Panasonic and those usuriously priced telecons
unhappymeal Contributing Member • Posts: 698
I recently offloaded 90% of my m4/3 gear, but kept a few items for shooting wild life. Partly, this is because the Fuji XF 55-200 and XF 100-400 aren't spectacular and partly because I couldn't find a buyer for the PL 50-200.
Right now, I have an E-M1 II, recently repaired GX8 and Panasonic-Leica 50-200. I'm looking to get a bit more reach for wildlife and birds and I'm in a bit of a conundrum. The Panasonic-Leica 100-400 can be had brand new for $1,600 CAD (+ tax). I have my apprehensions about the lens (quality control, dust ingress, not the sharpest and repairability), but the recently announce Olympus 100-400 is $2,100 CAD.
My other option is going with the Panasonic teleconvertors, but wow are they expensive: $700 CAD a piece for the DMW-TC14 and DMC-TC20--a full $300 and $200 more than the Olympus TCs. I can almost purchase the PL 100-400 at that price.
Let's hear it. If it was your money, what would you do?
Edit: Wild card option: put the PL 50-200 up on ebay and grab a used Olympus 40-150 Pro + EC-14 and EC-20 for $2,000 CAD.
Olympus E-M1 Panasonic Lumix DMC-GX8
Wildalaskaken
Wildalaskaken Senior Member • Posts: 1,369
Re: Panasonic and those usuriously priced telecons
Just buy the 100-400 and be done with it. How much you want for the 50-200? Sell the 50-200 here, if you price it right, it will go in a flsh. Fabulous lens, as is the 100-400.
 Wildalaskaken's gear list:Wildalaskaken's gear list
Panasonic G85 Panasonic Lumix DC-G9 Panasonic 12-60mm F3.5-5.6 OIS Panasonic 45-200mm F4-5.6 II Panasonic Leica DG 50-200mm F2.8-4 +1 more
OP unhappymeal Contributing Member • Posts: 698
I had the PL 50-200 listed at $1,500 CAD and literally only had one person interested. I agree, it is a fantastic lens.
Eric Nepean
Eric Nepean Veteran Member • Posts: 5,477
Where do you find that?
If you can get it for that price, grab one.
The PL50-200 is F4 at 200m, with a 2x TC it is F8 at 400mm, that's fairly dark except in broad daylight.
If you sell the PL 50-200, you have no real need for the GX8. Sell it too, and reduce the number of GUIs and menu systems you have by one.
El-cheapo option: Buy a used Four Thirds 50-200 SWD with used 1.4xTC and 2xTC, for use on the E-M1.2. I used mine on the E-M1.1.
I started with the used Four Thirds 50-200 SWD with used 1.4xTC and 2xTC, eventually purchased the Panny 100-400. I might have been better off with the Panasonic 100-300mkII.
Cheers
Eric
(Any image that I post in a DPR forum may be editted and posted in a DPR forum)
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +57 more
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 4,094
tele
while the teleconverters would make better unhappymeal toys, I would probably lean towards a zoom lens for wildlife.
good luck.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic Lumix DMC-G7 Panasonic G85 +1 more
Panasonic partner/preferred pricing is $1,600 CAD. I had the 100-300 II before and was less than thrilled with it. I did play with the PL 100-400 in store and the zoom ring seemed to be smooth enough (it's a bit tight as you get near 400 mm). It would seem they have addressed majority of the quality issues, which is nice.
jalywol
jalywol Forum Pro • Posts: 10,437
Wait til one of the TCs comes up on Ebay.  I just bought the 1.4x TC for $329 (USD) from a seller on the west coast.  It was new, works perfectly.
After having owned the PL 100-400mm and now the PL 50-200mm with both the 1.4x and 2.0x TCs, here's my take:
The PL 100-400mm is going to be a bit faster and a bit sharper out at 400mm than the 50-200mm with the 2.0x TC.  The 50-200mm with the 2.0 TC at f8 has noticeable halation and is not as sharp as the 100-400mm at f6.3.  However, if you stop the 50-200mm with the 2x TC down to f10, it cleans up extremely well.  IF you can live with that slow a lens, then the 2x TC is going to be a relatively economical way to get the kind of distance you are looking for in a nice, small package, without having to spring for the full price of the 100-400mm.
If you get the 1.4x TC, it is sharper wide open than the 2.0x TC, and your maximum aperture will be f 5.6, at 280mm, which is its longest reach (vs 400mm with the 2x TC). IF you can live with 280mm max tele, AND you can find one for $300ish, the 1.4x TC would give you both reach and sharpness, without breaking the bank, and would give you comparable maximum apertures to the PL 100-400mm, for lower light situations.
I like both lenses and I like both TC's with the 50-200.  However, I actually sold my 100-400mm last year to get the funds for some other gear I wanted to work with, not planning to come back to M43 for other than casual shooting.  But, I decided that for long tele, I really missed M43's reach, so this time around, instead of replacing the 100-400mm, I decided to try the PL 50-200 with the 2x TC since Adorama had a package with both for the same price as the PL100-400mm...and I knew I preferred the smaller size of the 50-200 in general, so I thought I'd take a chance with it.
Result?  I have been having an absolute blast with the PL 50-200 and both TCs.  One major advantage?  The minimum focus distance is much shorter with the PL50-200mm and the TCs than the PL 100-400mm, so I don't have to use extension tubes to do flower and butterfly shots, which I would have to on the 100-400mm.
So...my advice?  Keep an eye on Ebay and pick up one of the TCs when someone lists one in your price range.  It will happen, just keep an eye out.  Much cheaper than the 100-400mm...and IQ really is very similar.
-J
Skeeterbytes Forum Pro • Posts: 18,342
I'd lean towards the 40-150 Pro and MC20, presuming you can live with 300mm on the long end. The Pro zoom is brilliant and performance with the MC20 is good. It's also the only constant-aperture lens among your options, and the fastest @150mm.
Good luck!
Rick
Old Timer63
Old Timer63 Veteran Member • Posts: 5,809
5
I have the 40-150 oly pro and the 1.4 & 2 ext.
The lens on it`s own (on my G9) is the most enjoyable lens I have ever owned in 50 years, it rarely lets me down and with it`s close focus ability it is my go to lens for flowers and bees etc. I don`t print big anymore so can crop and the IQ is (IMHO) second to none. With the 1.4 on the IQ is around the same as my PL100-400 at that focal range and it never seems to suffer that annoying hot day heat haze. With the 2x on the IQ does drop a touch but it is still very usable. I have two bodies and the 40-150 pro is on one all the time and the PL12-60 is on the other.
Out of interest I don`t like the supplied hood on the 40-150, I know from others that it might fall apart and to be honest I purchased a metal screw in hood of about 30mm that stays on all the time and have never had any problems with flare and makes the lens a lot more comfortable to  use plus it looks good.
Good luck with your choice but what ever you choose for the reach you require I honestly think that the 40-150 pro should be in every persons kit because it is that good.
Dave
 Old Timer63's gear list:Old Timer63's gear list
Fujifilm X-H1 Panasonic Leica Summilux DG 25mm F1.4 Fujifilm XF 14mm F2.8 R Panasonic Lumix DMC-G7 Fujifilm X-T10 +17 more
Ruairi
Ruairi Senior Member • Posts: 1,092
If it were my money...
I'd sell the Fuji gear and get the 300mm F4 and an MC14.
 Ruairi's gear list:Ruairi's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Olympus E-M1 III Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +14 more
brentbrent Veteran Member • Posts: 4,725
Another wild card option:  a few months ago I bought a new, gray market PL 200, which came with the 1.4x teleconverter, for $1,600 USD.  I'm not sure if I'll ever buy the $700 2x teleconverter, though many here say the 200 works quite well with it.  No doubt you prefer having zoom rather than shuffling teleconverters to move between 200mm, 280mm, and 400mm, but the image quality would be good.
An interim step could be to buy the 2x teleconverter to use with your 50-200.  Down the road you could consider selling that lens and buying the 200 with the 1.4x.
Just a thought.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH +16 more
Re: If it were my money...
Not going to happen. The Fuji X-Pro 2 + f/1.4 and f/2 WR primes gives me something that is impossible to reproduce on m4/3, even if you step up to the f/1.2 primes (I had the 42.5 mm Noct before...been there, done that).
Just a thought.
Yeah, one of the things nagging me in the back of my mind is that the PL 200 comes with the TC. It almost feels like throwing away a TC if I buy it separately because there are a grand total of two lenses in the Panasonic line-up that you can use them with.
Chris DC Regular Member • Posts: 297
Eric:
You've got me thinking now. I have been wondering whether the new Oly 100-400 lens makes senses for me or maybe the Panny 100-400.
I already have my old worn but good oly 50-200 and both teleconverters. I will try these to see if the 100-400 zoom range makes sense for me. I have been using the 150F2 with the 2x TC and it is optically superb and fast but a bit heavy at about two kilos.
so many choices for reach!
CDC
Bobby J Veteran Member • Posts: 5,032
I agree with you Wild Alaskan.  He should forget the TC's and all the other stuff and just get the 100~400.  At the price he mentioned it's the best deal and If he'll learn how to get the most out of the lens, he'll be glad he got it.
From what I've seen, the new Oly is going to be a good lens, but there's so little difference I would go with the one I could get the best price on.  I've zero complaints with my P/L.
BJM
 Bobby J's gear list:Bobby J's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH Olympus 12-100mm F4.0 Olympus E-M1 Olympus E-M1 II +10 more
Gnine Senior Member • Posts: 2,013
My money -keep the 50-200 and supplement it with the 100-300 mk II
I had the 100-300 II and hated it.
How many Oly MFT lenses work with their TCs?  I think the 40-150 and the 300, but I don't know which others (if any).  Your E-M1 II would be sweet with the 300 with Sync IS and 1.4 TC, as someone above suggested.  I've shot with that lens and it's fabulous.
I'm going to the zoo this Friday to shoot with the 200 with and without the 1.4 TC.  It might help me decide whether to seriously think about the 2x TC.
Brent
Only two lenses, but Olympus doesn't bundle it (at least not in Canada). It's why it would feel wasteful for me to buy the Panasonic TC separately if I were to get the 200 f/2.8 afterwards.
JakeJY Senior Member • Posts: 4,839
The newly announced Olympus 100-400mm works with those TCs too:
https://www.dpreview.com/news/1848101989/olympus-100-400mm-f5-6-3-ii-arrives-in-september-for-1500
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +5 more
