XC 15-45 or XC 16-50 OR XF 18-55 on X-T20 for beginner ?
Started Jul 25, 2020 | Questions
OP shekhar92 New Member • Posts: 23
Re: XC 15-45 or XC 16-50 OR XF 18-55 on X-T20 for beginner ?
I am learning the modes available. I just started with shutter priority and then appreture and later manual mode.
Thank you
 shekhar92's gear list:shekhar92's gear list
Fujifilm X-T20 Fujifilm 50-230mm II Fujifilm 15-45mm F3.5-5.6 OIS PZ
SamfromAL Regular Member • Posts: 242
Get the better lens 18 55.  I understand everyone says concentrate on your learning but
Performance helps keep enthusiasm high.
The 18 55 is reaallllllly good.  And can be almost the only lens you need for many pics as it is relatively fast, and very sharp.  While it is nice to have something wider than 18 and narrower than 55, this is a well thought out range.   As far as selling the other lens it is always good to have a second one just in case but funding may not allow.
I have the XC 16 50 and it is a well adequate lens as well but not compelling like the 18 55 in terms of performance.
I just received a 10 24 it is excellent as well, but the Tiffin 72mm Polarizer I bought with it is pretty soft.
So if you have any filters on a lens make sure you understand the difference with and without.
jjz2 Veteran Member • Posts: 4,396
I wouldn't pay that much for an 18-55... you can get them used for much cheaper..
I got one for 220 shipped.
My 15-45 wasn't bad, but I didn't enjoy shooting with a plastic power zoom.
 jjz2's gear list:jjz2's gear list
Nikon Z6 Nikon Z5 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 85mm F1.8 +1 more
MarkMyWords Regular Member • Posts: 339
Some testing I’ve done recently:
https://www.dpreview.com/forums/post/64138000
bastibe
bastibe Senior Member • Posts: 1,236
I did a comparison a while back, of just these lenses: https://bastibe.de/2019-05-11-fuji-zoom-lenses.html
Personally, I stuck with the 18-135, and sold the 15-45, 16-50, and 18-55. Yes, I owned them all, because I was as confused as the OP was, and decided to evaluate them all myself.
 bastibe's gear list:bastibe's gear list
Ricoh GR III Fujifilm X-Pro2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
"To be perfectly honest, I can not see any significant differences between any of these pictures. At this point, I am starting to question the entire concept of sharpness and micro contrast for evaluating lenses. But at least I learned a lot about how to use the Gimp."
"As a sanity check, I repeated the experiment with my old Nikon 18-200, and this was in fact noticeably less sharp. And slightly overexposed. And slightly off-color. That's why I switched to Fuji. But as I said, this was a sanity check, not a fair comparison, as the Nikon D7000 body is much older than my Fuji X-E3, and the lens has surely seen better days as well."
Excellent comparison. Your summing up matches my own experience - modern camera gear IQ is converging with diminishing returns.
Ringwraith69
Ringwraith69 Veteran Member • Posts: 3,407
shekhar92 wrote:
Dear All,
After seeing all your suggestions, I decided to stick with current XC 15-45 lens till I understand all the basics. I am using shutter priority mode mostly. I need to learn how to use proper settings in manual mode and utilize the light.
Thank you for your time and support.
I think that's the best decision you could have made. You stated that you liked the 15-45mm images, but had difficulty in getting good low light shots. That's indeed a sign you need to get comfortable with the basic photography and camera techniques first. Investing in another 'kit'lens won't really help you that much there.
Just keep learning about the different settings and modes the camera has the offer, you'll get the hang of it soon enough. And take the steps you want to make in your own order, we all have different preferences but you'll have to do what makes sense to you. So: wise choice!
(We are only immortal for a limited time)
 Ringwraith69's gear list:Ringwraith69's gear list
Sigma DP1 Fujifilm FinePix X100 Fujifilm X-S1 Sony RX10 II Sony RX10 IV +42 more
baobob
baobob Forum Pro • Posts: 18,248
The IQ of the 15-45mm XC is very good The ergonomy is above average the price is attracting
If you are ready to cope with ergonomy it is a good choice to save money for a future XF 55-200mm in complement
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
bowportes Veteran Member • Posts: 4,337
Thank you
If you're using shutter priority, try slowing down your shutter speed to about 1/15th second in low light for anything that's not moving. The 15-45 has good OIS that will stabilize camera shake.
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-Pro3 Fujifilm GFX 50S II +15 more
YY101 Regular Member • Posts: 151
Unless budget is no concern, else I think just learn to use the camera and kit lens first before moving to something else
 YY101's gear list:YY101's gear list
Sony a7 III Sony FE 35mm F2.8 Sony FE 28-70mm F3.5-5.6 OSS Tamron 28-75mm F2.8 III Tamron 28-200mm F2.8-5.6
(unknown member) Senior Member • Posts: 2,057
Re: XC 15-45 or XC 35mm f2 for beginner
Try the XC 35 F2 for family shots to give you blurry backgrounds. Better at night too and should be sharper than the zoom at 35mm. At $200 it was made exactly for people in your situation.
a_c_skinner Forum Pro • Posts: 13,047
Stick with what you've got.  At the mid to wide setting the 15-45 is optically excellent and if your images disappoint then it is almost certainly how you are using it.
Buy the new cheap 35/2, which will give you excellent optics at the long end and better light gatheting.
However if you are disappointed with your images it is unlikely to be the gear, especially as a beginer it is likely because you need to work more on the craft.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
miroshi Contributing Member • Posts: 690
I own 16-50 and 18-55.
For 15-45 I always read good things about its IQ, but is with powered zoom - I do not like this.
I never compared IQ between my 16-50 and 18-55, but for my needs both are ok. I prefer and almost always use 16-50, because of the wide end and because of its small size. I use 18-55 only when need more light.
I can share lot of images with 16-50, and at 16mm I can tell IQ is better than 16-80 at 16mm.
Also I am sure 16-50 is much cheaper, I got it from UK (OIS vII) for about 170 Euro.
Regards!
"It isn’t the camera that makes the pictures great, it’s you." - Dan Bailey
phototravels-bg.com
 miroshi's gear list:miroshi's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 16-50mm F3.5-5.6 II Fujifilm 50-230mm II Fujifilm XF 23mm F2 R WR +1 more
Veducci Senior Member • Posts: 1,359
I have the XC16-50 ll and after reading some good reviews of the XC15-45 I bought one.
Comparing the two I ended up returning the 15-45. Actually I liked it operationally but the IQ wasn`t quite up to my 16-50. The long end was not great at all. I understand it`s an issue with this lens.
That said, I`d be willing to try another sample given the opportunity ,but for now the 16-50 serves me well.
Update: Got me another xc15-45 pz recently that came with my XA5. This copy is really good , maybe even as good as my old xc16-50 oisll but hard to tell now that I no longer have the older lens. As we all know, kit lens quality often varies from one copy to another.
 Veducci's gear list:Veducci's gear list
Fujifilm FinePix F40fd Panasonic Lumix DMC-G3 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +3 more
You can zoom as with the 16-50; you simply use the focus ring. You don't have to use power zoom.
I own all 3 zooms, but use only the 15-45 because it is wider and smaller than either of the others. Excellent image quality for an inexpensive zoom -- especially at the wide end!
Regards!
phototravels-bg.com
I didn't know it any way I will not get one more lens. 16-50 is good, some day I will try few 16-80 and if find sample with good 16mm I will get one.
I have kids and sometime I want my lens be up to 300mm
Regards!
phototravels-bg.com
jpig Contributing Member • Posts: 556
It's still a power zoom when you use the focus ring. You just get finer control over the zoom movement. This ability to zoom using the focus ring was added in a firmware update, but not all older Fuji bodies got it. I can't recall which cameras have this ability and which don't. I only know that it works on my XE3. It's useful, but not the same as the mechanical zoom on the 16-50.
Mahoumatic New Member • Posts: 1
Own both XC15-45 and XF18-55, both second hand.
On the wide side, the XC15-45 is by far sharper than the XF18-55 (at least for my copy). Anything wider than 28mm the XC15-45 is much sharper than XF18-55. The aspect that the 15mm gives you much more than the 18mm. Tele side, they perform pretty much the same, both just doing so-so. You need other lens if you want a visually sharp photo on 100%.
Personally prefer the color on XC15-45, but this is just personal.
The problem with XC15-45 is it's electronic zoom. Every time you power on the camera the lens need to zoom external. That's a 1-2 second lag and may cause a few miss-hit if you are using it for street photography or children / pets shots.
The 2/3 stop aperture difference isn't a big deal personally. If you care about boken or brightness it can be a point to consider, while the close-shooting ability of XC15-45 actually generates pretty much the same level of boken.
If you are a photography learner, XF18-55 maybe a better deal. With a zoom ring it helps understanding how you zoom and keep the distance between the camera and the subject.
Overall personally XC15-45 is a very good and far understated lens within X-Series lens series, even only with the wide to mid angle side performance. It eliminated the need for XF16 f2.8 for me, and for it's size you won't bother to bring it with you alongside with other prime lenses.
What prime lenses you will add later on will also be a thing to consider. With XF18-55 at the beginning you will probably skip the XF18 f2, XF27, maybe even the XF/XC35 f2 and XF50 f2, while for XC15-45 you will skip the XF16 f2.8.
