7i Getting A Little Better
Started Aug 6, 2020 | Photos
Hike Pics
Hike Pics Senior Member • Posts: 2,917
Thanks to neilt3, the camera is on the last firmware update available. I think this has had a little positive effect on it. Also, since many times the camera would lock up while writing to the CF card (and the card could get very warm) I decided to drop the resolution down to "Fine" and see what happens. Two days ago I got 30 images taken and the camera only locked up 3 times. Today I took about 40 images and the camera locked up about 5 or 6 times. This is much better than before the firmware update and resolution downsize.
I originally had the resolution set for TIFF and then would make small adjustments in post before converting to JPG. But these images are at the "Fine" setting.
...Wes...
Comment & critique:
Brian Chichester
Brian Chichester Senior Member • Posts: 1,104
Re: 7i Getting A Little Better
I specially like pic no. 3, which I believe is a passionflower. Such delicacy and detail.
Also it's good to see a camera even older than my A200 still going (I think the 7i shares its lens with the A200).
 Brian Chichester's gear list:Brian Chichester's gear list
Olympus XZ-2 iHS Olympus Stylus 1 Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +3 more
neilt3
neilt3 Veteran Member • Posts: 3,008
At least it's sort of working !
Good rich colours on the Hibiscus and the passion flower looks well too .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
neilt3
The DiMage 5 & 7 range and A1/2 & 200 all share the same optics .
Handy if you need to salvage parts off one for another .
GossCTP Veteran Member • Posts: 6,205
Some lovely colors.
"Law and order" is anathema to liberty and justice.
 GossCTP's gear list:GossCTP's gear list
Panasonic Lumix DMC-LX5 Pentax K20D Pentax K-5 II Fujifilm X-H1 Pentax smc FA 50mm F1.4 +8 more
