AF+MF or How do you use Manual Focus
Started Jul 20, 2020 | Questions
sparky_parrot Forum Member • Posts: 50
Hello everyone,
I'm a hobbyist taking mainly landscape and wildlife shots and doing a bit a video here and there. I'm always relying on AF for my shots, I never use MF.
When doing landscape with short focal I do AF on something a bit further than the hyperfocal and I'm done.
On wildlife with longer focal I usually use single point AF or small 3x3 zone and let the magic happen. I could try to adjust with MF sometimes I'm not just confident enough and also I'm not sure about the settings or how to use it.
(I selected the mode FOCUS PEAK HIGHLIGHT RED (HIGH) with all the red dots, but I really don't know what it means)
My question is related to photo/video and your experience of using  Manual focus or AF+MF, how do you use it if ever so. What would be your advice ?
Note: I have X-T1 and X-T2 bodies, mainly kit 18-55 lens and 100-400
 sparky_parrot's gear list:sparky_parrot's gear list
Fujifilm X-T1 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 100-400mm F4.5-5.6 OIS WR
Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm X-T1 Fujifilm X-T2
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
Re: AF+MF or How do you use Manual Focus
When critical focus is necessary, but visually precise focus isn't clearly apparent, I rack focus back and forth to try to determine when precise focus is attained. When the depth of what's in focus is narrow, focus peaking is most useful. There are situations when f.peaking isn't all that helpful, and magnification alone is better to use. F.peaking used when stopped down to have a greater range of the scene being IN focus - IMO is confounding.
Casually practice with refining focus after you take the AF shot - do it enough and you'll start to get the hang of it, and when you would find it useful (and when not).   You might also try practicing with an object on your desk with a wide open aperture, with and w/o f.peaking enabled.
"Well, sometimes the magic works. . . Sometimes, it doesn't."
------ Chief Dan George, Little Big Man
@ bobtullis.com & flickr.com/photos/bobtullis
My opinions are my own and not those of DPR or its administration.
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
(unknown member) Regular Member • Posts: 360
7
sparky_parrot wrote:
Hello everyone,
Usually best to do it with manual lenses as it is not focus-by-wire. MF is a joy to use with vintage lenses.
When using focus peaking, as the phrase suggests, the camera highlights where the focus peaks. So if it is red in areas, the camera thinks that the red dots are in focus. This is more evident when you have thinner depth of field (closer subject or faster lenses) you can see a thin focus plane moving back and forth as you turn the focus ring.
I usually switch my camera to MF all the way. You can still press the AF-L button to activate the autofocus even on manual mode. This way, when shooting a bird for example (I'm not an expert here), you can press the AF-L to focus on the bird then just keep shooting without activating the AF again.. So it's like, AF -> shutter, shutter, shutter... Instead of AF -> shutter, AF -> shutter, AF -> shutter if this makes sense?
When shooting with a vintage lens, I set the film simulation to Acros and image quality to RAW. The highlight is either red or blue (I prefer blue). This way, you can see the peaking clearly. Then, use the in camera raw converter to change it back to a colour if need be.
Hope this helps!
rlx
rlx Senior Member • Posts: 1,375
Hi,
I can explain briefly why and how I use AF+MF mode.
Why. There are a few cases when MF helps: 1) focus on an eye partly hidden behind thin hairs, or 2) the subject is not flat or not large and AF might settle for the background, 3) set quickly the focus on infinity (set focus ring mode to non-linear in the menus) etc. There are usually many ways to handle special cases with X cameras. MF is one among others.
Two manual focus modes.
  1. The AF-M mode. It is useful for static situations. The iris opens around f/4 when using that mode. After half-pressing the shutter release the focus ring is disabled.
  2. The AF+MF mode. AF+MF works only in AF-S mode AND with single point mode. AF+MF needs to be activated in the menus before it can be used. The way to use it is to turn the focus ring with the shutter release half pressed. Then the focus ring gains the control over the lens. The iris stops down to the shooting aperture. Focusing with the iris stopped down is sometimes useful if the lens has curvature of field. Otherwise AF+MF provides a quick way to switch between MF and AF. Another use case is shooting with the smallest shutter lag whether the EVF is zoomed or not while doing manual focusing.
    There is a small nuisance. One needs to get in AF-M mode to switch peaking between on and off.
Peaking or not peaking. Peaking if the background is far enough behind the subject. No peaking if the surrounding may peak as well and become confusing. And no peaking for some flat subjects with much visible texture; the texture all becoming sharp at once is sometimes better than peaking. So it depends. I feel sharp lenses need less peaking.
You might need to have stabilization on with the 100-400.
Back-button focusing works fine in combination with AF+MF.
Neil Chalk
Neil Chalk Forum Member • Posts: 98
I use third party manual focus only primes a lot, so have got used to MF now
The red peaking will show red lines when an area of the screen is in focus, around the edges. Also make sure that you use the focus assist to zoom in to an area to get a closer look at the area you want to focus on. Not sure the button on the X-T1/2 but on the X-T100 it is accessed via the rear command dial, with two levels of magnification
Hope that helps!
 Neil Chalk's gear list:Neil Chalk's gear list
Fujifilm FinePix X100 Canon PowerShot SX280 HS Canon EOS 450D Fujifilm X-T100 Fujifilm X-T3 +20 more
Neil Chalk
Hope this helps!
That's a great tip!
Morris0
Morris0 Forum Pro • Posts: 32,181
I mostly do what you described though I never use any of the focus assistant modes. The viewfinder on the X-T3 is superb and it's easy to see when I'm in focus when doing manual focus. Those peeping modes simply get in the way of composition which is critical to a good photo.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Sellwood Regular Member • Posts: 186
Do you need to keep the AF-L button pressed down or does pressing the button once and releasing lock it?
 Sellwood's gear list:Sellwood's gear list
Fujifilm X-T3 Canon EOS 90D Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 50-140mm F2.8 +1 more
boogisha
boogisha Senior Member • Posts: 2,858
Re: AF+MF or How do you use Manual Focus - AE/EF-LOCK, INSTANT AF
Which camera, X-T3?
If so, for the very auto-focus/exposure lock functions (AF-L, AE-L), you can configure whether you want the buttons to work as ON/OFF switches (single press to lock, another press to unlock) or have the lock active while the button is pressed down only ("SET UP > BUTTON/DIAL SETTING [2/3] > AE/AF-LOCK MODE[1]").
In regards to auto-focus in manual mode (called "instant auto-focus", "AF/MF SETTING [2/3]] > INSTANT AF SETTING[2]"), it depends on whether you select single ("AF-S") or continuous ("AF-C") mode there - in both cases single press will (try to) focus and lock, but holding further with "AF-C" selected will do so continuously.
 boogisha's gear list:boogisha's gear list
Canon PowerShot A75 Canon ELPH 300 HS Canon PowerShot S120 Canon PowerShot G7 X Fujifilm X-E1 +15 more
