Any IQ compromise in using electronic shutter?
Started Aug 3, 2020 | Questions
ArtHeals
ArtHeals Regular Member • Posts: 267
The mechanical shutter sound on my X-T1 is really loud regardless of the shutter speed. So i have been using electronic shutter on the lowest sound setting, that makes it sound like the leaf shutter on the X100 series. Quieter shutter sound is my personal preference and NOT due to shooting in quite environments (churches, weddings etc).
I only shoot jpegs of still subjects/people (no video at all), am I compromising on the image quality?
 ArtHeals's gear list:ArtHeals's gear list
Ricoh GR II Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 85mm F1.8
SigmaChrome Forum Pro • Posts: 15,746
Re: Any IQ compromise in using electronic shutter?
ArtHeals wrote:
The shutter sound on my X-T1 is really loud regardless of the shutter speed. So i have been using electronic shutter on the lowest sound setting, that makes it sound like the leaf shutter on the X100 series. Quieter shutter sound is my personal preference and NOT due to shooting in quite environments (churches, weddings etc).
If you're shooting static subjects and you're not panning, using the electronic shutter should be the same as using the mechanical shutter. Do some testing and see for yourself.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
Aoi Usagi Veteran Member • Posts: 3,224
You do realize that the electronic shutter "sound" is fake and can be turned off completely right?
As far as image quality, the specular highlights in the bokeh could be affected, at higher shutter speeds.
dave74
dave74 Regular Member • Posts: 230
14
Don't worry about "I.Q. compromise" and discover a world of new possibilities, not just amazingly high speeds but also the rolling shutter effects. Like airplane propellers curved into impossible arcs. Or my example, a hovering hummingbird whose two wings are out of phase and separated by a micro-second.
Right wing on the down-stroke and the other returning....have fun!
Ask anyone in their 70's how's it going and they'll tell you 'so far, so good!'
Neil Chalk
Neil Chalk Forum Member • Posts: 98
That looks awesome! Love how this really gives the impression of movement.
I feel like the rolling shutter effect is OK if the subject is moving, but not so much if you are. I tried it out for some street stuff and ended up with bendy lamp posts  which isn't such a good look
 Neil Chalk's gear list:Neil Chalk's gear list
Fujifilm FinePix X100 Canon PowerShot SX280 HS Canon EOS 450D Fujifilm X-T100 Fujifilm X-T3 +20 more
ArtHeals
OP ArtHeals Regular Member • Posts: 267
Amazing shot and i will take your advice and continue to use ES
Foxjet Contributing Member • Posts: 987
I have read that there is a small difference in dynamic range but don't notice it myself when using electronic shutter. You could set up on a tripod and shoot the same shot with and without electronic shutter and see for yourself. That's my preferred way of confirming internet obtained information or advice.
 Foxjet's gear list:Foxjet's gear list
Fujifilm X-T3 Sony a7R V
Chris Dodkin
Chris Dodkin Forum Pro • Posts: 13,956
4 reasons to not use ES
Main issues would be any camera movement or subject movement will lead to image distortion due to the relatively slow scan rate of the sensor during ES.
You also get banding when shooting under artificial lighting due to the cycle flicker of the light source.
You will also get bokeh degradation due to the plane of focus no longer being defined by the aperture on the lens, most noticeably with things like misshapen bokeh balls.
ES will also not allow flash to be used.
I avoid ES unless I have no other possible alternative.
Your time is limited, so don't waste it arguing about camera features - go out and capture memories - Oh, and size does matter - shoot MF
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm X100F Fujifilm X100V Fujifilm X-T2 Fujifilm GFX 50S Fujifilm GFX 50R +50 more
SrMi
SrMi Veteran Member • Posts: 4,377
Re: 4 reasons to not use ES
I have read of bokeh degradation with EFCS at too fast shutter speeds, but not with ES. Can you point me to the relevant tests? Thank you.
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
I believe electronic shutter was not available in the X-T1, but became available in the X-T2.  Is this correct?
I own a X-T3 and the electronic shutter is pretty good, but I mostly use the mechanical shutter.  I've heard that there are small sacrifices in image quality, and maybe some rolling shutter distortion if there is motion in the frame.
Tom Schum
Copper: Mankind's favorite electrical conductor
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
buzzbob Regular Member • Posts: 102
I don't want to hi-jack so please tell me if I am but this has prompted me to wonder if it would be good for Birds in flight. I am considering buying the 100-400 to do this on my XT3 and ditching my Canon DSLR completely. The thing putting me off is shutter blackout and I wondered if the electric shutter would get rid of this while doing all right at avoid RS distortion as I wouldn't be using it with hummingbirds but larger marsh birds like harriers.
Anyone used it with good results?
maxxxx Senior Member • Posts: 1,179
BIF is something I wouldn’t use ES for. Hummingbirds are extreme but I have seen artifacts on wings even for bigger birds.
 maxxxx's gear list:maxxxx's gear list
Sony a7 IV Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Tamron AF 28-200mm F/3.8-5.6 XR Di Aspherical (IF) Macro Sony FE 200-600 F5.6-6.3 Tamron 70-180mm F2.8 Di III VXD +1 more
As an early adopter of the X-T3, I was anxious to try all the features for myself. I always double check opinions posted on the internet especially gear forums. I shot tons of hummingbird photos and many larger birds using electronic shutter. I didn't have a problem with shutter black out using boost mode. The rolling shutter is much reduced with this very fast processor and was not a deciding issue for me. These days I use electronic or mechanical depending on how rare the photo opportunity is. If it's rare indeed, I use mechanical. Here are some early hummingbird shots with electronic shutter, other birds with electronic shutter on my Flickr as well, see link in my signature. By the way Buzzbob, I came from Canon DSLR and have never looked back.
Electronic shutter, X-T3, Fuji 100-400
Get out and shoot,
Tom Schum wrote:
X-T1's have electronic shutter with a firmware update.
shigzeo
shigzeo Senior Member • Posts: 2,296
Several YouTubers showed that Bokeh changed depending on the shutter you used, both on Fujifilm and Sony cameras. I assume the same would be true for other brands.
And, recently, Bill Claff from Photons to Photos, shows dynamic range differences of the R system based on the shutter type used. Again, I assume this behaviour tracks across different brands.
https://www.dpreview.com/forums/thread/4509191
Visit the chart
 shigzeo's gear list:shigzeo's gear list
Leica SL (Typ 601) Fujifilm GFX 50S Leica M10 Fujifilm X-H1 Fujifilm X-T3 +7 more
Jhuffphoto Regular Member • Posts: 108
I have experienced issues with banding in certain artificial lighting situations  while using ES. It seems to be worse with modern LED lighting. I could see the rolling shutter effect being an issue in certain situations such as when panning. I guess the quality of the bokeh could be effected but it must be pretty subtle as I have not noticed it. I tend to avoid the ES most of the time but I actually like the sound of the shutter on my camera. I recommend that you experiment and use whatever shutter that works for you.
 Jhuffphoto's gear list:Jhuffphoto's gear list
Fujifilm X100V Nikon D90 Fujifilm X-T2 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm F1.8G +5 more
Thank you for your help. It seems electronic might be an option. Would EFCS in supported cameras be a "best of both worlds" scenario?
BTW I notice a reference to the R series Canons having EFCS but I thought they didn't. Am I wrong?
Either way it seems blackout is not an issue for BIF with the mechanical shutter, so that's good to know. IIRC I tried a 100-400 some time ago on an X-T1 ( or might have been X-T2) and I thought the blackout was pretty distracting so this has obviously improved.
SrMi
shigzeo wrote:
Visit the chart
AFAIK, the difference in bokeh is only caused when using EFCS at high shutter speeds. Many cameras, like X-T4, automatically choose between the EFCS and a mechanical shutter to eliminate shutter shock while eliminating bokeh degradation.
The difference in dynamic range is caused when cameras use 12-bit instead of 14-bits with the electronic shutter. AFAIK, most cameras use 14-bits with the electronic shutter.
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
ES for astro?
I also find this question interesting. Thanks to the OP.
Is there a compromise in DR? That's what I have once read but I am not sure whether it is true or relevant or not.
Is there any reason not to use ES for example for astro or for macro?
I often use it for macro, particularly for stacking. Never seen an issue. But never made a direct comparison yet.
Advantage of the ES over the MS in such situations (ss between let's say 1/125 s and few s) is of course no shock/vibration at all. With shorter or longer ss, shutter shock is less a problem.
And when stacking dozens of frames or more, it's more pleasant to not have the constant shutter noise.
BR,
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
shigzeo
SrMi wrote:
shigzeo wrote:
Visit the chart
I am sure that B. Claff will test the X-T4 and 3 in the same ways.
