NX5 forgetting date/time
Started Aug 2, 2020 | Questions
kypfer Contributing Member • Posts: 985
As of yesterday, my NX5 has contracted "what-day-is-it-itis" when I change the battery, requiring the date and time to be re-entered when the camera is switched back on.
This is not a symptom I'm unfamiliar with, my old FinePix struggled on for several years with the same condition. At least the NX5 doesn't forget the frame number as well
Has any work been done to establish what component (battery cell or capacitor) has failed, where it's located and the practicality of replacement?
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Samsung NX5
Isola Verde
Isola Verde Forum Pro • Posts: 10,630
Re: NX5 forgetting date/time
As it's a sunny Sunday morning here, and there are better things to do, I trust you won't mind me simply posting this - copied from my reply in a recent thread on the same subject?
MikeSor wrote:
The internal battery on my Samsung NX300 won't hold a charge and thus the date / time is continually wrong. Is it a bad battery, or maybe a bad capacitor? Thanks, MikeSor
Only a few days ago I tried my own NX300, after leaving it in a drawer for several months - and yes, the battery was flat and the date/time needed resetting... and those were then lost afresh when I removed and reinserted a charged battery.
Good news for me though was that it did settle (after leaving it with a charged battery in it for a day or so), and now works as it had done previously... although I've not left it without a battery in it for more than a few minutes.
Some time back I had a very similar experience with the NX3000 - which needed a little longer, but did eventually respond in the same way! [That one has the benefit of USB charging, so is easier to "top up" occasionally, which I now try to remember to do!]
So I'd recommend persevering, as the capacitor - or whatever it is inside - does seem capable of being revived.
Good luck,
Peter
I've just swapped batteries again in the NX300 - without it losing date/time setting - so will repeat the advice to persevere!
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
OP kypfer Contributing Member • Posts: 985
Good luck,
Peter
Peter
Thanks for the response. Unfortunately my NX5 hadn't been left in a drawer, it had just been in use, then, as the battery was indicating a low level, I decided to change it. It was then that the symptoms occurred. The camera would have only been without power for a few seconds and it's not recovered
Isola Verde
That's a shame - at least mine were easily fixable.
Beyond the obvious stuff... changing cards, cleaning battery contacts and the like... no other suggestions spring to mind.
Peter
