LesT
Forum Enthusiast
Started this morning because i wanted to find the fastest way to get pictures from the R5 to my PC. It was great that the Type-C plug in charges when the camera is off and simply displays folders on the PC when on. My interest, however, was to move data the quickest way possible.
So we started with a large continuous run of RAW pictures on the CFExpress card...617 with a total size of 27.4GB. Only took a few seconds on the R5 with no buffer jam. LOVE THIS!
Next up, I had a PCIe 3.0 x4 (4 lane) AIC card with a CFExpress adapter made for me by Lexar which plugs directly into the computer PCIe slot (see below) as I wanted to know the fastest speed possible to move the data from that card to the PC. - 38 seconds. Pretty impressive.
Testing cables. I did two tests with the supplied cable and a 40Gbps Tbt3 Type-C cable. They both returned with the same time in moving that data at 4 minutes and 20 seconds. Alot slower but we have to live with this I guess.
Lastly, I wanted to test out the Lexar CFExpress card reader. So... all card readers right now are limited to two lane which maxes their transfer speeds out at 1GB/s...or 10Gbps. If you are considering a card reader... DONT WASTE YOUR TIME. Via card reader, and they are all the same right now, it took 8 minutes and 37 seconds to move that data.
Havent tried wi-fi or BT yet...but it will be slower.
So...two things learned to help others...
1. Don't go buying a 40Gbps cable as it will not speed data transfer up any faster than the USB 3.1 SS cable supplied.
2. It is cheaper and much easier to simply plug the cable into your R5 than buying a CFExpress card reader which will double your transfer times.
Have a good one.
Oh lastly... I had done a report on that card in my business and it can be found here... hope its ok to post.
https://www.thessdreview.com/featur...gb-long-awaited-storage-media-storage-speeds/
Have a good one.
