusual:
So, overall read noise is lower and PDR is higher as a result:
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
GXAlan Regular Member • Posts: 223
Re: Canon EOS Ra Sensor Measurements at PhotonsToPhotos
Thanks for running the numbers. Is the change in PDR/read noise strictly due to the way the red channel is operating or is there something else like binned sensor/CPUs?  The 60Da has the same firmware as the 60D, but the Ra has specific firmware.
The 60D and 60Da didn't have the same degree of difference in PDR or read noise.
ASTRO PERSPECTIVE
It's interesting because a lot of dedicated astrophotographers have found the Ra to be really impressive in use for a simple one-shot camera.
https://www.youtube.com/watch?v=x8bYAc0cGM4
Richard Wright from Software Bisque was gushing over it in this video. Software Bisque makes one of the flagship "tripod heads" (mounts) for astrophotography
https://www.bisque.com/product-category/mounts/
These are the types of mounts used by universities and other researchers to do things like exoplanet discovery like KELT and MEarth.
https://keltsurvey.org/
https://www.cfa.harvard.edu/MEarth/Telescopes.html
DAYLIGHT PERSPECTIVE
Both the 60Da and EOS Ra are less aggressive with their Ha filters than aftermarket modification. Daylight performance has increased IR leakage (like the old Leica M8) but it's somewhat fixable if your standard for quality is lowered.
https://www.youtube.com/watch?v=uZA-vuy0uG8
https://skyandtelescope.org/astronomy-equipment/first-look-canons-eos-ra-mirrorless-camera/
https://astrobackyard.com/canon-60da/
sharkmelley
sharkmelley Senior Member • Posts: 2,738
Very interesting.
I particularly note that the Ra appears to have lower read noise than the R:
https://photonstophotos.net/Charts/RN_e.htm#Canon%20EOS%20R_14,Canon%20EOS%20Ra_14
For both the R and the Ra, do you know of the reason for the ripples in the PTC at the low end? For some cameras it's caused by digital scaling of the raw data but this isn't something normally associated with Canon.
Mark
 sharkmelley's gear list:sharkmelley's gear list
Sony a7S Nikon Z6 +1 more
OP bclaff Forum Pro • Posts: 13,922
sharkmelley wrote:
Very interesting.
I'm showing averages across channels, which isn't normally an issue, except the Ra channels are very unbalanced. Very low red read noise is dragging the average down. If it were green I think it would be unchanged. And strangely blue EOS Ra is noisier than EOS R.
The EOS R also has ripples indicative of scaling.
There are some other oddities with the Ra histograms.
I was using an OLED TV for the test patterns.  (for both the 60Da and Ra). Does that affect the analysis?
Is there something with the timing for read noise that Canon could somehow optimize for red Ha nebula at the expense of blue Reflection nebula?
For my tests the spectral characteristics of the light source don't affect the results.
Timing would be the same for all channels. They are scaled differently.
sharkmelley
So the gain is different in each channel?
And what kind of histogram oddities are you seeing?  Gaps?
Mark
Probably digital scaling.
Columns are DN, R, Gr, Gb, and B
Note that only the red channel appears to be unscaled.
There's definitely scaling on the red at some ISOs. Take a look at
in the 1/250 FPN tests
114A8184.CR3 ISO 125
114A8187.CR3 ISO 250
But yes, the blue and greens are more consistently scaled than others.
This must be the digital white balance pre-scaling (which explains why the white balance on EOS Ra is always easy to fix in post).  I recall the D810 did this and the D810A was considered a very good astro camera.
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
EOS Ra.
I find the EOS Ra to be surprisingly noise-free at higher ISO settings.  The sensitivity to magenta is definitely there as a result of the IR-cut sensor.  Hence the images of re nebulae are strongly saturated.  Overall, it's an impressive camera that needs no IBIS but can still be used for terrestrial photography if you're willing to edit your images.  The only thing that proves challenging is processing skin tones.  But that's to be expected from an Astro-specific camera.
I've been incredibly impressed with the EOS Ra's performance.  I look forward to seeing what it will capture with longer exposures and longer lenses when used on an EQ Mount to track the sky.  The images it has captured for me so far - with merely 6 second and sometimes 10 second exposures - have been extraordinary.
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
You seeing how Canon routines does intermediate ISO settings by scaling.
An exception being the 5DS/5DSR models.
Ah!  My other Canon is a 5Ds.
EthanCam Regular Member • Posts: 111
Very interesting, thanks for running the numbers, and thanks also to GXAlan for running the tests
I am intrigued by the lower read noise of the EOS Ra w.r.t. to EOS R / 5DIV at base ISO.
Assuming only the optical low-pass filter was changed, this should not change the read noise (in e-) in dark frames in my understanding. So here my questions:
  • Have you spotted some kind of 'NR' in the dark frames of the EOS Ra, like for the R5?
  • Or is it because the camera can use a lower conversion gain (e- to DN) due to increased sensitivity in the reds? (I would think this is the more likely explanation)
Ethan
Neuropsychology
Neuropsychology Regular Member • Posts: 331
I did a lot of comparisons between the Eos Ra and other cameras but I have been to busy to write it up or make a video.  Maybe I should now.
 Neuropsychology's gear list:Neuropsychology's gear list
Canon EOS-1D X Sony a6300 Sony a7R III Canon EOS Ra Canon EF 50mm F1.4 USM +15 more
Neuropsychology
Re: EOS Ra.
I did a comparison between the Ra and A7r3 tracked.  It was not mind blowingly better but I preferred the colors of the Ra. The sony was better at capturing light with less noise though.
No NR spotted but since more photons are captured you would need to lower the conversion gain to avoid clipping the ADC and that would result in slightly lower noise.
So that's a good theory.
Okay, thanks!
What’s also interesting is that long exposures are different between the R and 5D4
https://www.brendandaveyphotography.com/canon-consistent-with-eos-r-rp/
I have sent Brendan some files from the Ra.  At 5 min, I was getting 54-ish with SD of 18-ish Which is also better than the regular R.
The Sony sensors are very good for terrestrial but they still have filtering for astro.  The GFX100 is spectacular but it’s not cost effective to convert it for Ha sensitivity.  A variant of the A7R4 sensor is available in a cooled Astro camera, but you lose the flexibility of the DSLR.
That's interesting, here my theory:
5D4: older DIGIC6+ -> higher thermal noise (affecting long exposures) than EOS R
R: DIGIC8
Ra: DIGIC8,  but probably lower conversion gain -> similar thermals as EOS R but better noise statistics because of lower conversion gain
Yes, Sony are known for doing some sort of 'star eater thing', Mark Shelley's website is informative on that. But I am not an astro-photography expert
Marco Nero
To: Neuropsychology ...(PICS)
5
EOS Ra + RF 85mm f/1.2L USM lens - untracked 6-second JPEG (3x shot mosaic)
I haven't taken any tracked shots yet so these are unstacked JPEGS with 6 second exposures.  I just wanted to test this specific lens with the EOS Ra.  So far it's quite an amazing combination.  But I've now seen enough merit in the EOS Ra to slowly acquire and assemble a sturdy EQ Mount to use it on. I'm yet to source my power supply (Celestron has run out of the 12V 5A variety until late September) but I'm almost ready to go. I'll be sure to report in when I get to sample some shots with longer exposures and slightly smaller apertures.  I have no idea if this will work properly... but it should.
Just waiting for a power supply to become available.... (the smaller Celestron Lithium Power Tank on the right will probably be used to power my lens warmer). The camera + lens is large enough and heavy enough that I needed a mount that would offer me more payload than I might require - with a scope fitted at a later date.  I'll be interested to see how the Ra works with a good telescope.
Marco Nero.
