OP
junmoe62
Regular Member
Re: Good post, but some errors...
John K wrote:
junmoe62 wrote:
Hi John,
Thanks for your post and bringing a more accurate and scientific approach to my claims.
You’re absolutely right on (Almost) everything you said (Your assumptions about the actual “real magnification’” of the setup were not correct), so I’m glad you could correct the errors.
It seems I got it all reversed! When I was talking about FF Eq. magnification I should have used the word “crop” and about the TC I should have used the term “magnification” instead of “crop”... my bad...
As I’ve previously stated and as you can see, I’m not much of a tech guy.
After, to be fair, English is not my mother tongue. What I actually meant was that, for example, the framing for 1x magnification lens on M43 is similar to the framing of a 2x magnification lens on a FF. Meaning that the composition of the picture would be the same. I never meant that the IQ and DOF of the picture would actually be the same between and 1x M43 setup and a 2x FF setup. I thought that it was obvious to most.
I know what you meant, but the way you said it was wrong.
I totally agree with you and I thank you for correcting it.
Also, I’m glad that you could decipher the meaning of the point I was trying to make through my gross mistakes. I hope other forum members will show as much clairvoyance as you do on the matter.
So indeed it was a shortcut that could be confusing, I agree. But then, I guess many here on the forum come from all around the world and don’t necessarily have the perfect vocabulary (like myself), probably don’t have a PhD in science and optics (me included), are there to relax and don’t always want to keep everything so serious and scientifically accurate in all the phrasing (I’m guilty too).
No PHD necessary. Words, and their definitions, are pretty easy to understand.
I’m glad to be granted the benefit of the doubt concerning my ability to understand words and their definitions! You might be largely over estimating my capacities there!!
Maybe, this favor can be returned to other forum members concerning their capacities to understand the idea I was trying to share with my post. Especially considering that I provided pictures with the details on the gear used and the size of the subjects.
When you think about it, even on a daily basis we always use shortcuts in our languages that don’t always represent things in a scientific accurate way.
Not getting basic terminology right can lead to a lot of confusion. Again, it's not science and no PHD required.
Agreed
Regarding the diopter, I know that the theory says that you do not use light, but in practice, I always find myself having to adjust the power of the flashes up when I put it on.
Because the magnification changed and the field of view dropped, so there is less surface area reflecting light back into the camera and the flash had to fire longer to compensate. So there's no light loss due to the diopter, but the increase in mag will require more light to get a proper exposure. Happens with extension tubes (to a slightly greater extent), teleconverters, etc. Any time the mag goes up the exposure will have to change to compensate.
Thanks for clarifying!
So we can agree that by increasing the magnification you’re “losing” light (maybe losing is not the right word but I don’t know how else to describe the phenomenon)?
So taking that into consideration, me saying “it doesn’t lose too much light” when I was referring to the Raynox isn’t completely out of place. To be clearer, I probably should have said “to reach the same magnification with the same camera and lens combo, the use of the Raynox M-250 results in a lesser light loss than using extension tubes”. But does that make that much of a difference to the end result to formulate the sentence that way? I’m not sure! What I’m definitely sure about though is that it makes waste much more time to write it that way! Well... at least on the moment... Because the time I’m wasting trying to justify myself afterwards is just insane!!!!
So I guess once again you’re right!! It would have been much better for everyone if I got it correctly the first time!
That’s probably due to something else, like inverse square law or the position of the light source relative to the subject and front of the lens, I don’t know, but the fact is that it somehow does have an impact.
You're on the right track.
And finally about the maximum magnification of my setup which consists of 2x 10mm extension tubes + 16mm extension tubes + MC20 TC + Raynox M-250, I made the test you requested since I don’t want you to think I’m here to spread misinformation It fills the width of the frame with about 3mm. So 17.3 / 3 = 5.76 magnification. So when I said that the setup gave 8x FF Eq. magnification (by which I meant same framing than 8x mag on FF), I was actually understating the numbers. Let’s round out to 5.5x which gives the same framing than 11x on FF. But let’s make it 10x for safety purposes...
No, lets make it 5.76x cause that's the magnification at the sensor. Cropping the image circle, like cropping a photo in post, does not change the magnification. You're still trying to claim that cropping increases the magnification.Cropping just creates an enlargement, so the subject looks larger on screen or in print. But it won't reveal more detail like increasing the magnification can and that's just one reason why they two are not the same.
When I'm shooting with a macro lens set to 1x mag on my APS-C sensor (1.6x crop) I'm shooting at 1x mag. I'm not shooting at 1.6x.
If I add a 1.4x teleconverter between the lens and camera I'm now shooting at 1.4x due to the magnification factor of a the teleconverter. I'm not shooting at 2.4x (1.4 x 1.6).
In both cases the crop factor of my sensor makes no difference in the magnification. Will the subject look larger in a print or on a screen than the same image taken with a full frame sensor at the same magnification? Sure, but that's the nature of creating an enlargement.
So, let me ask you a question. I definitely don’t want to get into all the equivalence controversy thing, because I have not much interest in all that stuff, and I most of the time have better things to do, but I’m interested in your view on that. My question is : Do you think it is totally unacceptable to say, for example, a 300mm F4 on a m43 body is roughly equivalent to a 600mm F8 on FF body?
If you think it is unacceptable, then fine!
But if you think it is acceptable to some extent (like the vast majority on the internet), I could argue that following your thought process, from the same distance, which would translate to same framing, if you fill the frame with a ruler of 1 meter, the m43 system would give you a magnification of 17.3mm / 1000mm = 0.0173, while the FF system would give you 36mm / 1000mm = 0.036.
Does that make the whole theory totally useless and cannot be used to have a rough idea of what to expect? I personally don’t think so, YMMV.
Anyways, I’m glad to have this chat with you and I totally understand and agree with your view on the subject. But I also don’t personally feel the need to have always 100% accurate phrasing and wording, as long as it is not completely detractIng the overall meaning of the message. There are times where it is of great importance, but come on, we’re on a photography forum talking about the hobby we all love!
I wish you a nice day and happy shooting!
Julien
