Backing up photos from MacBook to external hard drive
Started 2 months ago | Questions
Pannylumixfan Forum Member • Posts: 61
Hi,
This is probably a very silly question, but could anyone please explain how I can back up the photos on my MacBook Air (2020 version) to an external hard drive? I have searched online for several days and just cannot find an explanation that I can make sense of. This is my first Apple device after using Microsoft computers for 20 years and so I am still getting used to the new operating system.
Than you in anticipation for any replies I might receive.
Best wishes, Brian
JustUs7 Contributing Member • Posts: 886
Re: Backing up photos from MacBook to external hard drive
The Mac forum would be the place for this question.
I generally copy and paste in Finder, or use the photo uploader tool to move things to our external NAS. Some people use Time Machine (a Mac app).
We stopped using the Photos app for importing pictures from SD cards. I find Apples method of uploading to be difficult to unwind when trying to access with different software. I use Canons EOS utility to upload and build out folders by date using standard naming conventions.
 JustUs7's gear list:JustUs7's gear list
Canon EOS RP Canon EOS Rebel SL1 Canon EOS 1000D Canon RF 24-240mm F4-6.3 Canon RF 35mm F1.8 IS STM Macro +3 more
mdmarqphoto Contributing Member • Posts: 829
For a simple method, I'd do it the same way I would do it in Windows:  Mount external drive, drag desired photo folders from internal drive to external drive.
 mdmarqphoto's gear list:mdmarqphoto's gear list
Casio Exilim EX-ZR800 Canon EOS 90D Canon EOS M Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Canon EF-S 18-55mm f/3.5-5.6 IS STM +4 more
OP Pannylumixfan Forum Member • Posts: 61
Unfortunately I’ve got several thousand photos to transfer. Would I be able to drag a folder containing all of them? Thanks.
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 18,164
Pannylumixfan wrote:
Hi,
Best wishes, Brian
Well, the easiest thing is to back up your whole hard drive using Time Machine, which is Apple's built-in backup utility. Just get an external hard drive that connects to your Thunderbolt port and open Time Machine. It pretty much leads you through the process.
Then, left to its own devices, Time Machine will back up your Mac every hour, adding any new or changed files to the backup disc.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony RX100 III Nikon D300 Nikon D750 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED +12 more
Of course, as long as you have enough room on your target drive.
Mark Scott Abeln
Mark Scott Abeln Forum Pro • Posts: 15,700
Thunderbolt 3 hard drive
Get a hard drive with either a USB C or a Thunderbolt 3 connector. These are rather rare, but it will avoid you having to buy an adaptor.
Plug it into your computer, and go into the Mac’s Settings; then go the the Time Machine settings and tell it to use the new drive for backups.
The advantage of Time Machine is that it can fully restore your computer in case of system drive failure, and it is software found in every Mac.
This is an extremely basic setup for backup.
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF Nikkor 50mm f/1.8D Nikon AF-S DX Nikkor 35mm F1.8G +2 more
Thanks for all your replies. I shall give your suggestions a try.
CptAmerica
CptAmerica Senior Member • Posts: 1,046
This is my first Apple device....
Sad day.
 CptAmerica's gear list:CptAmerica's gear list
Nikon D850 Sigma 105mm F1.4 DG HSM Art Nikon D4 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 85mm f/1.4D +6 more
robgendreau Veteran Member • Posts: 7,468
BTW, I wouldn't bother with using Thunderbolt for backup. Time Machine doesn't need fast transfer speed.
A big USB 3 drive with a USB-C connector should work fine. Don't format it APFS. https://support.apple.com/en-us/HT201250
Let it back up everything. You NEED to have at LEAST one backup, preferably another one off site as well.
BrownieVet Senior Member • Posts: 2,932
Have been Transferring File between MBP & External Drives Regularly
RE: Backing up photos from MacBook to external hard drive
I own a 2019 MacBookPro constructed like a MacBook Air, equipped with two USB Thunderbolt ports, NO SD card reader and NO USB-3.0 socket.
I also own a 2009 MacBookPro equipped with DVD drive, two USB-2 ports, Firewire but NO USB Thunderbolt port. Connecting the External Drive to the 2009 USB port allows file transfer between the MacBookPro and External Drive.
Assuming your external hard-drive is USB-2 or USB-3, it cannot be connected directly to your MacBookAir UNLESS you use an Adapter (USB-3 to USB-Thunderbolt). My adapter is shown in the attached photos.
I purchased from Amazon for $30.00 in Dec 2019 - - - just Google "USB C Hub, 6 in 1 Type C Hub Adapter, MacBook Pro 2020"
Verify the USB-C (Thunderbolt) ports of your MacBookAir
You can use drag & drop to transfer files selectively or by entire folder or any of the methods you use in Windows. You can also transfer photo from SD cards, Thumb drives or between two external hard drives. I use one of the USB-3 port for hand-held mouse.
Good luck
henrya41 Regular Member • Posts: 287
Time Machine might be a good solution to back up your other files, programs, and preferences, but I wouldn't recommend it as the primary backup system for your images. Time Machine works as a backup but not well as an archive. For example, if you accidentally delete a file or lose your computer it is easy to recover what was recently on it. Time Machine is not for long term storage and access of files (IE finding an image from 5 years prior).
At the most basic level, you can drag and drop a folder (or multiple folders) onto an external hard drive, just like you would on a PC.
Most external hard drives will work on a Mac, although they may need to be re-formatted using the Disk Utility program.  Note: if you're reformatting a drive you will lose any data on it.   If you'll be using both PC and Mac you can format as exFAT .
Caveat on Using Time Machine
I have been using Time Machine since 2009.
Issues I discovered and verified by the Geniuses at Apple Store:
1.  Time Machine Back-up created on  different versions of Apple OS are NOT COMPATIBLE.
Remedy:  Manually back-up files on DVD or External Drives.
. . . Note the source directory drive to enable proper installation of recovered files.
2.  Files from Time Machine canNOT be accessed (read and recovered) by Windows OS.
My OBSERVATION / Experience:
Every hard drive I purchased that is marked "For Apple and Windows" worked on Apple and Windows.  Document and photographs I transferred from an Apple computer are accessible, can be read on a Windows computer.  Unless "write protected" the files can be edited on either Operating Systems.  The converse is true for Windows to Apple files.
I refrain from FORMATTING any memory cards, thumb drives, hard drives . . . UNLESS I want to WIPE CLEAN any trace of files.  Rather than formatting, I just erase the unwanted files.
As already posted by others EX-FAT make the HD accessible to both Apple and Windows.
IF I MUST format,  I use the FULL FORMAT instead of a QUICK FORMAT.
