Sony RX100V with Sony underwater housing
Started Aug 5, 2020 | Questions
asteros New Member • Posts: 3
New to underwater photography. When using the Sony RX100V in the MPK-URX100A housing, then the control wheel cannot be used (due to housing design). Normally this is OK, but when I'm shooting in Manual mode, then I cannot change the shutter speed.
Sony's website has this comment regarding this issue (http://support.d-imaging.sony.co.jp/www/support/acc/housing/mpk-urx100a/en.html?id=pdt): “Control wheel cannot be operated after installing the camera in the housing.” But does anyone has a better solution? Thanks
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Re: Sony RX100V with Sony underwater housing
Nauticam housing?
Phoenix Arizona Craig
www.cjcphoto.net
"In theory, practice and theory are the same. In practice, they're not."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Barmaglot_07 Contributing Member • Posts: 633
Switch the camera to shutter priority, use lens ring to set shutter speed, switch back to manual mode. Alternatively, use Ikelite, SeaFrogs Salted Line or Nauticam housing.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
