John K
Re: Good post, but some errors...
junmoe62 wrote:
I would personally not call you nuts for saying that. If you understand that the fact of cropping 2x will reduce you picture‘s resolution by the same amount. The resulting framing of your cropped picture would be similar to what you would get with a 600mm lens. You would obviously lose 2x the resolution compared to shooting with a real physical 600mm lens and also emphasize the flaws of the lens.
Cropping in post doesn't change the focal length that the image was taken with. But since cropping in post, and cropping a full frame image circle with a smaller than full frame lens, is functionally the same then the focal length doesn't change no matter what camera body you use. When you crop an image, no matter how you do it, the only thing that changes is the field of view and how large the subject looks in the frame. This is great time to use terms like "full frame equivalent field of view".
Totally agree with you!
That's what I was trying to say, but I don't think I presented it well.
I'd be pretty bummed if I got into m43 thinking that the 2x crop would actually give me more mag, and with it more detail, only to find out that it's just a crop.
Once again you’re theoretically right, but practically I think this is largely dependent on the optical qualities of the lenses and the pixel densities of the sensors.
OK, I'll agree. Lots of factors at play.
Let’s stay in the theory and say we are in a perfect world (with Teletubies, rainbow unicorns and cotton candy clouds everywhere. My favorite place ever!! :D). We make a side by side comparison :
We shoot an optically perfect 60mm 1x mag lens @f2.8 on a perfect 20MP m43 sensor @ iso100
We shoot an optically perfect 120mm 1x mag lens @f5.6 on a perfect 20MP FF sensor @ iso400
both same technology, same subject and distance to subject.
At 1x the working distance won't be the same though, if the mag is the same. Even the depth of field will be different because the Fstop is not equal. Where already comparing apples and oranges...
So both systems are shooting at the same magnification, yet, which picture do you think will end up with the most details?
I'll pick full frame because even at ISO 400 the image is gonna have less noise.
It is interesting when you read the Wikipedia definition of magnification :
quote from Wikipedia : “Magnification is the process of enlarging the apparent size, not physical size, of something. This enlargement is quantified by a calculated number also called "magnification". When this number is less than one, it refers to a reduction in size, sometimes called minification or de-magnification.
Typically, magnification is related to scaling up visuals or images to be able to see more detail, increasing resolution, using microscope, printingtechniques, or digital processing. In all cases, the magnification of the image does not change the perspective of the image.”
It gets muddy once you get past the image that's projected onto the sensor.
Based on that definition I see 2 interesting things :
- If Magnification is the process of enlarging the apparent size, not physical size, of something. Does it mean that enlarging the apparent size thanks to the pixel density of the sensor be considered as magnifying, even though the magnification of the lens relatif to the sensor size is a fixed number?
Kinda had this discussion already. If I take a photo of a field of sunflowers that has a butterfly in the foreground and print the image billboard size so that the butterfly is now life size in the print is it then a macro photo?
- We can also see from this definition that the magnification of the image does not change the perspective of the image. Which shows once again that zooming, magnifying or cropping doesn’t affect in anyway the perspective.
Doesn't change the magnification either
Look I'm not trying to bash you, the camera you use, or anything else. Putting anyone, or anything, down doesn't do me any good. I was just trying to clear up some important terminology.
I totally understood your attempt John, absolutely no offense has been taken. I also told you in each and every of my posts that I wholeheartedly agreed with you, that you are totally correct (Except for the perspective thing) and I even thanked you many times for correcting the mistakes. Nothing has changed and I truly mean it!
The only point I was trying to make since the beginning concernes the fact that I don’t think it is very helpful nor meaningful enough to hijack each and every threads and turn them into super geeky techy fight.
Not my intent. But telling people that using a 2x lens on a m43 camera gives you 4x mag is extremely misleading.
I’m not implying that is what you do nor that is a habit of yours, but if you spent enough time in the m43 forum, you will see this kind of behavior is extremely common, to the point where it just becomes toxic. Everyone spending a minimum of their time in the m43 forum already witnessed that countless times I’m sure. One would be extremely unlucky (or should I say lucky :D) to miss on the equivalence talks in this forum!!!4
Looking at this forum has been like stepping into a time machine. Like I've said before we've had these discussions in the 1.6x crop factor community already and concluded that it's called "crop factor" and not "universal multiplier" for a reason...
I just think this kinds of endless boring talks just don’t really help anyone and actually Scare away many beginners and new comers. I know for a fact that it did for me for several years. And I can promise you that while writing this thread I was sure it will turn out that way!! I don’t know what’s going on on this forum, but if you have the very bad idea to associate the letter “E” and “Q” next to each others, a very strong chemical reaction will happen!! This thing is like nitroglycerine!! One drop is enough!! Boom!
Agreed.
I think spending more time on what’s actually going to improve the overall photographs (like lighting, composition, color science, how to approach the subject, how to get good diffusion and catchlights in the insects eyes,...) would be way more useful to everyone, especially beginners, than getting semantics right. Sadly you chose the latter... I mean, in all your posts in the thread you never ever referred once nor commented on the pictures, even though I invited people to do so in my original post and that I would have really been glad about it.
Actually that's not true, I did compliment you on the photos. But I also made it clear that a crop is a crop.
For example, it’s my first time posting on the forum, do you think your 2 first posts sound like a warm welcoming to the forum?! It felt more like passing an exam, and the teacher correcting the mistakes. It was only missing the score at the end! I’m not really sure that’s what most people willing to post on the forum are after, but I might be wrong...
Sorry, but that's gonna happen when you write a post that sounds like a tutorial and make mistakes...
If you wanna believe that you're actually getting more magnification, more focal length, or even a better parking spot just because you're using a 2x crop factor sensor that's fine. I'll leave you to your echo chamber that seems to be the m43 community.
The thing is that I don’t think I’ve ever Implied that! For example, when I say “a 300mm F4 on a m43 body is roughly equivalent to a 600mm F8 on FF body“ I don’t think it means in anyway that a 300mm F4 on a m43 body is a 600mm F8 on FF body.
Anyways, in the end I think we are agree on the core thing, but we are just arguing about a different way of looking at things and we don’t put the cursor of the accuracy/approximation at the same level. You’re more on the tight & academic side, I’m more on the lose & field experience side... To illustrate my point I could see a talk between Mozart and Jimi Hendrix, with Mozart saying : “academic learning is key!!!” And Hendrix answering something like : “F@#$ that sh#$, bruh!!! Practice and experience is the answer!” :D.
To end this long answer, I really want to emphasize that I in no way attempted to bash you either and I really hope you won’t take anything personal.
Same!
You sound like a very nice and knowledgeable guy and I really hope we’ll be able to have friendly and constructive talks in the future! I mean it! (I just hope it won’t be on equivalence though!!! :D)
I wish you a nice day and happy shooting.
Julien
Respect.
