XF 18-55mm vs XF 16-80mm field of view comparison (simulated)
Started Jul 14, 2020 | Discussions
boogisha
boogisha Senior Member • Posts: 2,858
15
I have XF 18-55mm f/2.8-4.0 lens, and I am contemplating getting XF 16-80mm f/4 for quite some time now, taking over "no lens swap" (+ travel) role.
All other things aside, I was also curious in field of view differences between these two lenses, so I`ve made a simulated comparison.
Posting it here for whomever might find it useful, too.
p.s. Sample image is one of my (straight out of camera) photos, nothing special, but I found it useful for the purpose. Time allowing, I might post more examples in the future.
#1, 16mm frame with 18mm, 55mm and 80mm framelines
#2, Same size, zoom range from 18mm to 55mm (with 80mm framelines) and 16mm (with 18mm framelines) to 80mm
 boogisha's gear list:boogisha's gear list
Canon PowerShot A75 Canon ELPH 300 HS Canon PowerShot S120 Canon PowerShot G7 X Fujifilm X-E1 +15 more
Steve Bingham
Steve Bingham Forum Pro • Posts: 27,683
Re: XF 18-55mm vs XF 16-80mm field of view comparison (simulated)
Why? Shoot what you have and LOVE it. There will always be pluses and minuses.
Steve Bingham
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon Coolpix 990 Sony RX100 VII Nikon D810 Nikon D7200 Nikon AF Nikkor 85mm f/1.8D +33 more
boogisha
OP boogisha Senior Member • Posts: 2,858
Re: XF 18-55mm vs XF 16-80mm - why?
5
Why... is there a difference between 16mm, 18mm, 55mm and 80mm field of view? (as that is what this topic is about, after all )
I wasn`t discussing any pluses/minuses (and purposefully), but merely showing the field of view comparison, from 16mm, through 18mm and 55mm, all the way to 80mm.
But let me humor you (as I guess you`re asking why would I want to swap 18-55mm for 16-80mm) - because I find 16mm more useful on the wide end, and I would definitely appreciate 80mm at the long end (all the other things aside still). So... convenience? Shoot me!
Otherwise, I don`t mind shooting with (all manual) 35mm f/0.95 (Mitakon) all day long, and I`m loving it, all right But that`s beside the point here.
bastibe
bastibe Senior Member • Posts: 1,236
Useful comparison, thank you! It's always good to do these experiments, as I find it way too easy to fall into the trap of just assuming that 16 will be "way better" than 18, when in reality the differences are rather small.
In game design, they advise you to always change parameters by at least a factor of two if you want to see tangible results.
 bastibe's gear list:bastibe's gear list
Ricoh GR III Fujifilm X-Pro2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
jhorse Veteran Member • Posts: 5,913
Hi, thanks for the time to do this. Interesting. For me, as one with two zooms starting at 16 (16-55) and one at 18 (18-55), for a subject at this distance in a more rural setting, the difference is small. However, in a urban environment, or in large mountainous scenes, the difference in the angle of view might be more telling.  In this case, if you were often taking urban images, then the case for a 16mm zoom is more compelling.
At the other end, it confirms for me that one can crop. Today's sensors are good, so a degree of crop-ability is possible without undue image degrading. I use a rule of thumb of up to 25% max crop as my guideline. So in this case for my needs there would be no compelling reason to get a 80mm zoom over a 55mm one.
Since I got a 16-55mm zoom, I have seldom used my 14/f2.8 and I have been wondering about whether the angle of view is sufficiently different to keep it. I have been meaning to do a similar test to yours between the two lenses, so you have spurred me on to do it.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
a_c_skinner Forum Pro • Posts: 13,047
That is beyond doubt the most sensible, only sensible, reply to the numerous questions on here about "marginal" gear swaps that prey on members minds.  This is (alas) a gear orientated forum and people make the mistake of thinking because the forum is about gear that photography is too.
Bravo.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
bastibe
On the long end you can crop, and on the wide end you can stitch. I often shoot panos if I want a wider field of view. Or I shoot a zoomed-in pano if I want a wider aperture. A three-image APS-C pano produces the same picture as a FF sensor.
At least so long as there is no significant movement in the shot, of course.
Yes, you are right. I had forgotten the stitching technique. I have just bought into Capture One 20, and am learning it, but have yet to get to stitching. Good point.
biza43 Forum Pro • Posts: 15,074
Bravo.
So you don't think that 18-55 and 16-80 lenses are very different in terms of focal length?
Photography is a lot about gear, or do you take photos without cameras and lenses?
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
(unknown member) Regular Member • Posts: 360
Don't forget the XF 18-135mm which is the original one lens solution. Would be cool to see 135mm as an overlay on the picture as well but I can imagine most people would go for the 16-80mm over the 18-135mm any day.
jtr27
jtr27 Veteran Member • Posts: 3,328
Yes, as long as nothing in the shot is too close to the camera. An ultra wide field of view can be created by stitching, but that's not necessarily the same thing as an effective and visually compelling ultra wide composition.
This notion of stitching gets tossed around rather cavalierly, IMO. I would love to see someone, anyone, take a good ultrawide shot, say at 10-12mm, and then recreate it with the 18-55 or anything else.
TonyGN10 Contributing Member • Posts: 645
Hi - just in case you weren't aware, I'm afraid Capture One 20 doesn't have pano stitching capability - I use Affinity Photo with C1 for that - other apps that can stitch and work with C1 are available though
 TonyGN10's gear list:TonyGN10's gear list
Fujifilm X-T4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Samyang 12mm F2.0 NCS CS XF 90mm Fujifilm XF 33mm F1.4 R LM WR +6 more
jtr27
I find your response to be a bit puzzling, and a bit condescending as well.  Are you implying that the OP is not shooting what he has?  Or not LOVING it?  Is understanding one's gear, including its pluses and minuses, somehow antithetical to enjoying it?
Pan50 Contributing Member • Posts: 673
Hmmm, when I travel I shoot with my XH1 and the 27mm pancake lens. Reasonably compact package. Who wants to drag around a big ol’ 16-80 lens?
 Pan50's gear list:Pan50's gear list
Fujifilm X100S Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +9 more
What you use has no bearing on the choice of others. I have travelled with the 16-55 zoom for example.
At the wide end, not very different.  At the long end obviously but Steve's comment is still good.
Andrew Skinner
fahdeen New Member • Posts: 15
Hi. Thank you for this. I have been looking for this type of comparison for some time. now i wish this same was done for the prime lenses. especially the new ones. there was a fuji site but they did not have the newer ones.
keep up the good work!
 fahdeen's gear list:fahdeen's gear list
Fujifilm X-T2 Canon EF 50mm F1.8 II Fujifilm XF 18-55mm F2.8-4 R LM OIS Apple iPhone 7 Plus Apple iPhone X
boogisha
Re: 18 vs 16 field of view comparison (simulated)
Under assumption you meant to reply to me - you`re welcome, I was curious myself, and I`m glad if anyone else finds the (simulated) comparison useful
Though, "centered" 18mm framelines might influence perception that difference is smaller than it really is - here`s a bit different framing:
#3, 18mm framelines bottom right aligned with 16mm field of view, showing all the extra space on the left and top sides
Is it groundbreaking? Certainly not - but to be fair, this specific scene is not the best example, either, as there`s nothing interesting in the part left out in 18mm field of view, either.
In some other scenarios, it might mean squeezing in an extra person (or more), or just providing a less than "snug" fit for the main subject(s) (possibly allowing for different aspect ratios, too, without being restricted by image boundaries too early).
boogisha
You`re welcome, I find it interesting as well, and your note about some other scenarios being yet more favorable towards 16mm is well placed. Small apartment with a group of friends could be another example.
While this is true, it can also be used as a counter-argument - with same amount of cropping, 80mm will "simulate" longer focal length still
Looking forward to it, especially as difference between 14mm and 16mm should be even more noticeable than between 16mm and 18mm.
boogisha
Bravo.
Right. And totally misplaced one, in terms of what the topic here is. Bravo, indeed.
