Wrong file creation date?
Started 7 months ago | Discussions
georg f Forum Member • Posts: 54
i have a very strange problem on my A7s: the camera is set to the correct date, 5th august 2020, the exif data shows that date too, but the file creation date is one month later, 5th september 2020. is there a setting fot shifting the file creation date?
tried a different card, same issue.
system is ubuntu 20.04 (but that shouldn't matter actually).
www.georgfiedler.at
 georg f's gear list:georg f's gear list
Ricoh GR II Sony a7S +10 more
Sony a7S
arneh Regular Member • Posts: 160
Re: Wrong file creation date?
I just noticed the same problem with my camera (an a7R3). It used to have the correct file dates, but now it shows one month into the future.
I haven't found a solution yet, the date is correct in the camera.
 arneh's gear list:arneh's gear list
Sony RX100 IV Sony a7R III Samyang 8mm F2.8 UMC Fisheye Sony FE 16-35mm F2.8 Sigma 70mm F2.8 DG Macro Art +5 more
leiterweiter New Member • Posts: 2
OK, I solved it after reading the thread again:
in fact it IS related to ubuntu20.04!
see https://patrick-nagel.net/blog/archives/664
I have the same problem with sony alpha 7 III.
Have you been able to solve it?
OP georg f Forum Member • Posts: 54
yessss!!!! big thank you!!
installing exfat-fuse exfat-utils did indeed solve the problem!
www.georgfiedler.at
