Is Old Fuji Color Better? Or Even Different?
Started Jul 25, 2020 | Discussions
headofdestiny Veteran Member • Posts: 9,230
Re: Is Old Fuji Color Better? Or Even Different?
Marco Cinnirella wrote:
Ed Jeffersen wrote:
For me the difference is not so much the color, but the tonality. The X-Pro 1 had a beautiful way of graduating light.
Yes this. It's the reason I re-bought an X-Trans 1 sensor camera (X-Pro 1) recently
https://www.flickr.com/photos/marcoc/
"When words become unclear, I shall focus with photographs. When images become inadequate, I shall be content with silence." Ansel Adams.
Wow, I've been gone for a while, but I'm old enough to remember how many of us hated X-Trans when it came out.  It's hilarious to me that people are now searching out old X-Trans models.
I eventually gave in and bought a few X-Trans cameras, but I never liked the rendering, so now I've been shooting with an original X100 again.
UsherFellig Regular Member • Posts: 174
For Fuji digital, it's the Bayer X-T100 and original X100 for me.  Love their rendering.  Same with the Bayer XF10, though mine doesn't get the use it should due to the absence of a vf.   I was all set to add the X-T200, but its UI turned out to be too smartphone-esque for my taste.
allineedislight Senior Member • Posts: 1,311
it's all in the processor!
In my view, the type of Fuji JPG colour does in fact not really depend on the sensor, it depends on the processor.
If you are looking for the "old" Fuji colour you need to buy a camera with an EXR or EXR pro processor. Here are cameras with three different sensors but the same "old" colour signature:
* Finepix X-100 with Bayer aps-c sensor
* Finepix X-S1 with compact sensor
* X-E1 and X Pro 1 with x-trans I sensor
Using the same sensors as above but with a later processor (say EXR II) you get different colours:
* X-M1 with x-trans I sensor
* Finepix X20 with compact sensor
Again, EXR II colour style also does not depend on the sensor, you get the same type e.g with the x-trans II Sensor:
* X-E2, X100s, x100t etc with APS-C
In short, the JPG colour signature is due to the processor used in the camera. The sensor is important of course for dynamic range, noise, resolution etc but not really for the JPG colour signature.
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
oscarvdvelde Senior Member • Posts: 1,421
I thought they changed the color settings in the camera between X-T1 and X-T3, with more graduations of saturation and contrast. This may affect the personal experience.
Also, I perceived a better highlight color in X-T3, the X-T1 blew them more often.
Auto white balance can affect your experience with a camera as well. I found the X-T1 too cool, it was often going for 4800K, so I have since been using fixed 5400-5600 K for most daylight photography. Taken at the same WB the camera results look the same.
 oscarvdvelde's gear list:oscarvdvelde's gear list
Fujifilm X-T3 Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR Samyang 50mm F1.2 +4 more
John Sevigny Forum Member • Posts: 72
IMO, Fuji cameras have gone from creating a very unique look at the expense of stone age autofocus to creating a far more generic look with no real increase in AF. I currently shhot an xe2, xe3, xpro3 and previously shot an x100t and v.
OP Erik Baumgartner Senior Member • Posts: 6,893
Fuji's evolving jpeg processing (or devolving, according to some) is a good reason to just shoot RAW instead. You can enjoy the technical advancements of the newer cameras and process the images to look however you want.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
ayolos Junior Member • Posts: 39
Xtrans1 and Xtrans2 are bad for landscape because they are only 16MP, 12 bits raws and low DR.
But you can get interesting results with theses camera. After readind this post, I tried to capture high DR scene with my XE1 and 27mm for a very compact setup and get the most of it beautifull old sensor.
One shot only with highlight exposure (target sky), handheld, keeping base ISO 200 for max DR, C1 base profile no color correction only sharpening and HDR sliders. it's not A7R but for the age and weight it's not that bad :
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
Dismayed
Dismayed Contributing Member • Posts: 919
Everything was better when we were younger.
“There are three kinds of men. The ones that learn by readin’. The few who learn by observation. The rest of them have to pee on the electric fence for themselves.”
~ Will Rogers
 Dismayed's gear list:Dismayed's gear list
Fujifilm X-Pro2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 50-140mm F2.8 XF 90mm +2 more
Marco Cinnirella
Marco Cinnirella Veteran Member • Posts: 8,160
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
I know quite a few pro landscape shooters who shot with the 12.8MP Canon 5D very successfully - were the specs or performance of that (admittedly FF) sensor much better than the X-Trans 1 ? Interestingly some Canon fans still rave about that 5D sensor and revere it like some Fuji fans celebrate X-Trans 1. It seems there may be a degree to which early sensors that did not cram lots of MP on them produced a color and/or tonality that some appreciate
 Marco Cinnirella's gear list:Marco Cinnirella's gear list
Sony a99 II Sony Alpha a99 Fujifilm X-H1 Sony a7 III Fujifilm X-T3
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
5D classic is the XTrans 1 of canon : low megapixel, 12 bits raw, low DR, low green sensitivity but best colors and tonal range.
5D classic is my favorite sensor ahead xtrans1 because files are even more fantastic. problem : old body heavy 900 gr :/
XPRO1 and XE1 half the weight.
Marco Cinnirella
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
XE1 + XF 27MM
Yup, Canon 5D + a fast 85 was truly beautiful for portraits for example
Agreed. My favorite camera for color rendition is the x100t. Even those are going for like $900 used. And no, the xe2 is not the same.
