Does Sony FE 24mm 1.4 GM work on a NEX 5n?
Started 11 months ago | Discussions
billorg Senior Member • Posts: 1,282
Just wonder if there is a compatibility issue with my setup.  Is anyone using this lens on an APS-C body?  Thanks, Bill
 billorg's gear list:billorg's gear list
Canon EOS R6 Canon EOS 5D Mark III Sony Alpha a99 Canon EOS 6D Canon EOS 70D +18 more
Euell Veteran Member • Posts: 4,874
Re: Does Sony FE 24mm 1.4 GM work on a NEX 5n?
Yes. See my response to your inquiry in the lens forum.
 Euell's gear list:Euell's gear list
Sony RX100 Canon EOS 7D Sony a6500 Sony a7R III Canon EF-S 17-55mm f/2.8 IS USM +16 more
maccam
maccam Senior Member • Posts: 1,312
I looked for your response on the lens forum and couldn't find it. Mind giving a link?
JAW
 maccam's gear list:maccam's gear list
Sony RX100 VI Sony Alpha NEX-5N Sony Alpha NEX-6 Sony a5100 Sony a6500 +14 more
JAW
The response was that the focus problems are remedied by updating the lens firmware to version 02
OP billorg Senior Member • Posts: 1,282
Euell wrote:  The response was that the focus problems are remedied by updating the lens firmware to version 02
That’s not the case.  That lens and the NEX 5-N are incompatible for AF.  Updating the firmware solves aperture ring problems but not the AF focus issue.  Sony has a good page on camera and lens compatibility.
Bill
Bill
That is not what Sony has posted and would seem unlikely in any case. The 5n, you reported, is incapable of updating the firmware. Updating the firmware does not help with the aperture ring problems, which are a real incompatibility. However, if you manage to update the lens firmware, you will discover that the AF problems disappear, as I did.
Here are the compatibility issues from Sony's website:
  • "The SteadyShot is not supported.
  • Focus hold button of the lens does not work.
  • When Iris ring is switched between auto iris mode and manual iris mode, on-screen display (LCD monitor /Viewfinder) may flicker for a brief second and focus position may be reset.
  • When the Iris ring is set to manual iris mode, the Lens Model and Max Aperture Value of the Exif are not recorded correctly.
  • When the Iris ring is set to manual iris mode, the aperture value is set at the value which Iris ring indicates regardless of exposure mode.
  • When Iris ring is switched between auto iris mode and manual iris mode during movie recording, the recording will be stopped.
  • If you rotate the Iris ring, the time before Power Save is not extended.
  • When the Iris ring is set to manual mode, Background Defocus Control in Photo Creativity does not work correctly however the on-screen display is shown as is conventionally done.
  • The Exif lens name does not include "GM."
Note that there is no mention of AF incompatibility, other than that the focus hold button does not work.
