Powershot SX530hs continuous shot.
Started Jul 23, 2020 | Discussions
WayneWindsor New Member • Posts: 1
Good afternoon, my daughter has just purchased the above camera. Her passion is aviation photography, mainly fast jets. I understand there are two continuous shot settings but when she activates them and starts the shot the screen goes blank and she cant follow the aircraft. Is that normal or is she doing something wrong??
Thanks Wayne
Canon PowerShot SX530
User4286416121 Senior Member • Posts: 1,221
Re: Powershot SX530hs continuous shot.
Not sure since I have the sx50 versions. But it may be in burst mode too. Not sure if the screen always blacks out in continuous mode or not.
Takes  talent and skill for the sx530 is screen only, no evf.  The Canon site shows different specs than hee so go with that.
I will check blackout times on the sx50 with screen.
I have used my sx50 for air shows. Wish it was faste focusing, but it dies well, and even better than the expensive ones in certain areas.
Tested sx50 and it goes blank
labrie Forum Member • Posts: 65
For airshows I like to use red dot sight mounted in hotshoe. It does not get dark and I am aware of action outside of narrow FOV of the camera (really helps to catch planes passing by each other). On the other side, it needs to be precisely adjusted and one has to keep an eye on LCD, to adjust zoom.
Please, feel free to correct my English.
reyalp Regular Member • Posts: 201
I don't have this specific camera, but in my experience most PowerShots behave in a similar way: If you hold the shutter down in continuous drive mode (set in the func menu on sx530) it shows each preceding shot until the next one is taken. Not sure if this is what you meant, but in any case it's quite difficult to track fast moving subjects, especially on cameras that shoot at a low frame rate. There is definitely no mode that shows normal live view while shooting continuously, the sensor is tied up for significant time to read out a full image.
sx530 also has a high speed burst mode, but none of my cameras have that so I'll leave it someone else to chime in if it's different.
An alternative is to take single shots and use the framing assist button to zoom out and re-acquire the target, but obviously you get fewer shots this way.
Another thing people do is rig a red dot sight, like mentioned in https://www.dpreview.com/forums/thread/4178785 but unfortunately sx530 doesn't have a hot shoe, so some other mounting strategy would be required.
A viewfindwr attachment to the screen might help with stabilizing but does nothing for the blackout. Fast focusing camera with optical viewfinder might help.  Still blackout with the mirror just less.  The reach should be more than enough for shows.
