AD200 add a second flashhead to the cable?
Started Jul 14, 2020 | Discussions
2482 Regular Member • Posts: 248
[Mod: post moved to appropriate forum]
I want to cut the cable and spilt it so that its only one cable and one AD200 is used. Though with two flash heads.. Save weight. I use this for one flash under the camera and one on Hotshoe.....
double flash set up........ with the trigger on the hotshoe too. Is it easy to do?
On another forum, a boy was trying to explain. Though lost me.
I have it in my head that this can be done. Even cut the cable to see and ordered a new spare. So will try. bought a soldering kit and helping hands.
Reason being I need two heads. Not really 400ws. 200ws will do most of the time.
two cables is a bit awkward to handle. Plus two flashguns is heavy for street.
I thought it might just be three wires or so. turns out to be 5.
Please make it easy.. Thanks
be good to have a spare wire live for when I get hassle. Check my web site see what I mean. Done several Photo books with a double flash. Even won the Magnum photo agency award with my double flash set up.. That was two T32s Olympus from the 80's. Lowest power was 5.6 so not so versatile.
www.dougiewallace.com
 2482's gear list:2482's gear list
Fujifilm X100S Sony RX100 II Sony Cyber-shot DSC-RX10 Leica Q Olympus E-M1 +3 more
tugwilson Veteran Member • Posts: 3,870
Re: AD200 add a second flashhead to the cable?
You need to ask the question here .
