John K
Good post, but some errors...
junmoe62 wrote:
The gear I’m using for true macro is primarily the EM1 X (sometimes the EM1 II) with Olympus 60mm F2.8 macro, this gives up to 2x magnification in FF equivalence.
No. Cropping an image, in post or with a smaller than full frame sensor, creates an enlargement but does not change the magnification of the subject that was projected onto the sensor. You're still shooting at 1x. FWIW: I shoot with an APS-C sensor.
If I need more magnification, my first pick is adding the Raynox M-250 (DCR-250) diopter in front of the lens. It is a fantastic option, since it just takes a second to clip in front of the lens, it doesn’t loose too much light, and to my eye it doesn’t seem to degrade the picture quality (maybe just a tiny bit of chromatic aberration in some case, but that’s really neat picking).
With a diopter you won't lose any light at all -that's one of the advantages that diopters have over extension tubes. With a high quality diopter like the Raynox series you shouldn't notice any decrease in image quality. It's a myth that adding more glass degrades an image (adding cheap glass will, so it's one of those things where you get what you pay for).
From there, if I need more magnification I have different options. I an add extension tubes to the mix, or I can remove the raynox M-250 and use 2x 10mm extension tubes with the Olympus MC20 2x Teleconverter. The latter actually yields quite impressive results with the 60mm F2.8 macro. It makes you loose 2 stops of light but makes you jump straight to a little over 4x magnification (FF Eq.). You do lose a little in IQ but it is still impressively good. I would even dare say that the IQ loss is less noticeable than on the 300mm F4 or 40-150mm F2.8. That may be due to the close focus distance and the impressive 60mm F2.8 microcontrast.
Macro lenses are designed to be sharp at minimum focus, primes and telephoto zoom lenses are designed to be sharp at infinity. With a teleconverter as long as the quality of the glass is good you should get good results from it.
Doubt you're actually getting 4x out of all that though
Then, if you want to go crazy and need even more macro power, you can go 2x 10mm extension tubes + MC20 TC + Raynox M-250. From there you can definitely tell it does start to affect the IQ, but still perfectly useable in my opinion. Finally, you can reach about 8x (FF Eq.) magnification I believe (don’t quote me on that, I’m not totally sure but that’s definitely a lot, just a little less than the 10x I have with the Laowa 25mm F2.8 2.5x-5x macro) with the combo 2x 10mm extension tubes + 16mm extension tubes + MC20 TC + Raynox M-250. With this last setup, that’s the limit of usability, I think, regarding IQ, light loss and the fact that it’s the maximum number of extension tube you can use before the focus bracketing starts failing.
Again I think you're including the crop of the sensor in the mag. Big difference between cropping an image to make the subject look larger on a screen or a print and actually magnifying it.
You can actually go from infinity ... to about 8x macro with 1 lens, while still having access to focus bracketing and AF!!!
It's the AF part that tells me you're not really at 8x. AF isn't going to place the focus where you really need it once you get above 1x with most cameras.
I’m not sure but to my knowledge I don’t see anything else that can do that. You can surely find options that will provide better result at specific tasks, like using bigger sensor with motorized bellows and microscope lenses, but you can hardly consider that a hassle free, convenient, flexible, lightweight, compact, run & gun setup...
Agreed, except for the magnification. Depth of field (once you get to 1x and higher mag) is strictly a function of Fstop and magnification. Nothing else matters, not even the focal length of the lens or the working distance to the subject. One of the benefits of shooting with a smaller than full frame sensor is that the subject will look larger in the final image because the scene is cropped, and that allows you to fill the frame at lower magnifications than shooting full frame. Lower mag = more depth of field. It's the reason why I'm shooting with an APS-C camera (Canon 80D) instead of shooting full frame.
You can also get the exact same effect by shooting full frame and cropping in post. If the price ever drops I'd consider buying a 5dsr and crop its 50MP full frame images down to a 1.6x crop (roughly an 18MP image I think).
Here are some picture taken with this setup (Not full resolution) :
The images all looked really nice!
I’ll try to make a topic about the 300mm F4 Pro for closeup photography and also the Laowa 25mm F2.8 2.5x-5x on M43 and show the difference with the 60mm F2.8 when I find the time.
Not sure about your 60mm macro lens, but Canon's 60mm EF-S macro, like all macro lenses that have internal focusing (lens doesn't change shade when you turn the focus ring), loses a lot of focal length at minimum focus and is a 37mm lens when set to 1x. So it only takes 37mm of extension to get to 2x. One thing you might wanna try is add some extension tubes to your 60mm macro, set it to minimum focus and photograph a metric ruler, and then divide the width of your sensor by the number of millimeters in the photo to get the magnification. You can do that with all of the setups you mentioned to see what the actual magnification is.
Can't stress enough that there's no such thing as "full frame magnification equivalent".
If you like the pictures I shared and you have some time at hand, you can have a look at some of my work on 500px at : https://500px.com/julienmonborgne
I post regularly on that platform.
Thanks for the link -following.
I post there as well: https://500px.com/dalantech
