Fine tune jegs on x100v
minim3 Senior Member • Posts: 1,010
I really like the classic chrome on the jpeg files,but they seem a bit dark in shadows,any imput to what settings you have?
I doing RAW+Jpeg as im not surr about the settings or modes for jpeg,still testing...
thanks in advance!
Fujifilm FinePix X100 Fujifilm X10 Leica X1
DarnGoodPhotos Forum Pro • Posts: 10,280
Re: Fine tune jegs on x100v
If you think the shadows are heavy, just turn them down in the Q menu. It's all subjective as to what is great.
Here is a nice assortment of recipes:
https://fujixweekly.com/recipes/
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XC 16-50mm F3.5-5.6 OIS +2 more
OP minim3 Senior Member • Posts: 1,010
I did not see the shadow settings in “q” menu,ill have s look as they are too black yes,thanks a lot...
You can also customize what is in your Q menu.
Sherman90 Regular Member • Posts: 101
Dive into this world:
It'll help you understand what amazing things your Fuji jpeg engines can do.
 Sherman90's gear list:Sherman90's gear list
Ricoh GR II Fujifilm X100V Sony a7 III Sony a7R IV Sony FE 55mm F1.8 +4 more
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,895
All of the slide-film simulations are hard on shadows, as the original slide films were. Classic Chrome is particularly hard on shadows, and Velvia is extremely hard on them. The strong contrast and "inky black shadows" were a desirable feature back in the day, so maybe you might try just going with it.
If not, you've got the Shadow Tone control. Set it negative to reduce the harshness of the shadows.
I think the X100V works with Fujifilm's X Raw Studio software. X Raw Studio lets you use your camera -- tethered to your computer -- to process Raw files as you make adjustments so the results are exactly what your camera would produce. You could pick a few Raw photos and play around with the adjustments to see what you like.
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
Wow that is really helping me out,many thx!
You're welcome. Remember that clarity will noticeably slow down saving a photo.
Thanks for the advise,ive just touched shadows... but I’ll bare it in mind!
