For focus stacking, which is better?
Mark_A
Mark_A Forum Pro • Posts: 16,061
Is it better to fix the camera and rotate the focus ring on the lens?
Or better to have the camera and lens on a plate and move the whole camera and lens while taking the individual images?
Mark_A
A thread of photos from SmartPhones ..
https://www.dpreview.com/forums/post/64212858
Mark_A
OP Mark_A Forum Pro • Posts: 16,061
Re: For focus stacking, which is better?
At the risk of answering my own question, I also might try focus stacking for landscapes for which I expect the only option is to fix the camera and move the focus ring.
Mark_A
mawyatt2002
mawyatt2002 Contributing Member • Posts: 502
It's usually better to keep the camera and lens fixed and change the lens focus for magnifications less than 1X, and fix the focus and move the camera and lens for greater than 1X. Of course there's a big range around 1X that is good either way, and best to just test and see.
The change in perspective is the main issue when stacking is involved.
Best,
Research is like a treasure hunt, you don't know where to look or what you'll find!
~Mike
ken_in_nh Contributing Member • Posts: 900
Rik Littlefield, the author of a great stacking program, Zerene, talks about the choice here: https://www.zerenesystems.com/cms/stacker/docs/troubleshooting/ringversusrail
Short summary: It depends.
I've had great luck using the focus motor for stacking with my 100mm macro.
Mark_A
Hi Mike thanks for responding.
So if I am shooting a landscape which will be a lot smaller than 1x I can use the focus ring, and if I am shooting an insect with a macro lens where I am likely to be more than 1x I should use focussing rails?
About change in perspective, I don't fully understand that, but I am aware that each method changes the image a bit and probably differently.
Mark_A
Mark_A
Hi Ken,
Thanks for your response. The link is interesting and I had heard of Zerene.
It does seem like it depends.
Well that is OK, at the moment I don't have any software to stack with, I will probably buy Affinity Photo soon and that will enable me to have a go.  I have seen some very nice photos recently achieved with focus stacking so I do want at some point to have a go.
Mark_A
mawyatt2002
Mark_A
Mark,
Check Zerene as Ken mentioned. I use this for stacking, excellent special purpose tool.
Best,
~Mike
Bill Janes Senior Member • Posts: 1,924
Re: Perspective vs Focal Length
+1
Changes in perspective are lessened when one uses a longer focal length macro lens. If possible, I prefer to stack with my 180 mm macro, rather than my 105 and 60 mm lenses. For a given magnification, the depth of field over the subject is the same but the 180 will blur the background more.
Bill Janes
