SD15 Full Spectrum (no filter) WB comparisons
Started Jul 23, 2020 | Discussions
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
In this thread , a discussion started about the use of WB when shooting with the dust cover removed and no filter on the lens (FS). It being a nice sunny morning, I went out front and shot a few:
Embedded JPEGs opened in FastStone Viewer, no adjustments:
Top left: Auto
Top right: Incandescent
Bottom left: Custom with card in soft shade (top of tree shadow)
Bottom right: Custom with card in full sun (about 50 deg. elevation).
At first glance, bottom right is obviously "best". However, the crushed green channel in the foliage seems to be affecting "detail".
Bottom right versus RawDigger RGB export as-is:
With the foliage at right now a brown color there must now be green content in it's rendition which would obviously improve the said detail (mo' contrast), all other things being equal.
Because "detail" is hard to come by in FS work, I'll continue with the RawDigger-based workflow ...
There are more ways than one to skin a cat ...
Seba Smith - The Money Diggers, 1840
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Sigma SD15
tagscuderia
tagscuderia Senior Member • Posts: 1,957
Re: SD15 Full Spectrum (no filter) WB comparisons
Worth trying SPP's Green Fringe Correction: Hue 0.9, Amount 1.0 as a starting point.
The problem with SPP for FS is that the Colour Mode presets are simply not designed for it. RawDigger presents a great starting point but it's interesting that with Merrill, the White Point/Balance is so off; albeit easily corrected with Levels (and the rest).
 tagscuderia's gear list:tagscuderia's gear list
Sigma DP3 Merrill Sigma SD1 Merrill Sigma 15mm F2.8 EX DG Diagonal Fisheye Sigma 18-35mm F1.8 DC HSM Art Sigma 50-100mm F1.8 DC HSM Art
xpatUSA
OP xpatUSA Forum Pro • Posts: 23,016
As I say occasionally I'm remaining with 5.5.3 by choice, Tom.
Correct. I agree with your sentiment: If Sigma had pushed the "easy IR" aspect a lot harder and provided good support in SPP, they would have sold a good few more ILC cameras, I reckon.
RawDigger presents a great starting point but it's interesting that, with Merrill, the White Point/Balance is so off; albeit easily corrected with Levels (and the rest).
No Levels in SPP 5.5.3 either.
Not bashing 6 - I'm sure that the above will be of interest to others here.
Ted
tagscuderia
Oh what? I didn't know that that feature was missing from 5.x.x, sorry Ted − I wonder if it's feature locked to particular cameras too, such is SIGMA's want (rhetorical).
I concur, and it's interesting (perhaps should that read 'annoying') that SIGMA UK has featured several articles on FS and yet SPP doesn't really support it.
No Levels anywhere, has to be done in an external editor, as it would with a Merrill RawDigger export.
Thanks for the comparison, interesting to see the difference between sun and shade Custom WB.
xpatUSA
Yes I've seen that yellow before, even in the LCD. IIRC, I've seen it in high-luminance areas perhaps indicating "overexposure" ** by which I mean channel-clipping during conversion.
Raw histogram:
The red channel is 1EV below clipping (clipping is about 3500 on the SD15).
** ... now that most people think that "exposure" includes LUTs, raw scaling, matrices, WB, color space, connection profiles, printer profiles and the viewing white reference!!!!
Ted
tagscuderia
Affinity Photo uses LibRaw, so that's another option but...
... I don't know if it's using the WB matrix in the X3F metadata − I don't have any FS shots sans Custom WB to test.
Edit: it does by default but can be overridden by selecting a classic Kelvin/Tint WB tool.
But I've come full circle, I think that I prefer that palette over my 099 (550nm), digital photography really is nothing without the software!
N.B. LibRaw does no highlight reconstruction of Foveon RAW so 'overexposure' is a big no no!
xpatUSA
Like my Custom sunlit card image, very pleasing colors!
Oh. A bit global, but better than nothing, I guess.
Agreed!
I've never been a fan of "highlight re-construction" anyway. If desired stuff (e.g. clouds) is too bright in a converted but un-adjusted image, it's a candidate for the trash, IMO.
We should remember the "S-curve" in DPR's dynamic range graphs - where the curve at the top means that highlights may not be "blown" but they certainly can have less contrast than desired.
Ted
SigmaTog
SigmaTog Senior Member • Posts: 1,114
Ted what is " ILC cameras " Please ?
tagscuderia
That's a straight conversion, all defaults, no tweaking, which is very pleasing indeed! Far better than I can force out of SPP; and then you're stuck fumbling around in Photoshop attempting to achieve something vaguely aesthetically pleasing
A global White Balance correction is ok at the conversion stage... if I keep repeating that I'll start believing it I'm sure.
Agreed!
My phone shoots HDR DNG, even my drone shoots RAW! I miss the flexibility of Aperture/Lightroom, but for Infracolour... Affinity is scratching an itch:
The bonus with working on the RAW data (per se) is that you have so much control − this is a FS shot, same as above, but I simulated a 550nm orange filter. Which just doesn't work on a converted JPG/TIFF!
I'd much rather blow highlights than suffer SPP's treatment of 'under' exposed Merrill shots − so I've learned to live with SPP's rather good Highlight Control tool. But I admire your sentiment.
The 'Standard' tone curve for the SD1M, not sure what to make of that really
xpatUSA
Interchangeable Lens Camera, Colin.
Ted
SigmaTog
Yes, I should have known, thanks.
With Full Spectrum & IR & mixing filters etc, additive colours come into play & that is something I am looking at now....
You can see a thread over at UVPhotography here....
https://www.ultravioletphotography.com/content/index.php/topic/4030-spectrograph-study-of-a-rosco-74-night-blue-filter/page__fromsearch__1
tagscuderia
I presumed the above but it meant that Ted wrote Interchangeable Lens Camera cameras, a bit like when people say ATM machine
SigmaTog
& PIN number.....
tagscuderia
SigmaTog wrote:
& PIN number.....
I'm definitely guilty of that one!
xpatUSA
Doesn't look like DPR's. Here is the DPR test 'S' curve which is sRGB 8-bit luminosity versus illuminance from a step-wedge target:
What are the axes of your curve proportional to?
Ted
tagscuderia
That's the conversion tone curve for Standard, found in the X3F metadata i.e. the correction curve. "If" SIGMA granted us access to that, we could define our own highlight roll-off.
Truth be told, no idea  0-255, 0-255?
DPR have measured Dynamic Range though, so that's the classic S-curve post the correction curve that I've linked to... ? Gosh, my brain isn't working today.
xpatUSA
Now I AM impressed! You dig far deeper than I - and I imagine that quite a bit of work went into that!
<DPR's test curve>
What is/are the LUT/s captioned as in the metadata?
Ted
tagscuderia
I will take a look − I didn't have much luck interpreting it a couple of years back, we'll see if I've progressed
xpatUSA
It's a more recent acronym coined to include all such cameras e.g. film SLR, DSLR, mirror-less,, etc.
I've also seen "MILC" not to be confused with a "MILF" ...
Ted
