Tamron 100-400mm f5.6-8.3 MFT, where are you ?
DeepSilence
DeepSilence Regular Member • Posts: 135
The new Olympus 100-400mm f5-6.3 lens is not the smallest one. It is probably a full frame lens adapted to the m43 mount. Some time ago Tamron published a patent for the 100-400mm f5.6-8.3 lens, which should be much smaller:
https://www.43rumors.com/tamron-published-a-new-100-400mm-f-5-6-8-3-mft-lens-patent/
 DeepSilence's gear list:DeepSilence's gear list
Olympus OM-D E-M10 Olympus E-M5 II Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Panasonic 20mm F1.7 II +3 more
JakeJY Senior Member • Posts: 4,839
Re: Tamron 100-400mm f5.6-8.3 MFT, where are you ?
I don't think they will try as it would likely be another mistake like their 14-150mm where Panasonic and Olympus already had similar options, making their offering not stand out.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +5 more
Astrotripper Veteran Member • Posts: 8,281
Yep, pretty much.
However, this at least could have differentiate itself by being really small, light and affordable. I can see the appeal of that.
Their 14-150 had none of that potential. It offered the same thing but had none of the unique features of Panasonic (OIS) or Olympus (WR) and at least at launch it was not even that much cheaper. Eventually they just dumped them into a bargain bin.
I never understood why Tamron though it would be a good idea to do that 14-150. Smells like old-school DSLR era thinking of "We're gonna do the same as first party makers, but slightly cheaper".
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +14 more
TomFid Veteran Member • Posts: 3,517
Astrotripper wrote:
Yep, pretty much.
Failing that, it has to be really high performance. There's no advantage on speed, and the jury is still out on sharpness, though some samples are very promising. Stabilization looks like a fail, or perhaps just neutral for Oly body users. They might have a leg up on build quality, because the Panasonic has had issues, but it's hard to make hay with that when the value of an Oly warranty is now unknown.
Yeah - they were going up against strong competitors that were already reasonably priced and highly regarded. Hard road.
Gnine Senior Member • Posts: 2,014
I can't recall ever stopping down an m4/3 to f/8 or lower. Maybe by accident, after migrating from FF.
DeepSilence
OP DeepSilence Regular Member • Posts: 135
The difference between f6.3 and f8.3 is less than 1 EV. In good lighting conditions, it won't matter. In worse conditions, even f6.3 may not be enough.
