Metering on White Egrets
Rocket13 Senior Member • Posts: 3,295
Hello all, back for more tips. So I love shooting Egrets, I don't get to see them often so dont get to practice a ton on them. What I would like to know is how to meter on them to get the best detail out of them. I am sharing a recent shot just as reference. I understand I was not in a good position for the light but I didn't have options .
 Rocket13's gear list:Rocket13's gear list
Canon EOS 80D Canon EOS Rebel T6 Canon EOS 90D
ThrillaMozilla Veteran Member • Posts: 5,033
Re: Metering on White Egrets
I shoot egrets too.  They're just plain hard.  They usually look better if nothing is clipped.  There are some methods you can use.
1. Spot meter on the egret, if your camera has a small enough spot.  Then you can use some stops of exposure compensation.  Like maybe 2 or 3 or 4.  You'll have to figure that out by trial and error.
2. Meter off a white or gray card or a white shirt or something, and set exposure compensation appropriately.  You'll just have to figure it out for deep shade.
3. Bracket.
4. Trial and error.  Use blinkies/zebras/histograms.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1
OP Rocket13 Senior Member • Posts: 3,295
As far as EV goes + Ev for like snow until blinkies then back off a bit? I assumed spot but wasn't sure. Thanks for tips
Rocket13 wrote:
As far as EV goes + Ev for like snow until blinkies then back off a bit? I assumed spot but wasn't sure. Thanks for tips.
That should work, but be aware that there is quite a range of brightnesses even in the white areas. And typically those bird might be against a very dark background in the woods or deep water or something. It's a bit of an art.
The other method I didn't mention is to buy a camera specifically for those birds. A D850 or D500 would be sweet. There are others too.  But technique and luck can go a long way.
Canon EOS Rebel SL1
richj20 Veteran Member • Posts: 8,156
Good tips from ThrillaMozilla.
 richj20's gear list:richj20's gear list
Panasonic Lumix DMC-GX8 Panasonic Leica 100-400mm F4.0-6.3 ASPH Sony a7R II
Morris0
Morris0 Forum Pro • Posts: 16,256
In general, it's best to give your subject more space in the direction there looking rather than placing it in the middle of the screen
Morris
Fujifilm X-T3 Samyang 12mm F2.0 NCS CS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Sigma 150-600mm F5-6.3 | C XF 90mm +11 more
Bill Ferris
Bill Ferris Veteran Member • Posts: 5,678
I use center-weighted metering for just about everything and will choose settings 2/3 to a full stop (sometimes more) below meter. My camera becomes invariant at ISO 400 so, I'll dial that in knowing I can maximize exposure and have room to lighten in post. I typically bring up an egret (or the white heads of eagles and osprey) by anywhere from 0.5 to a full stop. I'd rather push a bit in post than risk loosing any detail in the feathers. The best light is early morning or late day indirect lighting, or a pleasantly cloudy day when the sky is a ginormous soft box
Bill Ferris Photography
Flagstaff, AZ
http://www.billferris.photoshelter.com
 Bill Ferris's gear list:Bill Ferris's gear list
Nikon D610 Fujifilm X-T20 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Tamron SP 24-70mm F2.8 Di VC USD +3 more
Modeling lighting
Sometimes the difference in light illuminating the bird is so extreme, that no amount of editing will produce a uniform light across the bird.
In these cases, a portrait in "modeling lighting" can be attractive - the sunlight illuminates just a portion of the bird.
- Richard
ruley74
ruley74 Contributing Member • Posts: 548
When I had the Canon cameras last year I'd need to be 1-1.5 stops -EV for Egrets, for some reason my EOS R seemed to blow them out pretty easily.
Best tool I have for Egrets now is Nikon cameras with the highlight weighted metering, it's simply excellent for Egrets.
I give permission to edit my posted images for the purpose of constructive feedback, if it's not constructive don't bother!
https://www.instagram.com/photos_by_ruley/?hl=en
 ruley74's gear list:ruley74's gear list
Nikon D500 Nikon D850 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 400mm f/2.8G ED VR II +4 more
Snowfella
Snowfella Senior Member • Posts: 1,069
All depends on what metering mode you use, background and how prominent the Egret is in frame.
I tend to shoot mainly center weighted for birds (although my camera also has highlight protection metering mode) so with an Egret only taking up a fraction of the frame that generally means some negative EC needed, on the other hand one prominent in the frame generally means some positive EC needed.
How light/dark the background is determines how much EC is needed.
Up close with the bird taking up most of the metering area, positive EC needed
Only taking up a fraction of the metering area, negative EC needed
Though I do "cheat" like mad and shoot EVF cameras so I have a live histogram and also if I want it blinkes in the viewfinder, plus I can see the exposure even before taking the shot.
 Snowfella's gear list:Snowfella's gear list
Sony SLT-A77 Sony SLT-A37 Sony a99 II Sigma 150-500mm F5-6.3 DG OS HSM +1 more
Morris0
I've had fun watching how others approach this.  I do it two ways yet both are similar.  On a mirrorless where I can see the results I'm usually using compensation and adjusting by eye.  I then take a photo and check for the flashing highlight warning and move 1/3 stop at a time till it shows up and then dial back 1/3 from the warning.
On an SLR and sometimes on mirrorless and particularity when there is action I'll quote what Popular Photography printed from my interview with them.
I get the exposure as close as possible using a Sunny 16 equivalent in manual exposure.  I then adjust one click at at time till I get flashing highlight warnings.  Then I back off one click.  Most cameras default to 1/3 EV clicks and that's better than 1/2 EV clicks.  Once you are set up this works as long as your subject is in the same light.  This method avoids the issues of how much your subject fills the frame and also changing backgrounds.
Morris
Wow, there's a tool.  I didn't know about that.  It's exactly how I used to expose color-reversal film.  Now it's called "exposing to the right".*
* Weasel words required here to prevent endless internet debate (EID).  Technically, exposing to the right implies exposing at the lowest ISO setting.  If you are willing to relax that requirement, then highlight-weighted metering would be almost exposing to the right.  (Please don't debate this term, folks.  It's way beyond the original question, and not needed to answer the question.)
Canon EOS Rebel SL1
Trial and error. That works poorly when there is action that won't wait. I like to set the exposure manually, so I don't have to fool around later, but that works poorly if the light is changing.
Either way we're stuffed. Cameras should be smart enough to expose for the highlights, and I'm sure they all will be, r_e_a_l___s_o_o_n___n_o_w -- by which I mean many years from now.
Magic Lantern has a way of kludging this.  According to the step-by-step instructions, it can be done with only 12 steps.  Sigh.
Canon EOS Rebel SL1
John Photo Contributing Member • Posts: 918
And it appears, according to Ruley74, that it is a selectable option in his Nikons...so maybe your "real soon now" is actually "here now"??;-)
Notice that I said all cameras, so no, it's not here now.  Mirrorless cameras seem like the best (only?) candidates, but it's good that Nikons have this now.
Canon EOS Rebel SL1
Morris0
Actually it works superbly for action as you set your exposure on arrival.  Note your exposure for white and your exposure for all other subjects.  Then it's simply a matter of moving the exposure wheel a few clicks.  I usually change the shutter speed though for Fuji ISO works best as I can do it in 1/3 EV increments.
Morris
Now I see what you are doing. That's about how I do it too. But it doesn't work very well if the light varies.  Personally, I muddle through, but I miss shots, alas.
Canon EOS Rebel SL1
Morris0
Ya, a partly cloudy day presents extra challenges.  This is one of the reasons that I love shooting mirrorless as I can see what I will get before dropping the shutter.
Morris
Thanks all, I will keep working on it and try some of the sage advice. Of course where I found them the other day there were none to practice on today.
