Low light lens for my Lumix G7 or buy new camera
Started Aug 8, 2020 | Discussions
asirvr4 New Member • Posts: 1
Hi,
I’m new to this forum and I’m a beginner photographer. I have had my Panasonic Lumix G7 for about 5 years and I only have the 14-140mm lens. Recently I became excited about photography again.
I’m looking to see if it’s worth it to buy a prime lens for indoor low light photography and some night photography. Mostly for family & new born moments and when I feel like doing some nice night shots. So far I believe my options are:
Panasonic LUMIX G 25mm f/1.7 ASPH
Sigma 30mm f/1.4 DC DN C
Panasonic Lumix G 20mm f/1.7 II
Olympus M. Zuiko 25mm or 45mm f/1.8
or any other MFT lenses you recommend with AF?
my budget is 300 usd.
my other option is to sell my camera+lens and buy a Sony RX100 latest version?
what do you recommend please?
thanks,
Asir
Panasonic Lumix DMC-G7 Sony RX1 Sony RX100
alcelc
alcelc Forum Pro • Posts: 19,006
Re: Low light lens for my Lumix G7 or buy new camera
asirvr4 wrote:
Hi,
On IQ, the newer models indeed does not give material improvement. The improvement would be on hardware side, more features etc.
Think of ISO1600 vs ISO3200~6400, 2~3 stops slower shutter speed for non IS lens and 4~5 stops for DUAL IS combo... Normally for shootings which slow shutter speed is usable, a newer body will help.
Regarding indoor shooting, usually I could imagine limited shooting distance. If so, I would look for a wider angle lens. Likely a 35mm to max 28mm eq AoV of FF, i.e., 14 to 17.5 for M43.
Surely if you love to shoot head shot, a longer lens might also be useful like 20 to 25. Longer than that might be more restrictive IMO.
G7 and an used 14~140 (I assume the f/3.5~5 6 mk-I) would give you not much on selling them.
thanks,
Asir
Albert
** Please feel free to download the original image I posted here and edit it as you like **
rodriguezPhoto
rodriguezPhoto Veteran Member • Posts: 4,261
asirvr4 wrote:
Hi,
thanks,
Asir
As has already been suggested, you'll want the lens to be on the shorter side, not more than 25mm.  Indoors, if the lens is long, you may not have room to back up enough.  My favorite lens is the Olympus 12mm f/2 but even though I bought a used copy, it would be out of your range.  Before that I tried out the Panasonic 20mm, f/1.7, but I found the focusing to be very slow so I returned it.  Don't be afraid to look at refurbished or used to widen the options within your price range.
~~~ Kim
 rodriguezPhoto's gear list:rodriguezPhoto's gear list
Olympus E-1 Olympus E-3 Canon EOS 6D Olympus E-M1 Olympus E-M1 II +55 more
Jan Chelminski Senior Member • Posts: 2,466
Hi,
I would advise choosing a f/1.7 or f/1.8 lens in the 17mm to 25mm range, either the  Panasonic or Olympus lenses should autofocus well on your G7. That focal range (from semi-wide to standard) is generally best for all around indoor/outdoor and low light use.
If you like close up photography, check the minimum focusing distance of lenses you are considering, as it can vary quite a bit.
On the other hand, if you know from using your zoom, etc, that the 45mm focal length is one you favor quite often, then IMO, you will not be disappointed by choosing the Zuiko 45mm f/1.8, as its a really great lens.
Rgds,
Jan
"The camera introduces us to to unconscious optics as does psychoanalysis to unconscious impulses"
"The art of the critic in a nutshell: to coin slogans without betraying ideas. The slogans of an inadequate criticism peddle ideas to fashion."
- Walter Benjamin
"Drawing is a constant correcting of errors, maybe a great deal of creation is exactly that."
- John Berger
"...to photograph is to frame, and to frame is to exclude."
-- Susan Sontag
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
asirvr4 wrote:
Hi,
thanks,
Asir
The cheapest options that autofocus are 25 1.7  and youngno 42mm
the 25 is serviceable and a good normal option.
I would get a 42.5 from panasonic, but that is 345 usd .
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
Optimist_Eyes Forum Member • Posts: 86
You are lucky that you already have your 14-150 and can use it to trial out the various focal lengths. I do think that 45 is a little long for indoor use, so would rule it out. But you can try your existing lens at 20, 25, 30 and 45mm indoors to see how tight it would be for you.
One thing to consider is that the newborn will not stay a newborn for long! Soon the little bundle of joy will be scooting, then crawling, then careening at fast speeds throughout the house. For that reason the autofocus speed of your lens comes into consideration. I love my Panasonic 20 f/1.7, but the focus speed is not great. Therefore I would rule it out.
Of the remainder of the lenses you listed, I do not know their focus speeds. But you can check out reviews online. Some helpful sites are cameralabs.com, Lenstip.com, opticallimits.com, lensrentals.com (look in their blog - the micro four thirds review are far back), 43rumors.com sometimes has some reviews, photographylife.com, and sansmirror.com are all pretty decent. Rob Trek has a good youtube site also.
Good luck!
 Optimist_Eyes's gear list:Optimist_Eyes's gear list
Canon G5 X II Nikon D60 Nikon D700 Nikon 1 V1 Nikon 1 V2 +7 more
CH179 Regular Member • Posts: 149
i think with your intended future usage to take some photo of your kids, i would not suggest 20mm 1.7 due to its slow AF speed
45mm is too long to be used in typical indoor to the point it started to annoy me as I often need to find a place to backup and those who do not understand photography will think you are crazy to shoot that far from your subject.
So I guess the 25mm 1.7 is the best low light lens with good AF speed within your budget. but I do think the oly 17mm 1.8 fits perfectly with your requirement but it's more expensive.
getting the latest RX100 is a worse option for your low light due to the slower F2.8 lens + smallish 1-inch sensor and you might need to spend a lot more(it's not a cheap cam, at least in my area) than just getting a new budget low light lens even after you sold your current kit. I don't see you get anything better out from that option unless you are taking pic with it in good lighting condition.
 CH179's gear list:CH179's gear list
Panasonic Lumix DMC-GX1 Olympus E-M5 II Olympus E-M1 II Sony a7C Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +7 more
rashid7
rashid7 Veteran Member • Posts: 7,011
Asir, none of your options are bad ones.  I have the rx100, and it is wonderful for pocket fit, but horrid ergonomics.  and the long lens option (vi&vii) espensive!
All the primes u mention are excellent.  The Sigma is the best, but also large.  Your 14-140 is best for all-purpose one lens
The g85 adds Wx resistance, soft shutter, excellent IBIS!
The cheapest body = GX85, which gives a small option and nice tiny 12-32.  Comes w/ free 45-150 in usa, which us might sell?
Don't over think it.  Try some out, and if u like one option, lens or body, buy it.  You can't hardly go wrong.  Lenses are 'forever' but bodies more fun.
Keep it fun!
Yar1971 Regular Member • Posts: 410
primes and flash
I would stay with MFT, not going for RX100, as it by itself doesn't solve Your problem . Fast glass, but also a smaller sensor. Go for fast primes and flash.
25/1.7, 30/1.4 are good options, I would add Oly 17/1.8 and maybe Sigma 16/1.4 to the set. Nothing longer (not good indoors), nothing wider (severe body distortions when taking portraits from a close distance). Note, that Sigmas are big & heavy = not good for travel. Oly 17/1.8 and Pana 25/1.7 seem most universal. Pana 20/1.7 is also excellent, but its AF struggles sometimes in low light.
Note yet another thing: Your target for indoor photo are moving people, including children. Very difficult target. Even fast prime may be not enough. There's only one solution -add light indoor by using flash. But not just built in flash straight into the eyes. Use small  & cheap external unit  with posibility to bounce off the ceiling. You don't need anything else.
Quite different story is low light photo of non moving targets. It may be still Your family when... still (for example at the table or posed portraits). Fast prime lens without flash may suffice.
Another case is photographing just interiors (in tourism: historic buildings or shrines/churches, museums etc.). Using flash is here difficult or impossible: too big spaces, flashing is banned or disturbing  to others etc. Tripod can be  troublesome, too.
Here fast primes can do miracles, but there's one problem with Your current set: lack of internal stabilisation (IBIS) in G7 body. Many fast primes in MFT , including all discussed above have no stabilisation. They will suffer at low light, static scenes when paired with camera body without IBIS. Just loosing some of extra capabilities by it. Fortunately, Panasonic currently does some cameras with IBIS, You don't need to go Oly   Mostly some (not all) bodies from GX series. Check carefully when choosing one, because sometimes there're mistakes in specifications at web resources.
In summary, I recommend You the the following path:
0) Keep 14-140; it's excellent travel/multipurpose lens
1) Buy a flash and learn how to use it properly; let it be unit compatible with Pana/Oly/MFT, not "universal" one as You loose TTL function otherwise; beware of old analogue time flashes as some of them may be dangerous to digital camera (too high voltage on foot connections); the cheapest modern Chinesee flash with tilted reflector, dedicated for MFT should be O.K., they are really cheap & good enough; oryginal Pana/Oly units are  prohibitive expensive, completely without sense...
2) Buy a fast prime, from the list discussed above
3) Possibly in future exchange Your camera body for one with IBIS
My own experience account: usually travel with Oly cam + 14-150 zoom and 17/1.8 prime. Added lately 12/2.0 and a small flash unit, unfortunately without bouncing ( try to use home-built large diffuser).
-J.
pattymeboy Contributing Member • Posts: 616
Try the PanLeica 15mm 1.7, Used. This lens is suitable for about 90% of my shooting. It renders colors beautifully and is a very well crafted jewel of a lens. If you look hard enough you should be able to find a nice copy.
Enjoy your new hobby!
 pattymeboy's gear list:pattymeboy's gear list
Pentax MX-1 Ricoh GR Nikon D700 Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 +8 more
motormatic Contributing Member • Posts: 521
Buy one of the 25mm options. You'll get a little over 2 stops more to play with in low light compared to your zoom.
In the days when fixed lens 35mm film cameras did not zoom, the focal length was in the range of 35-50mm, which would be 17-25mm for m43.
shinndigg Veteran Member • Posts: 4,690
I have both the Panasonic...
...25 1.7 and Olympus 45 1.8. Both are great. Though the 45 definitely can be a little tight indoors.
The Panasonic has a very nice contrast to it, the Olympus a little less so.
shinndigg
www.pbase.com/shinndigg
 shinndigg's gear list:shinndigg's gear list
Panasonic Lumix DMC-FZ35 Olympus E-510 Olympus PEN E-PL1 Olympus E-M1 Olympus OM-D E-M10 +9 more
DutchBoy17 Regular Member • Posts: 139
Another vote for the PL15/1.7. I've owned and used m4/3 gear since the original G1, and this remains my absolute favorite m4/3 lens. I've taken almost 14,000 images with mine over the last six years (mostly with the 16Mp GM1/GM5 sensor) and it still operates flawlessly despite leading a fairly hard life. The P25/1.7 is definitely applicable to your needs, has good IQ, and is far cheaper, but the PL15 is a special lens.
 DutchBoy17's gear list:DutchBoy17's gear list
Panasonic Lumix DMC-GM5 Fujifilm X100V Nikon Z50 Fujifilm X-T5 Panasonic Lumix DC-S5II +21 more
spike29 Senior Member • Posts: 2,471
asirvr4 wrote:
Hi,
Yes i bought the PL15mm f1.7 for that reason. Great little lens.
That's a limmited budget. Secondhand can stretch the quality jump.
the G80 is a far better camera then the G7 not in sensor but the use of it and the softer shutter which have much less shuttershock.
Maybe a secondhand 12-32mm f2.8? For first goal? And then saving up for a G90?
(newer sensor and 20Mp instead of 16Mp.)
If your renewed enthousiast about photography is a short one, the set is stil sell able.
If it last you can buy a nice improved body and maybe some lenses from a guy who wants the g9 or what ever is the top then. Or buy new on sale.
The 14-140mm f3.5-5.6 I or newer weatherproof one are optical the same , the first older 14-140mm  if you have that one: a type 2 aka 14-140mm f3.5-5.6 mk1 is a improvement.
thanks,
Asir
knowledge is addictive, every time i get some i want more.....
(If i can remember 1/1000 of everything i learned/read in the past i will be happy as a monky with........)
 spike29's gear list:spike29's gear list
Fujifilm FinePix F70EXR Panasonic Lumix DMC-FZ200 Panasonic G85 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
Emsquared Forum Member • Posts: 69
ISO1600 isn't the worst thing in the world on the 16mp sensor ya know. When kid is asleep the dual IS on 14-140 lets you get away with slow shutters too. Sure you don't want to save the money for a bike or ipad for the kid?
 Emsquared's gear list:Emsquared's gear list
Panasonic Lumix DMC-G3 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +7 more
yep, i have my G80 on max auto 3200 iso and use i-iso to have lower iso when it's not moving. stil a f1.7 is very nice to have around.
