Distant dslr
Started Aug 8, 2020 | Discussions
Automaticbirdphotography New Member • Posts: 9
Distant dslr
Hi, I want to put my camera (nikon d7500) by a branch, and then control it from a distance, so that wildlife can stand on it. I have tried remotely with qDslr on my computer, but it was quite laggy and the resolution weren't the best, so it was hard to check focus. Then i tried digitalcamcontrol, and the resolution were great, but it was still a bit laggy. Does anyone know a better solution to this? And if i am going for a solution like digitalcamcontrol, then i need a very long usb cable (about 50m) anyone have a solution to that?
Thanks in advance
Nikon D7500
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Re: Distant dslr
The lowest lag would be using a CHDK-compatible Canon, for example, most PowerShots and the EOS M3 and M10. You can program them to have about 1/1000s latency on triggering. If you meant lag on the video feed, well, you're probably stuck with whatever unless you plug it into HDMI for the live view.
There are USB repeaters. Here's an expensive wireless one . FlexIHub outlines several methods. Obvious answers include using a Raspberry Pi to host it and then talking via wifi or wired Ethernet. There are active USB wired repeaters for less than $20 (e.g., this ), but 50m is probably too long for that.
USB protocols were never intended to go that distance, so timing problems are likely unless you convert to/from a transport medium intended for longer ranges, such as wifi and Ethernet Cat6 cable.
Thanks in advance
The real weak link here is the camera's suitability for this task. You might easily spend more getting this to work than simply buying a camera more directly suited to the task....
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
OP Automaticbirdphotography New Member • Posts: 9
Re: Distant dslr
Thank you very much!
ThrillaMozilla Veteran Member • Posts: 7,674
Re: Distant dslr
There's a limit to the length of a USB cord, and it's not very long.  There's also a limit to those wired repeaters.  I think it's maybe 2 cords max.  Also, they are powered by the USB controller, and there's a limit to the power.
Wireless sounds more feasible to me.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Re: Distant dslr
The gold standard for this would likely be a pair of pocket wizards.  Should give at least 1/2 mile range.  Not cheap, but perhaps one of the Chinese brands is comparable.   They are sold as flash triggers but they can be connected such that they trigger a camera.
Phoenix Arizona Craig
www.cjcphoto.net
"In theory, practice and theory are the same. In practice, they're not."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
elIvarz Regular Member • Posts: 125
Re: Distant dslr
Maybe is possible use Focus Trap? Don't know if D7500 have this option.
Trap Focus
And one option more is use some triggers, f.ex. Pluto.
Pluto
 elIvarz's gear list:elIvarz's gear list
Pentax K-50 Pentax smc D-FA 100mm F2.8 Macro WR Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax 55-300mm F4.5-6.3 ED PLM WR RE
LorieS
LorieS New Member • Posts: 3
Re: Distant dslr
Trap Focus
Pluto
As far as I know there is no focus trap on D7500.
