Olympus 100-400mm F5-6.3 vs Olympus PRO 40-150mm F2.8 + teleconverter
Started Aug 7, 2020 | Discussions
valerio18 New Member • Posts: 3
Hi,
I am Olympus casual shooter that would like to have telephoto lens with more reach (the longest lens I have now is 14-150 F4-F5.6). I am considering between the 2 lenses (100-400 vs 40-150+TC). Do you think which option can deliver "better" image/AF/etc.?
Cheers!
Funny Valentine
Funny Valentine Senior Member • Posts: 1,392
Re: Olympus 100-400mm F5-6.3 vs Olympus PRO 40-150mm F2.8 + teleconverter
6
Honestly I would stay away from the 100-400, it has an outdated IS unit and is too big. But I highly recommend the 40-150 f/2.8 pro because it's cheaper, brighter, has better built quality and can also do telemacro. If you want more reach you can buy an extender, 1,4X or 2,0X, or buy an additional 75-300 for the supertelephoto. I always recommend the 75-300 because it's cheap, gives very good sharpness at close distance even at 300mm. It falls apart at 300mm when shooting distant subjects, but this also holds true for the 100-400.
 Funny Valentine's gear list:Funny Valentine's gear list
Olympus E-M1 II Canon 6D Mark II Canon EF 50mm F1.4 USM Canon EF 100mm f/2.8 Macro USM Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +2 more
Henry Falkner
Henry Falkner Forum Pro • Posts: 15,901
valerio18 wrote:
Hi,
Cheers!
150 + x2 TC only gives you 300mm, and you lose 2 stops or more in the TC.
Plus - changing lenses from 14-150 to 40-150 + TC needs removing one lens, and attaching two lenses. That is alright if you don't really take photographs, but enjoy making an exhibition of yourself changing lenses. I have seen tourists changing lenses and never taking a photo.
If the 100-400 is just outside your budget, consider the 75-300 II. It has good reviews here.
When I do get my tax return, I may go for the 75-300 , and put off the new E-M10 IV for later. The lens is about US$ 500.-.
Henry
Henry Falkner - E-M10 Mark II, SH-1, SH-50, SP-570UZ
http://www.pbase.com/hfalkner
 Henry Falkner's gear list:Henry Falkner's gear list
Olympus SP-570 UZ Olympus SH-50 Olympus Stylus SH-1 Olympus OM-D E-M10 II Olympus OM-D E-M10 IV +1 more
Henry Richardson Forum Pro • Posts: 21,959
Olympus 75-300mm f4.8-6.7 II
7
I suggest you consider the excellent Olympus 75-300mm f4.8-6.7 II also. Smaller, lighter, and less expensive, but very good quality. I also have the Olympus 14-150mm and they are a nice pair for times you want something much longer.
Henry Richardson
http://www.bakubo.com
Skeeterbytes Forum Pro • Posts: 23,182
valerio18 wrote:
Hi,
Cheers!
If you replace the 14-150 with the 40-150 Pro (and backfill the <40mm range with another lens) then you will have a major upgrade to the system's best mid-tele. The Pro zoom is quite good with the MC20 but I don't wish to claim it's as good as the two 400mm zooms at the longer focal lengths. Pretty good though, in my experience. If your emphasis is adding the 150-400 range to your kit while keeping the 14-150, then the Pro zoom might not be the path. But if you were to swap the zoom for the 14-150 then you'll end up ahead.
Good luck!
Rick
bbbbbbbbbbb Senior Member • Posts: 2,239
Re: Olympus 75-300mm f4.8-6.7 II
Unless you really need the 400mm reach, I'd be wary.  The 100-400mm is slightly lighter than the 300mm f4 PRO which I have.  I can tell you, first of all, finding a small bird at a distance, then holding the lens steady long enough for a good shot as it hops around is quite a feat despite dual IS.  Perhaps I should join a gym.  At 400mm it would be harder.  Then there is the issue of light.  Despite having 4f, there is never enough light and at 400mm you have only f6.3.  I would find it quite difficult to get keepers.  On the other hand the 75-300mm weighs less than half.
 bbbbbbbbbbb's gear list:bbbbbbbbbbb's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus E-450 +8 more
Jouko Senior Member • Posts: 1,985
6
Think about if you need the 40-100mm more than the 300-400mm range.
I have the 40-150mm F2.8 and both tele converters. The image quality 40-150 x2 is good, but I don't know if  it is better or worse than the 100-400mm at 300mm - I think only Oly has that knowledge right now. Maybe the 100-400 is better in the long end.
i have used that combo mostly for semi macro work so far, so the results are from close focus distances. With 1.4x I took some bird shots - no problem.
I changed the older 75-300mm lens for this combo to get a faster lens (F2.8 up to 150mm) and a reasonable light setup for hikes and travel. The IQ from 75-300 is quite good, but there is real difference between that and the 40-150, at least alone.
The 300mm is fine for larger animals, but with small birds it's a bit short - a 400mm would be better,  even 6.3. Remember, it's just 1/3 stop slower than F5.6... Not a big deal. The F-stop difference between 75-300mm (F6.7) and 40-150mm x2 (f5.6) is about the same. The 40-150 x 2 focuses faster than the 75-300.
However, if your main interest is travel photography, the 75-300 is hard to beat. It's so light and small that it fits to every bag.
I do think about getting the 100-400 for nature (birds)... But I'm not in a hurry...
Cheers!
Jouko
'The best camera in the world is the one you have with you when you need it'
https://www.instagram.com/jouko.k.lehto/
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
https://joukolehto.blogspot.fi/ - Lenses for mFT-cameras
https://joukolehto.blogspot.fi/2015/12/what-to-dowith-camera-during-winter.html
Olyinaz Veteran Member • Posts: 8,283
I've shot extensively with the Canon 100-400mm and Sigma 150-600mm on my EM1 and I can tell you that there just is no replacement for a true long telephoto, and the 400-600mm range is exactly where Olympus has been short...and exactly what you often want.  The new Olympus 100-400 is a bit smaller, but importantly quite a bit lighter than the Canon so it will handle just fine for anyone who's shot with the larger Zuiko telephoto zooms.  I'm hopeful that with native autofocus (vs. the adapted autofocus I've been using) it will be both faster and more reliable.
The 40-150 is such a good lens it's hard not to recommend it, and on the 1.4x TC it will still be really good.  If that's enough reach for you then this is a very good option.  Quite a bit less reach though.
Oly
 Olyinaz's gear list:Olyinaz's gear list
Olympus E-M1 II Canon EOS 77D Canon EF 100mm F2.8L Macro IS USM Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital ED 8mm 1:3.5 Fisheye +12 more
OP valerio18 New Member • Posts: 3
Thanks for the suggestions/comments!
Additional questions about the oly 75-300, I know that it can be a good alternative.. can it produce a good enough image? (at least on the level of oly 14-150 is sufficient for me)
I tried to find some reviews online but I can't find a lot about it😅
EM1Peter Junior Member • Posts: 25
I have both the 75 - 300 mkii and the 40 - 150 pro lens with the EM1 mk ii
I bought the 75 - 300 lens when going on holiday with very restricted hand baggage.  Every gm was important.  I got it second hand for a very good price.
I did miss the gap between 40mm and 75 mm but the 12 - 40 pro did a pretty good job when using a  cropped image.
I've found the 40 - 150 plus the x 2 teleconverter a bit sharper, slightly better on focus and subjectively better colour clarity but all marginal.
The low weight of the 75 - 300 is a bonus not to be under estimated.
gary0319
gary0319 Forum Pro • Posts: 10,540
I have been considering adding the 75-300 for a lighter telephoto than my Pan Leica 100-400, particularly for my E-M5 III.
I have a friend that recently added Ike 75-300 an he also has the 14-150 (as do I). I asked the same question, “is it as good as the 14-150?”.... his answer, “exactly”. He also shoots with the 300 f/4 so he knows what good image quality is.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
Jan Krux Contributing Member • Posts: 576
valerio18 wrote:
Hi,
Cheers!
Hi,
I do have the 14-150mm which I take as a light "travel lens" for occasional shots and flexibility.
I do otherwise use my 12-40mm F2.8 and the 40-150mm F2.8 + MC-14. The 40-150mm F2.8+ converter is my "wildlife lens" so far, and I did consider the MC-20 for longer reach (300mm instead of 210mm )  or I was waiting for the 100-400mm lens.
The 2.8 40-150mm is a PRO lens and is considerately bigger and heavier than the 14-150mm F4.0-5.6. They are 2 completely different leagues !
When you want to go seriously into wildlife or (motor) sports, then the 100-400mm will be the route I think. For anything else the 40-150mm F2.8 is a very good and versatile beast, which I love, and my E-M1MkII is glued with it.
For me, the 14-150mm F4.0-5.6 and the 40-150mm F2.8 with or without MC-xx are so different, that it will not be the question the one or the other, but rather if you want or need to go for the additional serious super tele , either the 40-150mm F2.8 or the 100-400mm F5.0-6.3 ..
I want definitively  the 100-400mm F5.0-6.3  for birding and wildlife, but I also will keep the 40-150mm F2.8 for shots with less light and for normal walks I also will keep the 14-150mm F4.0-5.6.
Jan
 Jan Krux's gear list:Jan Krux's gear list
Olympus 100-400mm F5.0-6.3 IS Olympus E-1 Olympus E-5 Olympus E-M1 II Olympus E-M1 III +5 more
Funny Valentine
I personally find the quality of the olmypus 75-300 II at 300mm to be really good; here some example of shots at 300mm that I shot since I bought this lens.
full moon at 300mm.
frog at 300mm, acceptable detail and sharpness.
270mm at ISO 3200, feather detail is still acceptable in my option.
Memoochi
Memoochi Regular Member • Posts: 168
valerio18 wrote:
Hi,
Cheers!
I just looked at the same.  I had hoped the 100-400 would be a designed-for-MFT lens, but am disappointed in what Olympus brought to market.  So, I picked up an MC20 for my 40-150.  The way I see it is, I now have a 40-150 F2.8, and a 150-300 F5.6.
Of course the 40-150 is not stabilized, and I have been struggling to get a good focus lock with MC20 on.  However, I think this is just a learning curve.
If by chance you live close to Munich, you are welcome to try my combo out.  If not, try borrow before you buy.
Would suggest you also take a look at the 50-200 from Panasonic.
 Memoochi's gear list:Memoochi's gear list
Nikon D90 Olympus E-M1 II Nikon AF-S Nikkor 50mm F1.4G Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro +4 more
Svein Eriksen Senior Member • Posts: 2,426
Olyinaz wrote:
I've shot extensively with the Canon 100-400mm and Sigma 150-600mm on my EM1 and I can tell you that there just is no replacement for a true long telephoto, ......
Very true, if you need 400mm then 300mm, or even worse 150 with 2x TC to get to 300mm wont be enough. Btw, I've nothing against using a TC, but it's no substitute for a lens with the reach you want.
75-300 or Panasonic 100-300 are both pretty good lenses (but consumer grade lenses) so if you regularly need 300mm then get one of those. Same if you really need 400, then a 100-400 is the best option.
DLBlack Forum Pro • Posts: 15,865
I own the 40-150/2.8 and the MC20. I use to own the original version of the 75-300/5.6-6.7. The image quality is better with the 40-150/2.8 + MC20. Plus it is f5.6 so better in lower light. Plus without the MC20 the straight 40-150/2.8 is maybe the best zoom lens image quality that Olympus makes.
The 75-300 is lighter and more compact if this is important thing.
I got the new 100-400/5.0-6.3 on order. I hope it will pair up with the 12-100/4.0 to give me a good general kit. I do find only going to 300mm to be a limitation for what I like to photograph.
 DLBlack's gear list:DLBlack's gear list
Pentax K-7 Pentax K-5 Olympus E-M5 II Olympus PEN-F Olympus E-M1 II +46 more
Auf Reisen Contributing Member • Posts: 854
6
Yes, it is about on par with the 14-150. It is also much better in the 75-200 range than it is in the 200-300 range. It is also much better for close subjects.
That said, I have often been frustrated with the lens. It can produce good pictures if you are reasonably close, but it is not great at the long end for far-away subjects. And it is very hard for amateurs to get pleasing results with the lens because telephoto technique is tricky. Especially with such a light lens.
Here is what you can expect for close subjects:
OOC Jpeg
There is enough detail there and some room for working the files in post, but it is not on par with what I have seen coming out of the more expensive lenses. Also do keep in mind that this is about a 1-in-200 shot for an amateur of my skill level. You can get better ones in better light and with better framing (and I have), but I wanted to give you a somewhat realistic expectation.
But for every acceptable shot like the one above, I get about a 100 of these:
OOC
I have tried everything in situations like this. Tripod, monopod, handheld. Shutter speeds from 1/50 to 1/2000. Autofocus, manual focus. It doesn't matter. I even magnified to 8x while on a tripod while dialing in manual focus. People keep telling me this is a focusing issue, it is not. So in tricky situations like this, where you are a tad too far away and where you have a distracting background and some heat haze/air distortions over water, forget it.
gary0319
75-300 refurbished for $359
Olympus has added the 75-300 to their US Outlet for $359. I applied the $50 end of rewards one time coupon for a net price of $309.... hard to pass up.
This will be an adjunct to my E-M5 III/12-45 f/4 for a lightweight 2 lens travel kit (if we ever get to travel again).
Re: 75-300 refurbished for $359
Great price for the lens and should pair up nicely with the 12-45/4.0.  I am looking forward to the 40-150/4.0 that is shown on the lens road map to pair up with the 12-45/4.0 for my small kit with Pen F.  I did order the new 100-400/5.0-6.3 to pair up with the 12-100/4.0 and the E-M1.3 for my general/casual kit.
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
the 75-300 mk2 is a superb value for money lens which I have produced many excellent images from but for my use its shortcoming are
- no IS
- too short
-not water sealed
Which is why I went to the PL100-400 (after experimenting with the sigma 150-600C via metabones)
The zoom problems + hood failure + poor / non-existent customer service (I believe it is now better?) resulted in that being ditched
So, for me the 100-400 meets my specific need, whoever designed it and the fact it is "plastic on metal" construction is irrelevant (my judgements should in no way influence anyone else) each to there own choice
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
