External HDD or SSD for backups?
Justme Forum Pro • Posts: 22,208
I am looking at Seagate SSD and HDD for backups in the 2TB range.  SSD costs double but is it more reliable?
What brand of external HDD do you recommend as reliable?
I know you mean well but please do not embed my images into the forum. Thanks for respecting that.
http://www.pbase.com/golfpic/some_recent_shots
http://www.pbase.com/golfpic/a_red_fox_family
http://www.pbase.com/golfpic/image/55043863/small.jpg
 Justme's gear list:Justme's gear list
Canon EOS 7D Mark II
rickpoole Senior Member • Posts: 1,200
Re: External HDD or SSD for backups?
Look at Backblaze's HD failure rates reports to see which drive in the capacity you need has the best reliability.
 rickpoole's gear list:rickpoole's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +7 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 16,835
My experience with external backup drives has been dismal, with many failing soon after the warranty expired.  By many, I mean 3-4 over 6 or 7 years.
One would think that (modern) SSD drives would be more reliable, though I'm not sure what happens if no power is applied for a year or two.  However, I just experienced my third (internal)  SSD failure in the past 4 years.  The early models seem not to be as good as hoped.
Phoenix Arizona Craig
www.cjcphoto.net
"In theory, practice and theory are the same. In practice, they're not."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +37 more
Sean Nelson
Sean Nelson Forum Pro • Posts: 13,874
No media, even SSDs, are immune from failure, so you should have more than one backup drive and alternate them. The last thing you want to discover after your live drives die, get corrupted or or stolen is that your sole backup is also dead. You also don't want to be in the situation where, for example, your system suffers its failure halfway through cloning your live data to your only backup drive. Now that backup is half updated and may be useless. And whatever took out your system might have taken out the backup as well.
That being the case, I see no reason to pay the extra money for an SSD as backup media. The big extra that SSDs give you is speed more than reliability, and you don't really need the speed for backup media since you don't normally run your backups while you're actually doing work on the computer.  And the reliability issue is covered by having multiple backups.
I would particularly avoid SSDs if by "backup" you mean "keep data offline for a while". SSDs will loose data if they're left sitting on the shelf for too long, they need to be powered up and scanned every so often in order to detect and refresh memory pages whose static charges are dissipating. That's not too much of a problem for an SSD drive that gets used as part of a regular backup cycle every month or so, but I wouldn't trust it to keep offline data intact for periods measured in years.
SC489 Senior Member • Posts: 1,225
It's very easy to kill an external HDD if you knock it whilst running so in that sense a SSD is more reliable. You need to backup to two drives as insurance against such failures.
 SC489's gear list:SC489's gear list
Sony Cyber-shot DSC-HX80 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +4 more
Robert Zanatta Senior Member • Posts: 1,952
7
Instead of one SSD, Id buy two HDs and do double backups.
 Robert Zanatta's gear list:Robert Zanatta's gear list
Austinian
MOD Austinian Forum Pro • Posts: 10,356
I don't recommend "external" HDDs at all based on what I often see in PC Talk.
What I recommend is a USB dock that accepts standard desktop SATA HDDs. That way any failure of the USB hardware won't affect your existing backups; the dock is easily and cheaply replaced, and you can back up multiple HDDs in rotation and have most of your backup HDDs safely off-line.
 Austinian's gear list:Austinian's gear list
Sony a7R III Sony a7R IV Samyang 14mm F2.8 ED AS IF UMC Sony FE 50mm F2.8 Macro Sony FE 24-105mm F4 +2 more
Jeff Farkas
Jeff Farkas Regular Member • Posts: 177
IMO.. An SSD is mainly for the OS and programs/apps and not data. The difference in performance between an SSD and HDD for data isn't great enough to justify the extra cost.
I would opt for a double 2tb HDD, One for primary storage and one as a back up and it would be best if they're internal.
Brand wise I would go for Western Digital. I've had the best results with them in all of my builds. The blue series is the best bang for the buck
Jeff
 Jeff Farkas's gear list:Jeff Farkas's gear list
Nikon D90 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G ED Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II
Ken60 Senior Member • Posts: 2,282
I agree , and have read that SSD's don't like to be left unpowered for long periods of time ... remember something about image fade !
Similarly HDD's are a mechanical monsters , and I would suggest giving them a short burst every now and then just to allow self lubrication.   I have a USB dock, into which you can plug all sorts of HDD's and enjoy them at USB 3 speeds.  As others have mentioned show extreme care in allowing the drive to come to rest and park , before lifting out of the unit and placing in a storage ....... bumping whilst spinning is a sure route to problems.
WD do a modest 4tb Sata HDD for around £100  or less , you could get two of these and make double backups for the price of a single lesser brand 2TB SSD.
Gear ... what I need to get the job done , after all you don't see mechanics listing their brand of spanner as a qualification .
CAcreeks
CAcreeks Forum Pro • Posts: 15,471
I like this docking station because it has a cover.
https://www.amazon.com/Sabrent-External-Lay-Flat-Docking-EC-DFLT/dp/B00LS5NFQ2/ref=sr_1_4?crid=2XKX0C2CVXUJK&dchild=1&keywords=usb+sata+dock&qid=1596900244&s=pc&sprefix=usb+sata+dock%2Celectronics%2C208&sr=1-4
Internal 3.5" drives have more capacity than 2.5" laptop drives. Are they more reliable?
Different strokes for different folks ..
https://www.amazon.com/dp/B07CSG4XM4/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B07CSG4XM4&pd_rd_w=LjroV&pf_rd_p=a64be657-55f3-4b6a-91aa-17a31a8febb4&pd_rd_wg=yJ1YA&pf_rd_r=XGR0D5WNCGWTVC8K88Q9&pd_rd_r=e5d2279f-f081-4043-aabb-78fa913ff004&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzVEU4SkZaUjZQUlFPJmVuY3J5cHRlZElkPUEwNzYwNjkwR09OVjhIMlBWUjNWJmVuY3J5cHRlZEFkSWQ9QTA3Nzg3OTMxSDA3QUhTUjJDUFJZJndpZGdldE5hbWU9c3BfZGV0YWlsX3RoZW1hdGljJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
I chose one like this  , made by Startech.com  , it can take every drive from old PTA to SATA and smaller laptop size drives.  Because it can take more than one at a time you can copy a drive , and I find there is more of the drive to hold on to when lifting in and out .  The drives get warm whilst working , so the open to the air style of fitting is good for cooling.
Austinian
That might be nice protection, but I'd be concerned about drive temperatures for some HDDs. I only use mine for laptop backups, so a cover isn't useful.
I have one of these:
https://www.amazon.com/Plugable-10Gbps-Upright-Cables-Supports/dp/B01E80N2E8/
I don't know, but I'd expect the 3.5" drives to be considerably faster; no need to worry about power consumption/battery life like a laptop drive.
Sean Nelson
You don't have to close it while you're using the dock but you can close it when it's idle to keep the dust out.   I had to make a little cardboard cover for my dock, I like the idea of one that's built in (or at least provided with the dock, even if it's not attached by something like a hinge).
Austinian
The dock I linked to has such a hinged cover that folds when a desktop drive is inserted. You do make a good point, and I think I'll cover the small laptop/SSD opening with a piece of plastic; can't hurt.
I have had one for about three years and it's been excellent.  UASP support.  Hot swapping works.  Never glitched.  With a 4TB Seagate Barracuda the sustained transfer rate is 180 MB/sec, and random small access is also quite fast.  Can boot from it too.
OP Justme Forum Pro • Posts: 22,208
What do you think about these portables?
These are external slim portable HDD. How do they pack a 2TB HDD into such a small case? Does that affect heat build-up in a negative way?  How do these slim portables compare for reliability to external HDD in larger cases?
Seagate Backup Plus Slim 2TB External Hard Drive Portable HDD – Silver USB 3.0 for PC Laptop.
Thanks for the helpful advice so far.  I will respond soon.
Can I plug these internal SATA HDD to the USB dock?
Thnaks for the tip on this option. Can I juust plug these internal SATA HDD to the dock?
https://www.amazon.ca/Seagate-IronWolf-7200RPM-128MB-3-5-Inch/dp/B07H2FPFW5/ref=sr_1_2_sspa?dchild=1&keywords=sata+hdd&qid=1596938465&sr=8-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExT0xZNFNVVDVMNFJUJmVuY3J5cHRlZElkPUEwMjQxODkzMlJWVFhSTDhUQk5NViZlbmNyeXB0ZWRBZElkPUEwODA4OTYyMjNSUU42V09WRlkzUSZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Re: Can I plug these internal SATA HDD to the USB dock?
Yes.  And 2.5 inch drives.  And SATA SSDs.
Thanks Robert. I may consider this option.
a_c_skinner Forum Pro • Posts: 10,087
I think that is good advice.  I'd always assumed a USB drive, if cracked open, revealed a standard SATA drive that could be tried in a new enclosure.  Apparently a lot don't so even if the drive is intact a failed one can be difficult to read.  A USB enclosure plus a standard drive if you don't care to have naked drives lying around.
Backup hardware does not need to be highly reliable because you will have a strategy (bascially several up to date copies stored off line) so a single or even duplicate failure won't affect all your data.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
