"f/1.4 and be there"
Started Aug 6, 2020 | Discussions
Barry Pearson
Barry Pearson Veteran Member • Posts: 9,625
20
In 2018 I spent many hours at Westonbirt, The UK's National Arboretum:
https://www.forestryengland.uk/westonbirt-the-national-arboretum
https://en.wikipedia.org/wiki/Westonbirt_Arboretum
I used my Pentax K-1II and Pentax-D FA* 50mm F1.4 lens .
For fun, I used 1/2000th at f/1.4 for all 754 photos.
This is rather like the well-known expression "ƒ/8 and be there".
Strip-out technical complexity and concentrate on what matters; taking the photos.
(At an airshow I typically use f/8 as long as there is sufficient light).
Here are a few of the results; I down-sized the original DNGs to 75%.
 Barry Pearson's gear list:Barry Pearson's gear list
Ricoh GR III Canon EOS R5 Canon EOS R7 Venus Laowa 12mm F2.8 Zero-D Canon RF 70-200mm F2.8L IS USM +28 more
Barry Pearson
OP Barry Pearson Veteran Member • Posts: 9,625
Software processing
As usual, I used Lightroom Classic and Photoshop.
(I subscribe to the full Adobe Creative Cloud suite).
I did most of the processing in Lightroom Classic.
Then little more than down-sizing (to 75%) and sharpening in Photoshop.
(I do final sharpening after down-sizing).
(I don't claim Adobe products are superior to all others; but they are what I use).
Rod Herdman Veteran Member • Posts: 3,494
Re: "f/1.4 and be there"
Beautiful colours.
All I want is a digital back for my trusty K1000 . . .
 Rod Herdman's gear list:Rod Herdman's gear list
Pentax *ist D Pentax smc DA 50-200mm F4-5.6 ED Pentax smc DA 18-55mm F3.5-5.6 AL +12 more
Barry Pearson
Rod Herdman wrote:
Beautiful colours.
Yes.
Unfortunately I can't take credit for that!;-)
Except that I tracked their predictions of autumn colours and got lucky.
chris gunn
chris gunn Veteran Member • Posts: 9,641
Seems genuinely sharp.
A stars pic would tell me something
cheers!
Gunn
-- Get a big lens and get closer™.
 chris gunn's gear list:chris gunn's gear list
Pentax K-1 II
Jozef M Senior Member • Posts: 2,199
Re: Software processing
I think you sharpened too much in the first photo, I see noise and artifacts in the bokeh.
Probably you don't see this in prints.
Jozef.
 Jozef M's gear list:Jozef M's gear list
Sigma DP3 Merrill Canon EOS 30D Panasonic Lumix DC-G9
Joseph Tainter Forum Pro • Posts: 11,494
Nice series. I especially like the first mushroom shot and the berries.
Joe
Barry Pearson
Fair comment!
I did all the processing on my (relatively new) laptop.
I'm finding it tricky to judge the sharpening.
I suspect if you look carefully at the others, you will find similar problems in some others.:-(
(When I'm printing, I sharpen specifically for the purpose, and do some tests).
Barry Pearson
My favourites too!
kriztian Senior Member • Posts: 1,449
It was my reaction to. Very nice pictures but I believe they don´t have to be as sharp as they are. They will look very good anyway. I like the first mushroom pic and the berries best.
kriztian
Tord S Eriksson
Tord S Eriksson Forum Pro • Posts: 17,306
Agree with you. totally!
Excellent mushrooms!
tordseriksson (at) gmail.....
Owner of a handful of Nikon cameras. And a few lenses.
WSSA #456
 Tord S Eriksson's gear list:Tord S Eriksson's gear list
Olympus C-8080 Wide Zoom Ricoh GR Nikon 1 V1 Nikon D600 Nikon D3300 +24 more
M R Padmaraju Veteran Member • Posts: 6,658
Enjoyable , enjoyed . 1.4 is only an extension of yo mind . Though you have said you cannot take credit for the colors , ` beauty is in the eyes of the beholder`.
Regards ,
mrp .
 M R Padmaraju's gear list:M R Padmaraju's gear list
Fujifilm FinePix F40fd Pentax K-01 Pentax K-x Pentax K-500 Pentax K-S1 +8 more
Barry Pearson
Software processing with less sharpening
There is a consensus that I over-sharpened some (perhaps all?) of the photos.
I'm going up a steep learning curve on using my (relatively new) laptop!
Here are a few of them with only the Lightroom sharpening I used before.
No additional Photoshop sharpening; but I have again downsized to 75%.
Comments, including harsh criticism, welcome.
I need to learn how to get this right!
Michael Arbor Regular Member • Posts: 275
Re: Software processing with less sharpening
Fine-tune the image as you have always done, but go light using the Clarity slider, if at all.
Downsize for publication.
After downsizing, examine the image for 'noise' artifacts.
Next, target the 'problem' areas with LR Classic's ADJUSTMENT BRUSH tool, Auto Mask enabled. Make sure areas and edges you wish to remain sharp are NOT included in the resulting mask by fine-tuning the mask with the tool's Erase option. Once you have the refinement area identified to you liking, use the Texture slider & Density slider to address the 'noise' to your satisfaction. (Texture tends to smudge. Density determines how much reads through.) Which setting combination is most pleasing... that's your call.
Works for me might work for you.
Cheers... M
Michael
Be the kind of person chance finds easy to help.
"No one cares how hard you worked." Bob Nadler, Camera 35 (1975)
Barry Pearson
Cheers... M
Thanks! Very helpful.
I've allowed myself to get a bit out of touch with some of the more advanced features if Lightroom.
I've bookmarked your post. I'll probably start by not using clarity.
Then play around with your other options.
I have found that it is almost impossible to sharpen a picture without getting artefacts to some degree. I have moved away from that and I try to use the contrast and color instead to get a better effect on separating the colors and make the main subject to stand out. I think it maybe can be a good idea to sharpen when one is printing but well lit screens will almost always reveal the sharpening artefacts.
kriztian
drummercam Senior Member • Posts: 1,964
The first one of the tree is a surprisingly effective f1.4 shot.  Really nice color palette, too.
 drummercam's gear list:drummercam's gear list
Leica Q Ricoh GR Digital III Pentax K-01 Pentax K-3 Pentax K-S2 +11 more
Terry K1
Terry K1 Senior Member • Posts: 1,616
Really nice.
 Terry K1's gear list:Terry K1's gear list
Sony FE 50mm F1.2 GM Sony a7R IV Sony FE 24mm F1.4 GM Sony FE 135mm F1.8 GM Sony FE 35mm F1.4 GM +5 more
Barry Pearson
Terry K1 wrote:
Really nice.
Thanks!
With all the debate in this forum about what the future APSC flagship may be like:
We can at least share appreciation about what the current Pentax K-1II and current Pentax DFA* 50mm f/1.4 can do!
Death89
Death89 Forum Member • Posts: 67
Excellent job, now I want one...
Seriously, lovely photos, especially the mushrooms! Love those ones.
 Death89's gear list:Death89's gear list
Sony RX100 Panasonic Lumix DMC-FX150 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX1 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +3 more
