Panasonic 100-300mm II vs 100-400mm comparison
Started Aug 3, 2020 | Discussions
Squire Photographer
Squire Photographer Junior Member • Posts: 42
Hi ! Newcomer here.
I've researched if such a thread already existed, but only found threads where I would be somewhat off topic. Might as well start this one !
I've had these two lenses for a while now, and now can attest of the differences, especially when it comes to the common features (Dual IS etc.)
I made a video where I add my two cents to all the reviews that are available here and there, because there are things that in my opinion have not been said.
Here is the link : https://www.youtube.com/watch?v=tSILf0l15Cw
If you want the shorter version without visuals, the 100-300mm mkII handles very well, performs very well, and does what you ask, all in a simple yet, rugged and small package. If you are on a budget, it's a very solid option.
The 100-400 has a far better stabilization, allowing for handheld shots at 400mm at insanely slow speeds, the autofocus is much faster and snappier. So yes, both lenses are compatible with Panasonic's dual IS, but there is a great difference of efficacy between the two. The 100-400 will help you getting a higher success rate for quick action-shots, getting a portrait of this shy bird that won't let you get close etc. But there are some design choices that I'm not particularly fond of (zoom lock ring / Weird two-element lens hood).
As for image quality, well, as I say in the video, of course I want to tell you the more expensive takes better pictures. That's why I propose a challenge, 14 pictures at the end, and you tell me if it comes from the 100-300 mkII or the 100-400. I have chosen pictures that I consider both good and bad taken with each lens, to try and lessen my bias.
TL;DR: I'll stick to the 100-400. The added weight and bulkiness isn't a problem for me, when I see all the plus sides.
Your feedbacks are welcome! I hope I'm not breaking any rules by posting a youtube link here.
Kindly,
Squirephotographer
John Carb Forum Member • Posts: 72
Re: Panasonic 100-300mm II vs 100-400mm comparison
I currently have the Olympus 75-300 with an Olympus OmD Em5 iii. I was considering getting the Panasonic 100-400 after Olympus releases their 100-400. I am hoping the prices drop for the Panasonic.  The newer Olympus looks bigger. I do like the size of the Panasonic much better. How do you think the Panasonic 100-400 would be on an Olympus body?  Without dual is?
HRC2016 Veteran Member • Posts: 6,874
You're always going to end up with a better set if you use gear made to be compatible.
Waiting to see how the prices drop is a good strategy, just beware of the Panny's reputation and make sure you can live with the return policy.
The Oly 75-300 is a great lens. I'd wonder if spending money on another lens would be worth it. If your fieldcraft is good the extra FL may not be worth the money.
So many choices!
Satan loves the shadows - and the highlights.
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
Squire Photographer
OP Squire Photographer Junior Member • Posts: 42
That's a very good question ! Unfortunately I am unsure. I'm confident the OIS alone would perform well, but I have no point of comparison with what you have now, that would allow me to tell you "go for it" or "you wouldn't gain much".
After a bit of research, I have not found a way to use only the lens stabilization on my G9, to give an idea of how it would behave on an Olympus body. If someone knows, I'm interested.
That being said, I've used non stabilized lenses (Pana 25mm f1.7 for example) with only my G9's IBIS, and it does help quite a bit I must say.
If I was an Olympus user, in the market for such a telezoom lens, I think I would wait for the Olympus lenses to come out, see the price tags, reviews etc. I am 99% sure there will be comparisons between the Pana 100-400 f4-6.3 and the Olympus 100-400 f5-6.3 when the former comes out. Maybe the Panasonic would drop in price as you hope, I don't know for sure. That would be good news !
Even though I haven't read anything on it (my research wasn't extensive, I admit), I cannot imagine Olympus getting this lens out without Sync IS. It is, after all, the Olympus contender for the Panasonic 100-400.
Thanks for the advice guys.  It is significant $ to spend for not much more reach.  I do love the Oly 75-300 and it performs well with just ibis. The images I am getting are more than sharp for my purposes.  I will probably wait and see.
Squire Photographer
Yes, if your current gear satisfies your demands, then waiting for this release to unfold before purchasing a new lens is most likely the best idea
Barry Twycross Veteran Member • Posts: 4,778
I had to choose between those two, and I've no doubt the 100-400 would have better IQ. However, I'm sure that'd leave it behind most of the time, it's just too big to take casually, you have to have a good reason to lug it along.
So I chose the 100-300ii, and I'm pleasantly surprised just how much I use it. It's become my second most used lens, after my 12-32 (the really really tiny one), because I can always have it with me. It's amazingly compact for what it does, and the IQ is good enough for me.
 Barry Twycross's gear list:Barry Twycross's gear list
Olympus E-PL7 Fujifilm GFX 50R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Fujifilm GF 110mm F2 Venus Laowa 7.5mm F2 MFT +11 more
Squire Photographer
Indeed, that increase in size with the 100-400 is something to consider. I have an obviously photographic bag wiith me, that could be sized down to something less obvious with the 100-300. One could say it defeats the stealthy purpose of the micro 4/3, but I don't particularly care about that.
And as we say, the best camera is the one you always have on you ! That's also true with lenses
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Many users use the PL 100-400 mated to their E-M! or E-M5. From this thread and some others, I'd say the PL 100-400 OIS is superior for long tele range than the camera's IBIS alone. For this reason, most long teles, even from Oly, feature OIS and Dual IS. I wouldn't hold my breath for the PL 100-400's price to drop like a stone when t he Oly 100-400 comes out (bigger, heavier, slower and 30 to 50% more expensive). It is compatible with Oly TCs but how often do you need an 800 mm (1600 mm eq.) F12 lens ?
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
darrinlingle
darrinlingle Senior Member • Posts: 1,028
i had the PL 100-400 on my previous Oly EM1.2 and it's one of the sharpest lenses up to 300mm. it drops from excellent to good at 300-400mm. i'm looking forward to the new Oly 100-400.
does anyone know when we can pre-order?
Darrin Lingle, Colorado
 darrinlingle's gear list:darrinlingle's gear list
Fujifilm X-T3 Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 23mm F2 R WR +5 more
Squire Photographer
That's a very fair point.
With these apertures I also wonder why one would use a teleconverter. For the Oly 150-400 F4.5, the built-in 1.25x teleconverter makes sense in my opinion. The idea of a high quality 500mm f5.6 for the m43 system makes me dream. But the price tag will surely put my feet right back on the ground !
Also, we already have a 2x crop factor on the micro 4/3 sensor, so narrowing the aperture makes a huge difference. An 800mm equivalent already gives so much reach... When framing subjects that are very far (I consider 50 metres / 160 feet, for a deer, 30 metres / 100 feet for a magpie to be very far), you often have to deal with atmospheric stuff, which lowers contrast and image quality. And if there's dust, fog or anything like that, IQ drops dramatically.
There is no substitute to closing distance with your subject when it comes to image quality. Having a longer focal length helps, especially for small birds, but that's up to a point. And I think that with an equivalent of 600 or 800mm, we're about there. We'll see if I stick to these words in the future, though
Squire Photographer
Thank your for your feedback with the 100-400 on an Olympus body.
Maybe I should try shooting at 300mm and cropping vs shooting at 400mm and see how IQ compares. I never took the time to try and test that !
Now that Olympus released their 100-400, it has no sync is (at least I think so and that’s huge), is heavier, bigger, and slower than the Panasonic 100-400.  It’s a hard pass for me.
Impulses Forum Pro • Posts: 10,039
I'm not a birder or heavy action shooter, and outside of a few sporadic events I tend to end up using really long FLs like this for landscapes as much as anything... So I went with the 100-300 II a while ago for the OIS and weather sealing (vs the 75-300) amongst other things (and even though I was gonna use it on an Oly body), and I'm likely to stick with it because the Roesch 3rd party tripod collar/foot I got for it is handy enough it even makes it pretty usable with my GX850.
It's a ridiculous combination but sometimes my larger body is just tied up. I can balance it atop a mini/tabletop tripod angled against my chest and achieve some pretty slow shutter speeds that way (the really soft shutter of the GX850 might be helping too). I thought about going for the PL50-200 + TC instead since it'd give a similar FL with more flexibility and probably better IQ in some cases, but I can't justify it (and no tripod foot! boo)
Over time Pana carpet bombed their lineup with both cheap and premium long tele options in various sizes, Oly has got to have lost a lot of sales to people going with one of Pana's 3-4 different options all smaller than the 300/4. I think Mirrorless Comparison had a thorough test of the 100-300 vs the PL100-400, tho they might've used v1 of the former with worse OIS/mechanics (same build/optics tho).
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
Correction:  Sync is may be supported but not 5 axis?  I am not sure what that really means for it’s effectiveness?
Squire Photographer
Thank you for tour feedback! If it works for you, it's not ridiculous ! I didn't know about the Roesch tripod collar, that's genious ! It takes away one of my favorite features of the 100-400 haha. I'll update the descriiption of my video.
If I remember correctly, Mirrorless did use the first version of the 100-300.
Squire Photographer
That's a real bummer... Indeed,on DPReview's review of the Oly lens, Hymenoptera mentionned Olympus's official specsheet, stating that 5 axis isn't supported:
https://www.dpreview.com/videos/7491054563/dpreview-tv-olympus-100-400mm-f5-0-6-3-is-review?comment=5600433409
Maybe someone will try the Pana combo vs the Oly combo and give us more a more precise comparison about this ?
Lens and body do work together but it doesn't have sync is. It's weird and a little complicated.  No way near as good as sync is though. This video review helps explain it:
https://www.youtube.com/watch?v=SfwU5Iavp1E
dbelling Contributing Member • Posts: 759
Gordon Lang released a review today and said the same thing. You can use both IBIS and the lens OIS, but they are not synced. Weird.
Regards, Dave
Squire Photographer
I don't get it. Dual IS was the major drawback for Olympus users, wasn't it ?
It's well known that Olympus know how to make great stuff. Heck, their 300mm f4 is acclaimed by everyone!
I really hope that future reviews will reveal better things about Oly's 100-400...
