Re: Fully manual lens vs Bricked lens on E-M5
j y g wrote:
My Olympus 40-150mm PRO lens recently bricked during an update, right before going hunting for comet NEOWISE. Meh. So I figured, big deal, I just use it manually as you do for all astrophotography anyway. But, when I attached the lens, the view from the sensor goes dark (view screen all black, save for camera OSD info).
You cannot use an electronic lens like a manual lens. Since your lens is "bricked", the camera detects that a malfunctioning lens is attached and refuses to use it. But even if it did not (like if you put an insulating tape over the contacts), you would still have no way to set aperture and focus mechanically on that lens, since both are strictly "fly by wire".
After fiddling a bit, I realized that when the contact pins have nothing to communicate with and the locking pin is down, the sensor goes limp. If that is correct, then how is an E-M5 (mk 1) able to use fully manual (not electronic) lenses or dumb mount adapters and still take photos? I've searched around, on the web and in camera menus, to see if there's some option to override this behavior, but I don't see it.
For purely mechanical lenses, the camera detects that no lens is attached, and simply works. You have to enter the focal length for ibis to work properly (obviously very impractical for say an adapted zoom lens).
In my Pen-F, I can also enter and save a lens name and description in "gear" menu K "lens info settings". It then displays that in the exif data. I assigned both ibis fl and description to a user mode.
For the old em5.1, here some hints for manual lenses:
http://www.ayton.id.au/wiki/doku.php?id=photo:olympusem5_fourthirds
PS: before sending the lens for repair, which will certainly cost you some $150, you could try to revert the camera back to an older firmware, and then have another try at updating the lens firmware. To load an older camera firmware, use the in-camera-firmware-update method described here: https://lightsnowdev.com/Olympus/
Chances of it working are not that great, but if you have time and feel confident doing it, worth a try.
PPS: if you also have a Panasonic camera, you could try using that to update the lens firmware - it may do it in a slightly different way and it may just work if you are lucky.
