Should I turn off lens OIS (eg 18-55) when using with X-T4 IBIS?
Started Aug 9, 2020 | Questions
(unknown member) Junior Member • Posts: 42
Should the stabilization on the lens be turned off when using it on a body which already has IBIS on it like the X-T4?
Or will the 2 work together just fine?
Thanks.
khollister Regular Member • Posts: 159
Re: Should I turn off lens OIS (eg 18-55) when using with X-T4 IBIS?
It's all or nothing - the OIS switch on OIS lenses turns off ALL stabilization. There is no way to independently control IBIS vs OIS. When an OIS lens is mounted, the OFF option dissappears from the IS menu in the camera as well.
 khollister's gear list:khollister's gear list
Fujifilm X-E2 Fujifilm X-T4
Mczar2u Regular Member • Posts: 227
IBIS and OIS work together.
If you turn off OIS on the lens  you also turn off IBIS, at least on the X-H1. There is not way to use a Fujifilm lens with OIS turned off and leave IBIS on. I  am not sure the other way around... turning off the IBIS but leaving on the OIS.  I never had a reason to try it
I do not have X-T4.... yet
Mario
OP (unknown member) Junior Member • Posts: 42
So all in all it handles OIS+IBIS automatically; thanks for the answers.
