Re: F11 lens with 2x TC = F22?
zonoskar wrote:
I know that the 2x TC you lose half the light: your equivalent lens aperture becomes 2x higher, so in case of the new RF tele lenses, you get F22 light gathering. But does that still hold for images quality due to diffraction? The physical aperture is still the same size.
There's a lot of misunderstanding on this topic.
"Losing light" is a concept that was born in a world of cameras without TTL meters. If you metered externally, or judged by the weather, you would need to account for the loss of *EXPOSURE* to get the correct exposure for your film, if you added a TC, a filter, or extension tubes, as the f-number indicated on your lens would not be correct for exposure. In that sense, there was a loss that you needed to account for.
With TTL metering, you don't have to think about that (except with non-circular polarizers), and now, with the actual imaging sensor as the meter, you never have to account for anything.
In the situations in which one adds a TC to the system or uses a longer lens with the same physical aperture size as an alternative to cropping, from the same subject distance, you don't lose anything, because you would have LOST IT IN THE CROP, ANYWAY. Yes, not using the entire frame is also "losing light". People often deceive themselves about IQ based on 100% pixel views or full image frames resized to their monitor, when in fact, they can not use the entire image. When people say that they get better results cropping from a shorter focal length with a lower f-number, at a lower ISO, they are probably wrong, and are judging by full image qualities as seen on screen, or 100% pixel views. They really need to magnify based on the actual crop to be used; not the entire frame. IOW, if you stand at the same distance from the subject and shoot it at 1600/22, 800/11, and 400/5.6, for example, you should open 3 windows on your monitor, and look at the 800 at twice the magnification as the 400, and the 1600, at 4x the magnification of the 400. These "cropped" options usually fall on their faces (especially if the shutter speed is sufficient for the 1600), compared to the 1600, even if none are spectacular at higher magnifications.
When we get into focal-length-limited photography, where we are likely cropping most of the time, it makes no practical sense to worry about absolute exposure, f-numbers, and ISOs as dictating final cropped image quality.
Diffraction, noise, and background blur, all considered with a normalized subject size, from a given distance or perspective, come basically from the size of your entrance pupil, which is the same for a 200/2.8, 400/5.6, 800/11, or 1600/22. It is the 71mm that matters in this paradigm; not the f-number, or f-number-derived diffraction and DOF, and not the ISO. The focal length, combined with the pixel density, determines how well the underlying analog image (which is basically the same) is resolved.
