Olympus 100-400mm/5.0-6.3 IS - my review
Started Aug 4, 2020 | Discussions
Astrotripper Veteran Member • Posts: 8,676
Re: That’s not what I am talking about
Raist3d wrote:
Astrotripper wrote:
Raist3d wrote:
Astrotripper wrote:
Raist3d wrote:
Astrotripper wrote:
Raist3d wrote:
Of course under a camera with more minimum closer distance it will appear bigger Duh That’s not what I am talking about
Minimum focus distance is the same for both.
talking about this
”But what surprised me was the difference between the two zooms. If you compared the size of the photographed object to a focal length of 400 mm with the mentioned lenses, then each is different from the same distance. With the Panasonic 100-400, the object is smaller and corresponds roughly to what the 342mm focal length looks like on the Olympus 100-400.”
This is exactly what mirrorlesscomparisons found and illustrated in their article:
Both brands mention 1.3m as the minimum focus distance for these lenses but the magnification is higher on the Olympus
You conveniently left out: ", most likely because focus breathing is more pronounced."
On the Panasonic. About focus breathing, see my response above: https://www.dpreview.com/forums/post/64225930
So at 400 the Panny Leica sure performs with a similar FOV then.
No idea what you're referring to here.
Both have the same FOV at 400mm.
At infinity, which is what the specs state.
Keep in mind, that's not quite I was talking about- at least as described by Petr, but could be the same reason / finding. Seems like an Olympus Len defect here (or "defect").
I really do not see the difference between both described situations apart from the fact that MirrorlessComparison erroneously states which lens has more breathing.
Why were they wrong? How do we know?
Because they provide a description of the test and the resulting photos. There really is no room for any argument here. This is as clear as things can be.
At long end of the zoom and minimum focus distance of 1.3 meters, Panasonic has a shorter focal length than Olympus.
That's it. No more, no less.
Hmm how do we know the Panasonic isn't the correct one? Trying to understand that.
Because Panasonic has smaller magnification (wider FoV) at minimal focus distance. Hence its FL is shorter when compared to Olympus in the same scenario.
Also, there's no "correct" here. Each lens has different focus breathing characteristics. In this case it's easily comparable because both lenses share the same MFD. So this is actually the perfect case for demonstrating this phenomenon. And I am 100% sure that both of those lenses have focus breathing and the only difference is in the extent to which this happens.
I guess you could say that "correct" would be a hypothetical lens that does not focus breathe. I don't think you will find a consumer grade or even pro grade photographic lens like that. Maybe some older manual focus film era designs. I have a legacy 300mm that seems to not focus breathe at all (or very little), but it has ridiculously long minimal focus distance (like 3 or 4 meters). But comparing it to my Panasonic 100-300, the difference is striking.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Tech Head
Tech Head Regular Member • Posts: 225
Panasonic 100-400 stabilization is better
Auf Reisen wrote:
Amazing shots as always, Petr.
Do I understand it correctly that you are saying that this lens is not offering Sync-IS with Olympus bodies? Or that the Sync-IS did not work as well as other lenses? Could that have to do with this being pre-production?
https://www.youtube.com/watch?v=cxXfO1uPVTA
If you look at Gordon Laing's review he compared the OIS of the lens to IBIS at 400mm in video, and the IBIS was clearly better. With the Panasonic lens, this wouldn't be the case. The PL100-400 OIS alone would either match or exceed IBIS at 400mm.
With OIS vs IBIS, OIS tends to be better at longer focal lengths and IBIS tends to be better at shorter focal lengths. Comparing this lens to the PL100-400, the stabilization at the longer end is clearly going to be better with the PL, not only because of the better OIS but because Panasonic's equivalent of sync IS is the Dual IS 2, which the PL100-400 has. The Oly 100-400 apparently doesn't have sync IS.
So, make of it what you will but this is the biggest obvious difference between the lenses.
Happiness is a warm puppy.
Auf Reisen Contributing Member • Posts: 854
It is not about which lens is "correct".
When you shift focus, your lens is "zooming" (i.e. changing "focal length", or better: field of view) because glass elements are moved around to achieve correct focus. This is called "focus breathing". In very expensive cinema lenses, this effect is counteracted by including correction lenses (that also move) so that the FoV stays roughly the same.
The Olympus lens achieves a tighter FoV at minimum focusing distance at 400mm than the Panasonic. This is usually a good thing because you get a higher magnification.
Gnine Senior Member • Posts: 4,108
talking about this
I wouldn't take too much notice of what they say. They tested sharpness between the two lenses using different cameras, one with an AA filter, one without. Not exactly a level playing field
IBIS > OIS
Not my experience, actually.
For EVF stability, I found IBIS on my E-M1 Mark II superior to OIS of PL 100-400. And I have found no advantage to OIS for photos either (I could reliably get 1/20s at 400mm with just IBIS). I tried using its OIS for a while and switched back to IBIS only, as it was giving me more reliable results. There's a clearly visible difference in the way both work, and I simply did not see any advantage to using OIS instead of IBIS.
For video, it was a no-brainer, IBIS wins hands down with Panasonic's OIS. Not even a contest.
Now, the advantage of IBIS did not seem as obvious (for stills) as with my 100-300 II, which I actually measured to be considerably less reliable than IBIS alone.
But it does have OIS+IBIS mode of operation. Not as effective as Sync IS or Dual IS 2 (most likely), but still better than just OIS.
However, looks like Gordon could not have tested that, because that requires firmware update to E-M1 Mark II that he used for testing.
(unknown member) Veteran Member • Posts: 6,392
thanks for including High RES pics Petr...
thanks again for your time and efforts Petr.
i did take a look at Rostislav's images too.
He posted some example images using the mc1.4 and mc20.
IQ appears better than expected for a mid-grade zoom and a 2X teleconverter.
as always,
thank you fellow DPR members for your kind words and encouragement.
(unknown member) Forum Pro • Posts: 11,837
Semantics. This is not a review.
7
As expected some great pictures have been produced by the OP with this lens.
But I would say that the post should be titled "Presentation" rather than "Review", seeing that the OP is connected to Olympus by being a "Visionary."
This post is a social media marketing exploit and not in any way an impartial "review".
Please lets have some honest transparency and have an accurate title.
Tech Head
Re: IBIS > OIS
The bottom line is I've never seen a Panasonic lens with OIS look that bad in video with OIS alone. The biggest contribution of OIS is at the longer focal lengths, from what I've seen, so combining IBIS and OIS is most effective at longer focal lengths.
It seems this lens has a lower grade of OIS than the PL100-400.
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Re: Semantics. This is not a review.
13
On balance I felt it was far superior to what DPreview managed to do!
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
gary0319
gary0319 Forum Pro • Posts: 10,540
6
Absolutely! I would much prefer to have a “presentation “ by someone who is both knowledgeable and accomplished, than a review by someone who is neither.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
bobn2
bobn2 Forum Pro • Posts: 71,955
Are you suggesting that the DP reviewers are not knowledgeable or accomplished?
Is it always wrong
for one to have the hots for
Comrade Kim Yo Jong?
Wu Jiaqiu
Wu Jiaqiu Forum Pro • Posts: 29,319
don't worry the Oly salesteam have provided many videos on youtube about the lens, some with samples to download so you can make your own mind up about the performance of this new release
the computer says no
 Wu Jiaqiu's gear list:Wu Jiaqiu's gear list
Fujifilm FinePix X100 Nikon D2Xs Nikon 1 V1 Nikon 1 J3 Nikon AF-S Nikkor 300mm f/4D ED-IF +3 more
Messier Object Forum Pro • Posts: 12,721
Are you suggesting that they are accomplished Micro FourThirds experts ?
Peter
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
Wu Jiaqiu
Peter
how do you become an expert of something just released?
bobn2
Peter
What's a 'Micro Four Thirds expert'? I would hazard a guess that they have had experience of more micro Four Thirds cameras than most of us, have experience of other cameras too, so that they can contextualise their reviews.
Or are you suggesting that the limitations of micro Four Thirds are such that special expertise is required?
Is it always wrong
Chris 222 Senior Member • Posts: 1,989
Spot on Gary.
The pictures speak for themselves!
As to the Nikon expert you responded to, "exploit" is a French word whose meaning he clearly doesn't understand, so..
"Please lets have some honest transparency and use accurate words"?
LOL.
Or maybe he's just seriously miffed that ANYBODY could possibly produce better shots with a puny MFT system than he never could get with his mighty Nikon?
Either way his post is pretty insulting towards Petr Bambousek IMHO..
9
Peter
Just released ? Hasn’t Micro FourThirds been around for years ?
Unless you’re putting it on an optical test bench, a lens needs to be mounted on a camera - in this case a m43 camera. Expertise with m43 cameras will, in my opinion, help the reviewer evaluate the lens - especially its autofocus capability. And experience with the other m43 lenses will enable the reviewer to better compare the new lens with other m43  models.
unlike many here, I’ve got zero interest in reading about how this or any other m43 product compares with Sony, Nikon, Fuji or Canon products. Got no interest in comparative weight or cost.  I’d much rather read a review from a dedicated, and yes accomplished, Olympus user like Petr Bambousek.  Yes he is connected with Olympus but that doesn’t make him untrustworthy as NCV suggests.
In fact, I just wish that Petr and the other Olympus Visionaries put more time into doing reviews and technical presentations etc and were available for technical Q&A.
Peter
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
spot on Peter, I sometimes think this site should be split into two parts, "tech-heads" and "Photographers"
In past reviews DPR have published test results that have been patently impossible, not even being internally consistent, I don't rate them very highly as reviewers
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
Petr Bambousek
OP Petr Bambousek Regular Member • Posts: 435
29
Well, I would like to avoid to start flame in rather decent discussion. I am just wondering, what you think to be "Olympus visionary" REALLY means? I expect you think Olympus pay to visionaries to say its gear is great. Which is common mistake far from reality.
All my articles are based on my personal experiences and never been changed single word from Olympus guys.
I chose my equipment voluntarily based on my personal preferences and feelings. BUT yes - I love my gear. YES, I dig very deeply to setting to tune up the camera to be perfect in real wildlife photografy life. I'd rather look for a solution than make an infinity complain that that's not good enough for this and that. And finally YES, Olympus like my work and I am honored I am time to time featured in their materials as well as I am priviledged to have some gear in advance to make personal testing before release (feedback from visionaries is important for future fw updates, etc.).
I am confident all my observations reflects my real experiences and are not curved to make the gear better than I really mean. And honestly I really don't understand why people tend to believe more "reviewers" who are not interested particularly to wildlife photography (and very often even to Oly gear) and just recap technical facts with several usually poor pictures. They are not even willing properly set the camera just make sure nothing is good enough for their needs. "Visionary" multi-award wining wildlife photographer with more than 15 years of real field experiences in wild "review" with tens of exapmles confirming what is written based on 3 weeks intensive testing period is less valued one.
This is why I never "review" portrait/wedding/street oriented lenses.
Choice is always on particular person, I always recommend to "try first" before buy. As there are zillion other "reviews" available, I am pretty sure people can do their clear decision if buy or not. Everybody can find lots of my work examples (over 300 to be seen here: https://500px.com/sulasulacom/galleries/olympus), I am not hidden person for rest of the world behind nickname.
Petr
 Petr Bambousek's gear list:Petr Bambousek's gear list
Olympus E-M1 II Olympus E-M1 III Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 8mm F1.8 Fisheye Pro +10 more
6
Peter
hazard a guess ? So you don’t know then
experience handling the latest model for a day so they can post a review, or are you saying that they are working pros who earn a living from them ? Or are they awarded wildlife photographers who use m43 ?
I’ll hazard my own guess and say that they have indeed handled more m43 camera models than I could even name,  but neither of those DPR guys have spent much time using the equipment for any purpose other than to do a review.
Peter
