John K wrote:
gardenersassistant wrote:
John K wrote:
junmoe62 wrote:
Regarding the diopter, I know that the theory says that you do not use light, but in practice, I always find myself having to adjust the power of the flashes up when I put it on.
Because the magnification changed and the field of view dropped, so there is less surface area reflecting light back into the camera and the flash had to fire longer to compensate. So there's no light loss due to the diopter, but the increase in mag will require more light to get a proper exposure. Happens with extension tubes (to a slightly greater extent), teleconverters, etc. Any time the mag goes up the exposure will have to change to compensate.
I'm wondering how just how large an effect you would expect this magnification-caused change in illumination requirement to be with a close-up lens. You say it happens to a slightly greater extent with extension tubes, teleconverters etc, so presumably that means that if you use a close-up lens and increase the magnification you would need to add almost as much light as if you had made the same change in magnification using extension tubes, teleconverters etc. Have I understood you correctly?
Extension tubes (and a teleconverter as well) move the lens further away from the image plane and as the image circle expands the intensity of the light drops. You don't get that same effect with a diopter. No matter how you increase the magnification there is going to be less surface area reflecting light back into the lens as the mag goes up, and it was the original reason for effective Fstops. Back in the stone age, when we used hand held light meters, you had to compensate for that drop in light by adding stops to the aperture value displayed in the meter (the meter assumes that you're shooting at infinity). Effective Fstops has since been hijacked to use in diffraction calculations but I think it's just a convenient way of dealing with the aperture getting further from the sensor as the mag goes up (as the distance between the aperture and sensor increases light has more room to diffract).
And presumably the etc includes macro lenses, for example the MPE-65?
It does, but one way to compensate for it is to get the light source closer to the subject. If you're using a macro twin flash that drop in reflected light off of the scene as the mag increases can be offset due the distance between the flash heads and the subject getting shorter. It's possible to increase the mag and yet keep the flash power the same and still get a good exposure simply because the flash, mounted to the end of the lens, is closer to the subject.
Thanks John, but my question was about close-up lenses (what you refer to as "diopters"). It was this: "presumably that means that if you use a close-up lens and increase the magnification you would need to add almost as much light as if you had made the same change in magnification using extension tubes, teleconverters etc. Have I understood you correctly?"
Key word is "almost". A teleconverter and extension tubes move the lens further away from the image plane, and as the light expands the intensity will drop. You don't get that effect with a closeup lens.
And my other question was whether the same would apply if you used a macro lens such as the MPE-65 rather than extension tubes or a teleconverter for that side of the comparison.
If you're gonna set up some sort of side by side comparison and attempt to slice my throat go ahead. Just keep in mind that there will be differences in the physical size of the aperture, and potential differences in the distance between it and the image plane. I can only tell you that as the mag goes up, no matter how, the intensity of the light will drop due to the decrease in surface area reflecting light back into the lens.
That is the core issue for me - you say that increased magnification reduces the light intensity reaching the sensor, however that magnification is achieved. However, this seems inconsistent with my experience with close-up lenses; when I change the magnification I don't have to change the flash power (I use a manual flash, so I think I would notice it if anything other than a small difference was going on).
Puzzled about this, I did an experiment, using as an example the difference in light intensity as between a magnification of 1:1 and 4:1, first with an MPE-65. I used it on a Panasonic G9. in aperture priority mode, using available light, I shot it at 1:1 and 4:1 with the same f-number and ISO for both shots.
Based on the effective f-numbers for these magnifications, I calculated an expected difference of light intensity of around 2.5 stops. The illustration below shows this was about right. The camera chose 1/50 sec for the 1:1 shot and 1/10 sec for the 4:1 shot. This is a difference of 2 and 1/3 stops, and the 4:1 shot is slightly darker. So this result is consistent with a difference in light intensity of around 2.5 stops.
Click on Original size beneath the image to see the animation.
With the same camera and subject, I then captured two images using a Raynox MSN-202 close-up lens on a 45-175 lens, one using 45mm and one using 175mm. This gave magnifications very similar to the ones with the MPE-65, 1.15:1 and 4:1. Here too I used aperture priority mode, using available light, with the same f-number and ISO for both shots.
The following illustration shows that the camera chose the same shutter speed for both shots, and the lightness of the two images was very similar. This means that the light intensity was pretty much the same at the two magnifications.
This seems to me to confirm my impression from shooting flash - if changing magnification when using close-up lenses does alter the light intensity reaching the sensor, then it doesn't change it by much.
There is a bit of a twist to this. I did similar comparisons with other close-up lenses (Raynox 150 and 250, Canon 500D, Marumi 200 and two Marumi 330s, one reversed on the other), shooting pairs of shots at 45mm and 175mm as I had for the Raynox 202.
These pairs all gave the same result, which was that the camera chose the same shutter speed for both shots in the pair, and the lightness of the shots in each pair was almost the same, but they differed very slightly, and differed in the same way for every pair. Here is the Raynox 202 comparison again, but this time with the histograms aligned.
We can see that the 4:1 shot was very slightly darker than the 1.15:1 shot.It is a very small difference. For example, thinking back to the MPE-65 example, the illustration below shows what a 2 and 1/3 stop difference looks like on those histograms.
The difference we are seeing with the close-up lenses is tiny compared to that. (Presumably it is less than 1/3 stop otherwise the camera would have changed the shutter speed to keep to the required exposure compensation.)
I wondered if this might have something to do with the design of the 45-175, which does not extend as you increase focal length. However I get the same effect with a 45-200, which does extend.
Curious. I wonder what is causing this.
