Just picked up the RP, will the EF 24-105 be all right or should I pay nearly triple for the RF?
Started Aug 11, 2020 | Questions
zkyevolved
zkyevolved New Member • Posts: 20
Hi everyone. I just picked up the RP (still on way from Canon) to replace my 80D since I wanted an "in" into the FF world. Anyways, I am on a budget, but I can get the 24-105 EF L lens (first version since I don't do any videography) for around 400€. I could also get the RF version for 1,100€. That's considerably more. I know from reviews that the RF version is faster and sharper by a bit, but since it's already a big step up from what I currently have... should I stick with the adapter + 24-105 EF version and save 700€ for more glass down the line, or should I just save up now and get the RF version? Is the EF + adapter going to be so darn awkward on the RP?
Thanks.
 zkyevolved's gear list:zkyevolved's gear list
Canon EOS RP Canon EF 40mm f/2.8 STM Canon EF 50mm F1.8 STM Sigma 100-400mm F5-6.3 Canon RF 24-105mm F4L IS USM
Canon EF 24-105mm f/4L IS USM Canon EOS RP Canon RF 24-105mm F4L IS USM
mingram1969
mingram1969 Regular Member • Posts: 109
Re: Just picked up the RP, will the EF 24-105 be all right or should I pay nearly triple for the RF?
Thanks.
You could always try somewhere like e-infinity and get the RF lens for considerably less than €1100;
https://www.e-infin.com/uk/item/4050/canon_rf_24-105mm_f/4_l_is_usm_lens_(white_box)
They get great reviews and I’ve used them at least half a dozen times with new problem at all
 mingram1969's gear list:mingram1969's gear list
Canon EOS R Canon EOS R5 Canon EF 135mm F2L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM +8 more
Ishootautoonly
Ishootautoonly New Member • Posts: 15
Will the RF be better, yes. However, especially when you’re on a budget the question of it is worth spending that much extra for a potentially difficult to perceive quality difference is a different question entirely. Unless you’re really trying it will probably be hard to pick a difference between images shot with either lens, I certainly wouldn’t feel guilty for taking the old lens over the new one if you get a good price on it.
 Ishootautoonly's gear list:Ishootautoonly's gear list
Canon EOS R5
Ray Chen Veteran Member • Posts: 9,651
RF
Consider the adapter is $200, I'd just skip the adapter and get the RF 24-105.
Ray
 Ray Chen's gear list:Ray Chen's gear list
zkyevolved
OP zkyevolved New Member • Posts: 20
Re: RF
My RP comes with the EF adapter. I also got an extra 150€ off of the RP due to a sale Canon is having.
zkyevolved
mingram1969 wrote:
Thanks.
Awesome, thanks for the link. 750€. I'd rather get the RF version for that price! Thanks a bunch! I tried eBay, Wallapop, and even google shopping but this store didn't even show up. Thanks again for the link, mate!
Regards.
jwilliams Veteran Member • Posts: 6,385
I would ...
5
Thanks.
I would add the RF 24-105 4-7.1. This lens is just made for the RP. Light and handles beautifully. The faster f4 L version is better (i have that also), mostly at the wide end but the 7.1 is very good at the long end (I was very surprised at how good it is at mid to long FLs) and it's not terrible at the wide end.
Don't be scared of the f7.1 as it is actually faster than a f5.6 APSC lens on your 80D and the RP has very good high ISO. If wanting a low light lens the RF 35 1.8 makes a good compliment and like the 24-105 is small/light and handles well on the RP.
I handled an RP with the EF 24-105 STM and adapter and didn't like it. Long and the weight being further out just didn't handle well. The older L version is even heavier so it would only be worse. IQ wise the RF L lens is definitely a step up from the older L version. The slower RF version is probably just a bit behind the old EF L version at the wide end (but the L has mustaches distortion at 24mm) and of course is slower at the long end.
The only real downside of the 24-105 4-7.1 is that if you like to shoot wide a lot and also make very large prints it might not be the best choice. Otherwise it's a great all around lens for an RP. Price is very reasonable also.
I'll add that the 24-105 L version is a superb lens, but it is a bit big for an RP and for most of the FL range there really isn't much IQ difference between it and the slower RF version.  IQ wise you can't go wrong with this lens, but make sure you want to carry it around with you as it is considerably heavier than the slower one and for me at least messes up the otherwise great handling of the RP.  It is much better suited for the R or R5/6 bodies.  I use mine on an R and it handles well but the camera/lens combo is much heavier than the the RP with the slower lens.
Jonathan
LesT
LesT Regular Member • Posts: 484
Re: I would ...
I have the RF version on its way will be selling my EF 24-105 locally.  I have the control ring adapter on its way from Korea it seems as I there are certain lenses I won't part with, mainly my 28-300L.
Relatively...actually very cheap it seems...is the 24-240 that I picked up just for a track shoot yesterday...  Did the job.
 LesT's gear list:LesT's gear list
Canon EOS R5 Canon EF 28-300mm f/3.5-5.6L IS USM Canon EF 16-35mm F4L IS USM Canon RF 24-105mm F4L IS USM Canon RF 24-240mm F4-6.3 +2 more
thunder storm Forum Pro • Posts: 10,139
zkyevolved wrote:
mingram1969 wrote:
Thanks.
Regards.
I think the RF is improved enough to be worth it. I would add to that: This is a walk around focal range. Hence it might be worth it to get rid of the adapter.
EF glass = bang for my buck
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
stevvi Contributing Member • Posts: 829
zkyevolved wrote:
mingram1969 wrote:
Thanks.
Regards.
I would be aware that e-infinity is selling grey imports which won't have Canon's warranty. That isn't necessarily a bad thing (I'm in the UK and buy most of my equipment from the grey market) but it's something to bear in mind.
 stevvi's gear list:stevvi's gear list
Canon EOS R Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM +4 more
diness Veteran Member • Posts: 3,758
Thanks.
If you can find a place to get the RF version used, I would try that.  There are lots of great hardly used copies of it out there because it’s a kit lens.  I have found it to be a lot better than the EF lens.  It’s sharper, focusing and IS are both quieter, and it has the control ring as well and has way less zoom creep.
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
sassan_n Forum Member • Posts: 78
In Germany, if you buy the RP and within 30 days or so you also buy the RF 24-105 f4 from an official European dealer, then you will get 200,- Euros cash-back
https://www.canon.de/lens-promo/
a couple of months ago, I bought the RP with adapter from amazon.de for 1100,- Euros minus 100,-Euros instant cash-back. At that time, the RF was around 1130,-Euros at amazon.de but I found the lens on Amazon in Spain for 1000,- Euros. Then applied for the cash-back and at the end the RP with adapter and the RF 24-100 f4 cost me 1800,- Euros.
 sassan_n's gear list:sassan_n's gear list
Nikon Z 24-70mm F4 Canon EOS M5 Nikon Z6 Canon EOS RP Canon EOS M6 II +10 more
pkoenig2001 Contributing Member • Posts: 827
Re: I would ...
Good insight here except that 24-105 f4 L is not too big for RP especially with extension grip - nice combo
 pkoenig2001's gear list:pkoenig2001's gear list
Canon EOS 40D Canon EOS R6 Canon EOS R7 Canon EOS R10 Canon EF 100mm f/2.8 Macro USM +13 more
zkyevolved
Re: I would ...
I'll have to check out the grip. I got the RP yesterday and I was playing around with it a bunch. My only FF lenses that I currently have are the 40mm and the 50mm stm lenses. I purchased the 24-105 L lens and it should arrive next week (extremely excited, my first L lens!!!!).
zkyevolved
Nice!! That's actually still active (I just changed the .de to .es) and it is still working. Still though, I saved more money from the grey market purchase. When I purchased the RP I got 150€ off from Canon, but even with the discount from Canon the lens is still several hundred more than the one linked from e-infinity. Hopefully everything will be fine though! If not, I can always return it and purchase another one (I have 30 days to do so).
JamesK Regular Member • Posts: 324
I went through this last year as I had a trip over to Germany to visit my son.  I have a 5DMk III with the L version which pretty much stays on the camera.  When I bought the RP before my trip last year I also bit the bullet and bought the RF 24-105.  I still use a DSLR and have not bought fully into Mirrorless yet as you seem to be.  If you are committed to Mirrorless I would say bite the bullet now and get the RF as you will probably do it later anyways.
ChicagoRob
ChicagoRob Senior Member • Posts: 1,150
Re: I would ...
One of the smartest decisions you will ever make. The RF 24-105 is insanely good.
cityboy New Member • Posts: 3
Thanks.
I faced the same dilemma and went with the adapter.  I have no regrets.  I couldn't afford to replace this lens, but replacing my 100-400 was really impossible.
I know that this particular lens is not the sharpest lens that Canon has ever released, but it's perfectly serviceable with a slight bit of sharpening applied in LR.  Recently purchased Topaz Labs DeNoise AI, which not only removes noise but slightly sharpens the image as well.  Absolutely brilliant results.
I'm confident that I made the right decision, but will probably replace my lenses right after I win a major lottery.
Jos van Eekelen Regular Member • Posts: 463
zkyevolved wrote:
mingram1969 wrote:
Thanks.
Regards.
I just checked the link: GBP 979 (€ 1166). Out of stock and depending on your location you will have to pay VAT and/or import duties (I think, the UK is not an EU member anymore).
Apart from that, the lens seems to be out of stock everywhere. In the Netherlands the price was recently raised from € 1200 to € 1474. No big deal since I am not able to buy one for 14 months or so.
 Jos van Eekelen's gear list:Jos van Eekelen's gear list
Canon EOS R6 Canon EF 24-105mm f/4L IS USM Canon RF 50mm F1.8 STM
tocar Veteran Member • Posts: 4,533
I had the same dilemma.  I decided to keep the EF 24-105L and the plus adapter.  I didn't want to spend money for another L lens with the same focal length plus what am I going to do with the old 24-105L?  I have a few collection of the L lenses and to replace them would be cost prohibited.  Another plus is that the EF/RF adapter can utilize EF-S lenses also further expanding the capability of the RP.  Surprisingly the L lenses are sharper on the RP than the 5DII and 70D.
 tocar's gear list:tocar's gear list
Canon PowerShot S5 IS Canon PowerShot SX50 HS Nikon Coolpix P900 Canon EOS 5D Mark II Canon EOS M +1 more
