Maxxum 650si Won’t Turn On
Started Aug 10, 2020 | Discussions
Joseph_Engelman New Member • Posts: 1
I’m not sure if this forum is strictly digital Minoltas but please forgive me if I’m posting this in the wrong place.
I inherited a Minolta Maxxum 650si Date(what a mouthful) that doesn’t want to turn on. I purchased a new 2CR5 battery and it still doesn’t work. I actually brought it to my local store today and they threw another battery in and that also did nothing. The contacts look very clean and we tried bending the ends a bit in case they weren’t making good contact. No dice.
The camera belonged to my grandma and had two lenses and a flash that I’d really love to try using. I swear it worked about a year ago when it was given to me. I vaguely remember testing it and then packing it away.
Any suggestions? There is a local shop that can probably service it but I know it’s not worth enough money to really justify a $100 repair.
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Maxxum 650si Won’t Turn On
This sometimes comes up .
On the assumption the camera isn't faulty , it's sometimes the battery it doesn't like .
Are you putting it directly in the camera or do you have a vertical grip fitted ?
Have you cleaned the contacts in the battery chamber ?
Use the end of a pencil with an eraser on .
Where this issues come up before it's turned out that the battery was the problem .
Although new the camera wouldn't come to life .
Try a different brands battery and see how that goes . What brand were you using ?
If the camera does turn out to be faulty , you can buy these cameras for about $30 , so a replacement is the usual remedy .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
Hike Pics
Hike Pics Senior Member • Posts: 2,917
Joseph, I agree with Neil's advice.
I am currently finishing up a roll in my 650si Date. I am using a Panasonic 2CR5 battery and everything works great.
I realize the sentimental value of you camera. Sometimes these things just happen. These old Maxxum bodies are getting old and sometimes get flaky. I don't know where you are located but here in the US a used body will cost average $35 for either the 600si or 650si, but expect that to go up. For instance, I bought mine for $17 and it included a Minolta 35-80mm F4-5.6 "Lens Cap" lens. That was a year and a half ago. And this body is a very well featured one as you probably know. It is actually my favorite, along with the Maxxum 70.
Good luck in your efforts, let us know the outcome.
...Wes...
