Distortion vertical objects rolling shutter a9
Started Aug 1, 2020 | Discussions
Raafje Forum Member • Posts: 80
Sony a9 distortion vertical objects in the background during panning...:-(
It is not a big deal, but it happens pretty often and I don't like it (Electronic shutter 20fps)
Raafje
Sony a9
Tristimulus Veteran Member • Posts: 9,998
Re: Distortion vertical objects rolling shutter a9
9
Then use the mechanical slutter.
The scan time of the electronic shutter is fixed and so it is. No way around that.
OP Raafje Forum Member • Posts: 80
Offcourse, but this camera is advertised for 20 fps with minimal distortion.
Today l did some shooting on the same location with shorter shutterspeeds and
it was less. Overall, compared to the distortion of my a6300 and a6400 I can live with it..)
Magnar W
Magnar W Veteran Member • Posts: 7,055
Are your images tilted a tad counter clockwise? The pictures seems not to be aligned perfectly to the horizont.
If the readout speed is enough to freeze a golf clun\b speed, it seens unlikely that these poles should be noticeable affected by jelly effect when panning.
 Magnar W's gear list:Magnar W's gear list
Sony a7 Sony a7R III Sony a7 IV Sony FE 24-70mm F4 OSS Sony FE 90mm F2.8 macro +5 more
padam19 Regular Member • Posts: 355
It is a different scenario, the camera has the "Anti-distortion shutter" which is probably some sort of additional software correction to remove any residue for rolling shutter. It works well when the camera is relatively static, but when the camera is panning very quickly, it will have a harder time doing this type of correction, so some artifacts may still appear.
It would be interesting to see it against the new A7SIII which also has a very fast sensor readout (Even though it is not a stacked sensor), it probably does not have this Anti-distortion shutter feature.
 padam19's gear list:padam19's gear list
Canon EOS D30
Magnar W
This kind of distortion shoud probably be visible with mechanical shutters too, since faster shutter speed than about 1/250 sec is obtained with a slit moving vertically. The Sony A9/A9II readout speed isn't that much slower, about 1/180 second, from what I understand.
Alfonso Bresciani
Alfonso Bresciani Senior Member • Posts: 1,812
these pics are tilted, look at the shadow areas on top...
Alfonso Bresciani
http://www.AlfonsoBresciani.com
http://nolaPIC.com/
 Alfonso Bresciani's gear list:Alfonso Bresciani's gear list
Sony a9
No,
Later I will post more samples with the horizon visible.
Raafje
pollup Senior Member • Posts: 1,532
Show us the same images with mechanical and electronic shutters, that way we can see what they should look like.
 pollup's gear list:pollup's gear list
Sony a9 Sony FE 85mm F1.8 Sony FE 35mm F1.8 Sony E 70-350mm F4.5-6.3 G OSS Canon EOS 550D +6 more
This 'problem' does not occur with mechanical shutters. I never noticed this from the 3o years I was a canon and nikon dslr shooter. Today I made some new distortion samples
with the sony a9 in electronic shuttermode when making panning movements. I post them later. If you can't wait, make a panning shoot movement with 20 fps with powerpylons or something like that in the background. There is no need to wait for a bird passing by...)
Some distortion samples from today (Panning with electronic shutter 20 fps)
Offcourse you don't need a bird to make a distortion sample..)
Two frames from a panning movement :
Most times there is no problem...;)
The same Swan :
Crop from the same picture :
Another distortion sample :
ssshoot
ssshoot Regular Member • Posts: 494
A mechanical 'slutter', mmmm, interesting
 ssshoot's gear list:ssshoot's gear list
Sony a7R IV Sony a9 II Sony 70-200mm F2.8 G SSM II Sony FE 90mm F2.8 macro Sony FE 24-70mm F2.8 GM +3 more
No,
The problem occurs when panning...
I know the golfclub freezing sony-pr samples.
I'm sure there is no panning involved for taking those pictures.
Auto word correction, just as brilliant as using the electronic shutter when shooting fast and erratic action...
Magnar W
You probably are right! Test shots posted here!
On forums we sometimes think we are right when answering or commenting, but doing some quick research might make us change our mind.
Your photographs and comments made me do a pretty simple test to find out how the electronic shutter in my A7rIII handles panning. And guess what: With electronic shutter (ES), the tilting effect is insane - just as expected with such low readout speed.
If we look at the ES results here, and try to reduce the angle so that it fit the A9 readout speed, I woult think some tiliting defect would be seen with your camera too when panning. Note the flat top on the tilted poles. I can clearly observe the same in one of the photos you first posted.
Just a few notes on my test:
  • I went for a test scene with a visible horizon line for better control
  • I took a reference shot with static camera
  • It is very hard to pan with excactly the same speed
  • Even mechanical shutter show slight tilting defect, less so with electronic first shutter curtain, but this is probably due to some slower panning speed
Here are my quick and dirty results:
Magnar W
Examples very fast panning - mechanical shutter
6
Here are two frames taken with mechanical shutter, taken with 400 mm focal length at 1/8000 sec. The camera was panned very fast, higher speed that what we would use for tracking for birds in flight.
Here we clearly see the rolling shutter defect with vertical mechanical shutter. Note that the top of the poles look horizontal.
Also se the post lower in this tread, with examples taken with different shutter settings.
Alfonso Bresciani
Re: You probably are right! Test shots posted here!
Electronic first shutter curtain is straight!!! What are the cons of using electronic first?
Alfonso Bresciani
http://nolaPIC.com/
Sony a9
robert614 Senior Member • Posts: 1,745
I’ve noticed the same thing
Raafje
I’ve noticed the same phenomena.
I made a thread about it on Fred Miranda a while back.
https://www.fredmiranda.com/forum/topic/1623045/0#15052843
Magnar W
Close to zero.
You might get a bit different out-of-focus rendering when using very bright aperture, and with some non-native lenses you can get uneven exposure with at very high shutter speed.
This is documented in the user guide, and most likely also the help guide.
For my photography, I use first electronic shutter curtain all the time.
SQLGuy
SQLGuy Forum Pro • Posts: 12,666
Close to zero.
You also may get fine banding when using HSS flash.
A7R2 with SEL2470Z and a number of adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Canon PowerShot S100 (2000) Sony Mavica FD-91 Sony Cyber-shot DSC-S70 Sony Cyber-shot DSC-V3 +45 more
