John K wrote:
junmoe62 wrote:
John K wrote:
junmoe62 wrote:
So, let me ask you a question. I definitely don’t want to get into all the equivalence controversy thing, because I have not much interest in all that stuff, and I most of the time have better things to do, but I’m interested in your view on that. My question is : Do you think it is totally unacceptable to say, for example, a 300mm F4 on a m43 body is roughly equivalent to a 600mm F8 on FF body?
It's the same, but only in the sense that the field of view will be the same. But if the focal length actually changed then there would also be a change in perspective. As you go from a wider angle to a narrower one objects in the scene start to appear closer together. That perspective change doesn't happen when you crop a photo, no matter how or when the crop is done.
Well John, I’m afraid to tell you that this time you are the one guilty of spreading misinformation!
If anything I'm guilty of over simplifying it, but you took care of that below:
Hi john,
After reading your message again, I’m not entirely sure what you actually meant or what point you where trying to make. So I’ll give you the benefit of the doubt and let you develop a little more if you wish to.
But to me it sounds a whole lot like you were saying that because the 300mm lens on m43 is a wider focal length than the 600mm on FF, the framing would be the same, but the perspective would be different. This is totally wrong and no amount of over simplification will ever make this right. From the same distance to subject, so putting both setups on the same tripod, focusing on the same subject, the 300mm @F4 on m43 and the 600mm @F8 should give you the same framing, same perspective and same perceived DOF on the picture.
Saying, and I quote you : “As you go from a wider angle to a narrower one objects in the scene start to appear closer together” this is totally wrong. If you do no move your position relative to your subject to keep this subject the same size relative to the framing, the perspective won’t change at all.
To me this is actually quite a big mistake, because it’s directly affecting one the most important aspect of photography, which is composition.
Now to be perfectly honest, I personally don’t mind much, because as I stated before, I’m not much of a tech guy, and I prefer put my focus on the real world practical experience than the actual scientific and physics aspect of photography. You are the one who seem to be very attached to the semantics and accurate phrasing, so I though it would only be fair if it applied to you as well.
I mean, nowadays with digital cameras you can see instantly what you’re getting, so generally you’ll make test shots before committing to your final shot. I can imagine in the old times it was paramount to know all the intricacies of the physics, because you didn’t have the flexibility that we have today, and you couldn’t afford any mistakes. But nowadays, IMHO I don’t feel that it is of such great importance. Is it good to know about all the physics involved? Yeah, sure! It’s better if you know it all. It probably could help you figure out things a bit faster, but is it the end all be all? I don’t think so! Especially when you consider that all those theories apply in a perfect world. In the real world, so many parameters are involved that it is almost never 100% accurate.
The focal length of a lens alone has absolutely no effect on the perspective! Your position relative to the subject does. You can experiment yourself by taking a picture of a subject from the same position with a zoom lens on your camera. Take a picture at the widest angle you can, then zoom to the max and repeat. You will see that the perspective of the zoomed picture will match the one from the same location on your wide angle shot (minus the potential optical flaws like lens distortions (pinch, barrel and so on) obviously).
So when you zoom with your lens, you basically “cropping” the framing... and I’m not counting DOF and other aspects.
Which means, if you take a picture of the same subject, from the same location with a 300mm on m43 and a 600mm on FF, you should have the exact same framing and perspective. You just cropped, and crop doesn’t affect perspective...
I just googled the first article talking about that to link for you as a reference, in case my words are not enough to convince you :
https://martinbaileyphotography.com/2017/04/10/the-effect-of-subject-distance-and-focal-length-on-perspective-podcast-568/
That pretty much sums up why 800mm on m43 isn't the same as 800mm on a full frame camera. Let me try this from another angle:
Well... a 800mm lens is a 800mm lens and this is not dependent upon the sensor size. The sensor size will only change the resulting framing provided by those lenses.
If I shot with a full frame sensor using a 300mm lens, cropped the resulting images in post to a 2x crop factor, and claimed that the resulting photos were shot with a "600mm virtual lens" you'd call me nuts.
I would personally not call you nuts for saying that. If you understand that the fact of cropping 2x will reduce you picture‘s resolution by the same amount. The resulting framing of your cropped picture would be similar to what you would get with a 600mm lens. You would obviously lose 2x the resolution compared to shooting with a real physical 600mm lens and also emphasize the flaws of the lens.
Cropping in post doesn't change the focal length that the image was taken with. But since cropping in post, and cropping a full frame image circle with a smaller than full frame lens, is functionally the same then the focal length doesn't change no matter what camera body you use. When you crop an image, no matter how you do it, the only thing that changes is the field of view and how large the subject looks in the frame. This is great time to use terms like "full frame equivalent field of view".
Totally agree with you!
I remember these discussions in the APS-C community, and they were really painful. Way too many people wanted to think that the 1.6x crop was somehow magical, like the rules of photography and physics had to be rewritten to be re-written to explain the magic that was nothing more than a simple crop. Seems the m43 community isn't there yet, and I regret stepping in it...
If you think it is unacceptable, then fine!
Not unacceptable, but not the same. Sorry.
But if you think it is acceptable to some extent (like the vast majority on the internet), I could argue that following your thought process, from the same distance, which would translate to same framing, if you fill the frame with a ruler of 1 meter, the m43 system would give you a magnification of 17.3mm / 1000mm = 0.0173, while the FF system would give you 36mm / 1000mm = 0.036.
But you can't fill the frame with a ruler on both systems -the m43 is smaller. If you're saying that you are filling the frame on both then either the m43 is at a lower magnification (there's that word again ) or there's a difference in distance between the subject and the sensor with the ruler being closer to the full frame sensor. In either case the magnification isn't the same, if it were you'd only see half of the ruler in the m43 photo because the image is being cropped. At the same mag and Fstop depth of field will be the same for both sensors. But if you shoot at 1x with the full frame sensor, and shoot at .5x with the m43 but call it 1x due to the crop factor then the m43 image will have more depth because the mag is lower. That's the main reason why I think that cropping shouldn't be viewed as magnification, and why the two really are not the same.
In my example I was still talking about the 300mmF4 m43 lens VS the 600mmF8 FF lens. I though once again that it was obvious... sin
ce I precisely said “from the same distance, which would translate to same framing”.
My mistake.
Why wouldn’t I be able with those setups, from the same position and the ruler at the same distance, be able to fill the width of frame with the exact same 1 meter mark? Yet I believe the m43 would give a 0.0173x mag. while the FF would give 0.036x mag.
Is the 300mm m34 lens projecting a smaller image circle? Is so then it's focal length is probably a m43 equivalent (like the EF-S lenses for Canon APS-C camera bodies).
I have absolutely no idea!
So, since we saw above that FL has nothing to do with perspective if you shoot a subject from the same distance, and that the DOF from a F4 on m43 is very similar to a F8 on FF (btw, I’m still referring to the same lenses mentioned above, in case it wasn’t clear enough), don’t you think that feels very close, in the concept, to crop in post or with the sensor? Maybe the semantics are not of absolute perfection and accuracy, but honestly, that’s a good enough approximation for me.
Does that make the whole theory totally useless and cannot be used to have a rough idea of what to expect? I personally don’t think so, YMMV.
Yes it does invalidate it because of the differences in depth of field, diffraction softening, and I'm probably forgetting a few others. The problem is that you're assuming someone just getting into macro is going to know everything that you do, not realizing that juggling terminology could be confusing.
Well, honestly I don’t think this kind of tight and minute subtleties in the photography jargon is gonna appeal to, nor affect the photos of macro beginner!
I'd be pretty bummed if I got into m43 thinking that the 2x crop would actually give me more mag, and with it more detail, only to find out that it's just a crop.
Once again you’re theoretically right, but practically I think this is largely dependent on the optical qualities of the lenses and the pixel densities of the sensors.
Let’s stay in the theory and say we are in a perfect world (with Teletubies, rainbow unicorns and cotton candy clouds everywhere. My favorite place ever!! :D). We make a side by side comparison :
We shoot an optically perfect 60mm 1x mag lens @f2.8 on a perfect 20MP m43 sensor @ iso100
We shoot an optically perfect 120mm 1x mag lens @f5.6 on a perfect 20MP FF sensor @ iso400
both same technology, same subject and distance to subject.
So both systems are shooting at the same magnification, yet, which picture do you think will end up with the most details?
It is interesting when you read the Wikipedia definition of magnification :
quote from Wikipedia : “Magnification is the process of enlarging the apparent size, not physical size, of something. This enlargement is quantified by a calculated number also called "magnification". When this number is less than one, it refers to a reduction in size, sometimes called minification or de-magnification.
Typically, magnification is related to scaling up visuals or images to be able to see more detail, increasing resolution, using microscope, printingtechniques, or digital processing. In all cases, the magnification of the image does not change the perspective of the image.”
Based on that definition I see 2 interesting things :
- If Magnification is the process of enlarging the apparent size, not physical size, of something. Does it mean that enlarging the apparent size thanks to the pixel density of the sensor be considered as magnifying, even though the magnification of the lens relatif to the sensor size is a fixed number?
- We can also see from this definition that the magnification of the image does not change the perspective of the image. Which shows once again that zooming, magnifying or cropping doesn’t affect in anyway the perspective.
Look I'm not trying to bash you, the camera you use, or anything else. Putting anyone, or anything, down doesn't do me any good. I was just trying to clear up some important terminology.
I totally understood your attempt John, absolutely no offense has been taken. I also told you in each and every of my posts that I wholeheartedly agreed with you, that you are totally correct (Except for the perspective thing) and I even thanked you many times for correcting the mistakes. Nothing has changed and I truly mean it!
The only point I was trying to make since the beginning concernes the fact that I don’t think it is very helpful nor meaningful enough to hijack each and every threads and turn them into super geeky techy fight. I’m not implying that is what you do nor that is a habit of yours, but if you spent enough time in the m43 forum, you will see this kind of behavior is extremely common, to the point where it just becomes toxic. Everyone spending a minimum of their time in the m43 forum already witnessed that countless times I’m sure. One would be extremely unlucky (or should I say lucky :D) to miss on the equivalence talks in this forum!!!
I just think this kinds of endless boring talks just don’t really help anyone and actually Scare away many beginners and new comers. I know for a fact that it did for me for several years. And I can promise you that while writing this thread I was sure it will turn out that way!! I don’t know what’s going on on this forum, but if you have the very bad idea to associate the letter “E” and “Q” next to each others, a very strong chemical reaction will happen!! This thing is like nitroglycerine!! One drop is enough!! Boom!
I think spending more time on what’s actually going to improve the overall photographs (like lighting, composition, color science, how to approach the subject, how to get good diffusion and catchlights in the insects eyes,...) would be way more useful to everyone, especially beginners, than getting semantics right. Sadly you chose the latter... I mean, in all your posts in the thread you never ever referred once nor commented on the pictures, even though I invited people to do so in my original post and that I would have really been glad about it. For example, it’s my first time posting on the forum, do you think your 2 first posts sound like a warm welcoming to the forum?! It felt more like passing an exam, and the teacher correcting the mistakes. It was only missing the score at the end! I’m not really sure that’s what most people willing to post on the forum are after, but I might be wrong...
If you wanna believe that you're actually getting more magnification, more focal length, or even a better parking spot just because you're using a 2x crop factor sensor that's fine. I'll leave you to your echo chamber that seems to be the m43 community.
The thing is that I don’t think I’ve ever Implied that! For example, when I say “a 300mm F4 on a m43 body is roughly equivalent to a 600mm F8 on FF body“ I don’t think it means in anyway that a 300mm F4 on a m43 body is a 600mm F8 on FF body.
Anyways, in the end I think we are agree on the core thing, but we are just arguing about a different way of looking at things and we don’t put the cursor of the accuracy/approximation at the same level. You’re more on the tight & academic side, I’m more on the lose & field experience side... To illustrate my point I could see a talk between Mozart and Jimi Hendrix, with Mozart saying : “academic learning is key!!!” And Hendrix answering something like : “F@#$ that sh#$, bruh!!! Practice and experience is the answer!” :D.
To end this long answer, I really want to emphasize that I in no way attempted to bash you either and I really hope you won’t take anything personal. You sound like a very nice and knowledgeable guy and I really hope we’ll be able to have friendly and constructive talks in the future! I mean it! (I just hope it won’t be on equivalence though!!! :D)
I wish you a nice day and happy shooting.
Julien
