Test shot with the M6 Mark II
JWAR1976 Regular Member • Posts: 131
12
So it finally arrived a few hours ago and so I done a quick test shot of the dog with the Viltrox Speedbooster and Tamron 24-70 G2 at F2.  Going to have lots of fun with this.
With Wildlife photography you don’t need to ask the creatures to sign release forms.
 JWAR1976's gear list:JWAR1976's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 50mm F1.4 USM Canon EF 100mm F2.8L Macro IS USM Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +8 more
Canon EOS M6 Panasonic Lumix DMC-G2
AdamT
AdamT Forum Pro • Posts: 60,797
Re: Test shot with the M6 Mark II
Hey Congrats and Enjoy
I`d stick to the Canon M Converter and F2.8 - not sure I`d trust the speedbooster optics in a "Viltrox" - odd green cast and heavy blowout in an image where I`d not expect one though, neither are traits of the M6-II or Ms in general  . cute pup .
Sony RX10 III Nikon D610 Nikon D850 Panasonic Lumix DC-GX9
OP JWAR1976 Regular Member • Posts: 131
Yes completely agree with you there, I have got the M converter as yet but will definitely be buying one.
AdamT
I got mine used for £70 to the door with the tripod mount there are a few kicking about in the various shops (LCE, WEX, MPB etc)
Here`s one
https://www.lcegroup.co.uk/Used/Canon-Mount-Adpater-EF-EOS-M_277762.html
Here`s one
Thanks for that, one of my friends swears by the Meike version which he has got on both his M5 & M6 II, he says it is just as good as the official  Canon one, but at a fraction of the price.
AdamT
5
MY issue with Shonky stuff is that your particular one doesn`t have to be far out in depth or cockeyed much to cause decentering or other issues such as badly made contacts which could damage the connector in the camera etc - you`ve just ploughed a lot into a very nice camera and have good DSLR glass, why risk it for the sake of £30 or so saved on a meike over a used Canon ? -
You could of course get the Meike from Amazon and return it if its out or cockeyed and grab a used canon, I didn`t  bother for £30-£40 diff though even for my humble M100 and just got a used Canon
smartintech New Member • Posts: 9
I use the same combination of cam, speedbooster an lens. And i'm satisfied with it.
I use a color checker as reference in my RAW workflow, so i don't have any issues with the colors.
But in terms of sharpness i would not recommend to use this viltrox with a wide angle lens.
24 mm is ok for me, as the M6 MarkII has a crop factor of 1.6 wich leaves a small margin around the sensor due to the viltrox' 0.71 factor.
For me the biggest concern with this particular adapter is the power consumption.
But i will make a new thread for that.
Edit:
https://www.dpreview.com/forums/post/64263900
PerfectMark Regular Member • Posts: 205
I have the Canon and Meike adapters, the main different I have noticed is the Meike is a bit bigger because it has a tripod mount on it.  But then that is the way I wanted it, the smaller canon adapter for when I am just handholding lenses and the Meike for when I want to put the camera with a heavy lens on a tripod.
 PerfectMark's gear list:PerfectMark's gear list
Canon EOS 600D Canon EOS M6 II Canon EF 50mm F1.4 USM Canon EF-S 18-55mm f/3.5-5.6 Canon EF-M 22mm f/2 STM +5 more
RedFox88 Forum Pro • Posts: 30,027
agree. Poor color and blown highlight on the head. Was there sun on the dog’s head?
