XC 15-45 or XC 16-50 OR XF 18-55 on X-T20 for beginner ?
Started Jul 25, 2020 | Questions
shekhar92 New Member • Posts: 23
I have purchased X-T20with XC 15-45 two months ago. It's my first camera. I am in learning process. The XC 15-45 images are looking good.
I recently came across that IQ is better on XC 16-55 and XF 18-55 than XC 15-45. Is it good decision to sell the XC 15-45(for 190$) and buying( XF 18-55 for 380$ and XC 16-50 for 250$) any one of the two? Is any other better option?. I'm on budget.
I'm intended use this for family and travel photography.
Thank you for your time.
 shekhar92's gear list:shekhar92's gear list
Fujifilm X-T20 Fujifilm 50-230mm II Fujifilm 15-45mm F3.5-5.6 OIS PZ
Fujifilm 15-45mm F3.5-5.6 OIS PZ Fujifilm 16-50mm F3.5-5.6 II Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm X-T20
nonicks Senior Member • Posts: 1,188
Re: XC 15-45 or XC 16-50 OR XF 18-55 on X-T20 for beginner ?
I don’t have the 15-45 nor I researched on the lens so I can’t say anything good or bad about it.
i had 18-55 before and that lens is quite impressive given it’s a kit. Build, handle, size and speed are very good for this kit lens. IQ is great. if u can find a used one around $300, it’s a no brainer.
However, i think the XC16-50II provides even bigger value. IQ is great and color and contrast are outstanding. I would say the color is better than the 18-55. It is also Very light and small. The only big thing it missed is the aperture ring. But it gives you 16mm on the wide which is a generous feature for a “low end” kit lens. The best part is that It costs around $140 for a used one.
I would say either choice is good. If budget is not an issue, I would get the 18-55 due to better handling experience and faster aperture. But if budget is an issue and you are more a 16mm person, get the xc16-50, you will be very happy with it too.
 nonicks's gear list:nonicks's gear list
Leica Q2 Leica M10-R Leica Summicron-M 35mm f/2 ASPH Leica Summilux-M 50mm f/1.4 ASPH
Nick on the Baltic
Nick on the Baltic Contributing Member • Posts: 664
15
Stick with what you've got; technique and your imagination have a lot more effect on image quality than the lens.
If you have money to spare, you might find a longer (telephoto) lens useful as an addition. Otherwise I would wait until you fell constrained by what your current lens can do. Don't bother about what people think is a better lens.
Nick on the Baltic
 Nick on the Baltic's gear list:Nick on the Baltic's gear list
Canon EOS 5D Fujifilm X-Pro1 Fujifilm X-M1 Canon TS-E 24mm f/3.5L II Fujifilm XF 18mm F2 R +5 more
sshapiro Senior Member • Posts: 1,018
I have a copy of each lens and have used them with my X-T20. I would keep the 15-45mm because it gets wider than the other lenses. Maybe add an XC 50-230mm or XF 55-200 for telephoto. The other alternative is the XF 16-80 but that lens seems overpriced unless you get it at a 25% discount. The XF 18-135mm is also a good choice if you want a variety of focal lengths without changing between lenses. I believe the 18-135mm is on sale for a substantial discount in some regions.
sparky_parrot Forum Member • Posts: 50
Stick with it but if you have extra money just look in second hand websites or ebay and get a xf 18-55 for 300$ or less (or 300eur or less depending on your region).
As a beginner ur better off focusing on acquiring skills, discovering ur tastes and buying second hand. XT-20 is a perfect choice and in term of timing the market its one of the best price/quality ratio.
 sparky_parrot's gear list:sparky_parrot's gear list
Fujifilm X-T1 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 100-400mm F4.5-5.6 OIS WR
User5469540350 Regular Member • Posts: 175
The 15-45 sucks at the long end. Soft,soft compared to the 16-50. The 16-50 is larger, not that wide but the IQ is far better. If on a budget I would sell the 15 and buy the 16.
Snap Happy Senior Member • Posts: 1,925
If you are happy with the 15-45, then replacing it with lenses that might have better IQ (and probably only slightly better and/or only in specific situations) is not going to improve your photos dramatically, if at all.
I would keep it but may be add a 50-230. Thats a nice light kit for travel.
 Snap Happy's gear list:Snap Happy's gear list
Fujifilm X-T4 Fujifilm GFX 100S Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +19 more
jhorse Veteran Member • Posts: 5,913
Hi, you are going to get lots of suggestions based on personal preferences and user experience. You will have to judge them against your needs and desires. So, here is my take. When I had a XT20, which is a fine camera, I used a 18-55. It is, in my opinion, a great do-it-all combination.  That would be my choice.
Looking at the alternatives. I had, but sold a 15-45, which I bought with a XE3. I bought it for a trip to Paris, where photography was a second priority (to a charity event). I was very happy with the IQ, but not with the power zoom. I found it slow, imprecise and frustrating. Upon return, I sold it and bought a XC16-50/f5.6, which gave me the same IQ, I am unable to see any discernible difference between it and the 15-45, but with a manual zoom and far better experience. I still have it and use it a lot when I want to go light.  Again, between it and the 18-55, I can see virtually no IQ difference on screen viewing. The 16-50 is a little wider, which helps in an urban setting, and it is a little lighter, whereas the 18-55 has a better quality feel to it and I enjoy using it more.  They are close, but if I were forced to have only one, without doubt I would go for the 18-55.
Note that in your title, you state 16-50, which I assume you mean the XC 16-50/f5.6, but in the text you state the 16-55.  This is the red badge XF 16-55/f2.8. I have this lens too and it is in a difference league to the others mentioned in terms of IQ, being superior and having f2.8 throughout the zoom range. But note, it is larger, heavier and more expensive and has no image stabilisation (nor does the XT20).
In sum, what is best for me might not be so for you, but of the choices you outline, I would opt for the 18-55. Hope that helps.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
a_c_skinner Forum Pro • Posts: 13,047
5
"The XC 15-45 images are looking good."
You've answered your own question.  Optically at the wide end there is agreement it is as good as the wide primes.  Unless you are very unhappy with the longer end images (and do look at your images, not reviews) then keep it.
The real weakness of the Fuji system is the "standard" zooms.  They all have drawbacks and no one is a clear winner.  I spent ages debating 16-50, 18-55, 16-55 and found it difficult to decide.  I think I chose wrongly.  The 15-45 and 16-80 have made the choice harder!
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
OP shekhar92 New Member • Posts: 23
Hi J,
Thank you for your response.
I have written 16-55 instead of 16-50 by mistake. I'm only talking about XC 16-50 throughout the post.
My daylight images form XC 15-45 are looking good but in the low light , those are bad. That's why I am looking at these two.
Could you show us a bad low light one, jpg with EXIF and you'll get better advice.  If low light is your problem you may gain little from a different lens unless you can justify a much faster lens, say f2.
Andrew Skinner
shekhar92 wrote:
Hi J,
The other lenses might not substantively change your low light outcome. You might need to improve your understanding of how to use your camera in low light situations. In addition, software such as Topaz DeNoise might help if the issue is noise.
baobob
baobob Forum Pro • Posts: 18,248
IMO the 18-55mm is a good starting lens I have been using mine for years since bought it at launch many years ago...
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
NotANumber Forum Member • Posts: 91
Forget about getting a 2nd hand 18-55. There is a very high chance you will get a decentered copy. Get the xc16-50ii and you can use the extra money for the xc35 f2 prime.
 NotANumber's gear list:NotANumber's gear list
Sony RX1 Canon EOS M Fujifilm X-E3 Canon EOS RP Fujifilm XF 35mm F1.4 R +8 more
Hi, notwithstanding that above I said if I had to choose I'd opt for the 18-55, I think it is a great lens, this approach of an XC16-50MkII plus the new XC35, which I have no experience of but heard good things, makes a of of sense.
More decisions!
YY101 Regular Member • Posts: 151
I think just stick with the XC15-45 kit that you got with the camera. I doubt you will see a huge improvement in your photography by switching from 1 zoom lens to another.
I recommend that you get a nice prime if you are looking for more bokeh, especially for portrait photos. You need a large aperture for this. The bokeh you get from the 3 zoom lenses will not be impressive.
 YY101's gear list:YY101's gear list
Sony a7 III Sony FE 35mm F2.8 Sony FE 28-70mm F3.5-5.6 OSS Tamron 28-75mm F2.8 III Tamron 28-200mm F2.8-5.6
JayPhizzt Senior Member • Posts: 2,374
Bad in what way? Noise? Motion blur?
Getting a different lens isn't automatically going to make your low light shots better. A larger aperture can of course sometimes be beneficial in low light, but else it's a lot more about knowing how to shoot in poor light.
My suggestion is that you keep your 15-45mm and properly learn to use the camera and lens and then maybe get a better lens As you learn more you will also learn what kind of lenses you might want/need.
Strangefinder
Strangefinder Senior Member • Posts: 1,352
XC50-230 +/- XF50 ///Re: XC 15-45 or XC 16-50 OR XF 18-55 on X-T20 for beginner ?
If you're happy with the 15-45mm, I don't think that the cost of the 18-55 would warrant the improvements.
I'd recommend a lens which provides more light or more range.
The XC50-230mm is very cheap (be sure to shop around, as some places will double or triple the price), and yet comes close to the capabilities of its XF55-200mm counterpart.  This would bring your total range to 15-230mm, which is handy for travel.
I would otherwise suggest a bright prime for better portraits and indoor/evening shots.
The XF35mmF1.4 is outstanding and also a bit cheaper than the other f/1.4 lenses, and the XF50mmF2 is not quite as bright, but very sharp and swift to focus for family.
“Remember that all through history, there have been tyrants and murderers, and for a time, they seem invincible. But in the end, they always fall. Always.” Gandhi
“If you're not careful, the newspapers will have you hating the people who are being oppressed, and loving the people who are doing the oppressing.” Malcolm X
5
Dear All,
After seeing all your suggestions, I decided to stick with current XC 15-45 lens till I understand all the basics. I am using shutter priority mode mostly. I need to learn how to use proper settings in manual mode and utilize the light.
Thank you for your time and support.
shekhar92 wrote:
Dear All,
Why shutter priority? I'd say aperture priority is the most commonly used mode and imo. the best mode for most situations as it gives you control over the depth of field.
