Canon 85mm f2 macro IS vs Samyang 85mm f1.4
Started Jul 10, 2020 | Polls
Francis A
Francis A Regular Member • Posts: 150
With the canon coming in at 599 against samyang's 699 (B&H price), which one would you get?
 Francis A's gear list:Francis A's gear list
Canon EOS RP Canon EF 24-105mm f/4L IS USM Canon EF 50mm F1.8 STM
POLL
Canon RF 85mm f/2 Macro IS
71.7% 33  votes
Samyang RF 85mm f1.4 non-IS
28.3% 13  votes
  Show results
mrphotography Regular Member • Posts: 128
Re: Canon 85mm f2 macro IS vs Samyang 85mm f1.4
Samyang can't compete, I wouldn't touch their glass at those prices.
 mrphotography's gear list:mrphotography's gear list
Olympus OM-D E-M1X Canon EOS RP Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro
tkbslc Forum Pro • Posts: 17,522
5
Why would you say it can't compete?
Samyang has:
  • weather sealing
  • internal AF
  • full stop faster
  • very sharp with great bokeh (based on Sony version)
  • all for similar length and weight as the 85mm f2
Canon has:
  • IS
  • Macro
  • tiny bit cheaper (although the Sony mount Samyang is often on sale for $599)
EYNG Junior Member • Posts: 29
Samyang has:
  • weather sealing
  • internal AF
  • full stop faster
Canon has:
  • IS
  • Macro
Canon is 82g lighter. I am getting one of them but hard to decide yet.
Hope we can have the review for 85 F2 soon.
 EYNG's gear list:EYNG's gear list
Canon EOS RP Canon EF 50mm F1.8 STM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
Samyang has:
  • weather sealing
  • internal AF
  • full stop faster
Canon has:
  • IS
  • Macro
I consider 500 and 582g to be “similar weight”
I’ve got the 85 1.8 on an adapter and would like to upgrade to something native mount.  Samyang isn’t shipping yet either
Samyang has:
  • weather sealing
  • internal AF
  • full stop faster
Canon has:
  • IS
  • Macro
Me too!
EF 85 1.8 's price is really low now but no IS. (I am using RP no IBIS..)
Wing2 Contributing Member • Posts: 512
Canon has one more feature which I believe Samyang does not have, the control ring
Another consideration is Canon typically has better resale value than 3rd party lens
rmexpress22 Senior Member • Posts: 2,304
Do you want 1.4, or do you want .5 macro? That's what it comes down it. If the Samyang's AF is good enough, I'd go that route since I'm a portrait shooter. I have the 35mm efs for the occasional macro.
It depends on what you shoot.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
EYNG wrote:
Samyang has:
  • weather sealing
  • internal AF
  • full stop faster
Canon has:
  • IS
  • Macro
Me too!
fortunately the f1.8 aperture helps keep shutter speed above 1/100 where IS would not really be needed.
ntsan Senior Member • Posts: 1,029
Samyang's AF sucks for video, so Canon all the way.
 ntsan's gear list:ntsan's gear list
Nikon Coolpix 5400 Canon EOS R5 Canon EOS R7 Sigma 18-35mm F1.8 DC HSM Art Canon RF 50mm F1.8 STM +4 more
sobrien
sobrien Senior Member • Posts: 1,756
Samyang has:
  • weather sealing
  • internal AF
  • full stop faster
Canon has:
  • IS
  • Macro
  • Availability of optimised lens corrections (DLO) in jpeg and for raws with DPP4.
I’ll be having a close look at both of them in due course. Suspect the Canon will prove more appealing though too soon to tell.
"The simple things are also the most extraordinary things and only the wise can see them."
https://www.flickr.com/photos/135843555@N03/
 sobrien's gear list:sobrien's gear list
Canon EOS R Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon Extender EF 2x III +16 more
NowHearThis
NowHearThis Veteran Member • Posts: 4,591
RF85/2 | I keep reading mixed reviews on the Samyang
I'm more interested in the RF85.  For me, I'm sure the 85/2 will provide plenty of subject separation from the background with nicely rendered out of focus areas. Some of the images I've seen look (albeit not full resolution) great.  Having the control ring on the RF lens would be more beneficial to me too - especially if I'm used to it on one lens (like the RF24-105/4), I don't have to change my shooting and dive into a menu or quick menu if I use the Canon but would with the Samyang.
The other reason I would pick the Canon over the Samyang is because I see to many conflicting reports on the Samyang and for some of the reviews it seems like I'd be stopping the lens to F2 at least anyway.
Here's 4 quotes from 4 different websites:
"Centre-sharpness isn’t overly impressive at f/1.4 but is rather better at f/2 and excellent from f/2.8 onwards. Edge- and corner-sharpness are comparatively poor."
"Sharpness is acceptable when shooting wide-open at f/1.4, very good at f/2 and outstanding from f/2.8 onwards, although the edges aren't quite as sharp as the centre, with f/2.8-f/11 producing the sharpest results."
"Central sharpness is excellent all the way from f/1.4 through to f/11. It is still very good at f/16. The edges are very good at f/1.4 and f/2, excellent from f/2.8 to f/8 and very good from f11 to f/16."
**Review of the Samyang AF 85/1.4 for EF** (I'm assuming the optical formula is the same)
"MTF (resolution) on the EOS 5Ds R (at 50 megapixels)
The Samyang AF 85mm f/1.4 EF is a lens with two souls. If you check the sample image section, you will notice that is dead sharp at near infinity settings. However, the performance isn't quite as good as shorter focus distances. Our test was performed from a distance of 3.5m. This is far from being a macro scenario and roughly equivalent to an upper body portrait taken with this. The drop of quality was already quite obvious as you can see in the charts below. The dead center quality is (just) very good at f/1.4 but the near center is already down to good quality here. The outer image field is soft. Stopping down to f/2 doesn't change much. There's a slight increase in quality at f/2.8. The peak performance is reached between f/4 and f/8. The broader center zone isn't bitingly sharp but certainly sufficient even for demanding users. The borders/corner remain just fair though. As usual, negative diffraction effects set in from f/11 onward.
For the sake of comparison with our legacy tests, we are supplying MTFs taken at 21 megapixels below. This is far from being as demanding as the MTFs based on a 50-megapixel sensor. Even so, the results aren't overly impressive compared to other prime lenses. The corner/border weakness remains at large aperture settings albeit it isn't quite as pronounced anymore. Stopping down shows the same gradual increase in quality. The center quality is excellent between f/4 and f/8 on this sensor and the outer image field is at least good to very good here."
People will have their own reasons for choosing either, you will need to prioritize what matters more.  And it might not be a bad idea to test them out first if you can, even if that means renting them (if that's possible).  Good luck.
NHT
 NowHearThis's gear list:NowHearThis's gear list
Panasonic Leica 12-60mm F2.8-4.0 ASPH Olympus E-M1 III Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 42.5mm F1.7
Do people AF during video?  Even on lenses with silent and quick AF it still looks awful to me to have focus move around during video clips.
Re: RF85/2 | I keep reading mixed reviews on the Samyang
It's not the same. It's the same as the Sony E version. Dustin Abbot and Christopher Frost are the only two reviews of the new RF version that I have found and they say it's an outstanding lens.
Dustin Abbot compares it with the RF 85 1.2L and says it is "surprisingly competitive", "quite sharp from f1.4 on" and "near perfect for portrait work".
He also said he was not as happy with the EF version.
Christopher Frost's video summary was, "I love it".
That's true, but you can use that to your advantage if you buy the 3rd party lens second hand and let someone else take the hit!
johncal Contributing Member • Posts: 585
And you know that how? I own the Samyang AF 14mm F2.8 RF mount lens and the Autofocus is lightning fast and dead silent. The image quality is fantastic and it's built like a tank. Negatives are no IS or Control ring, but I don't need either, just a good durable lens at a low price.
 johncal's gear list:johncal's gear list
Canon EOS 70D Canon EOS R Canon EF 50mm F1.4 USM Canon EF 28-135mm F3.5-5.6 IS USM Tamron 28-300mm F3.5-6.3 Di VC PZD +8 more
Yes, most Vlogging needs AF to get satisfactory results.
One of the cool feature of R5 and R6 is the smoothness of AF change during Video shooting is programmable. You can select between fast AF that gives kind of abrupt but fastest focus change or different degree of smoothness for more gradual but slower focus change
Going to be hard to fit your whole face in the frame when vlogging with an 85mm!
I suppose some kind of digital focus pull could be useful in certain cinematic situations, but I'd maintain in general, video should be done with manual focus to avoid distracting shifts.
At any rate, I'm not sure why we'd think the Samyang would be worse.  It has an silent internal AF system.
tobicy68 Contributing Member • Posts: 700
Any 85/1.8 and/or 85/1.2 owner here gonna wait until more reviews come out to decide whether to keep using our EF lens or go RF?
I have a 85/1.2 mark I and am thinking of going smaller and lighter but also in no hurry because I already have a 85 I am using. I've also heard some people deciding to just keep using the 85/1.8 because it's just a lot cheaper than either the new Canon and Samyang for them it just doesn't justify the extra price.
 tobicy68's gear list:tobicy68's gear list
Canon EOS M100 Canon EF 85mm F1.2L II USM Canon EF-M 22mm f/2 STM Sigma 18-35mm F1.8 DC HSM Art Canon EF 50mm F1.8 STM +1 more
poipoipoi_2016 Senior Member • Posts: 1,158
As someone with the E-Mount version, the sunstars are trash and I love it for everything else.
If the RF-mount version avoids the early AF issues and you get a good copy, it's an astounding lens that's on the lighter end of my usual zoom kit, but also my heaviest/largest prime.
/Not a bad thing as I stabilize on 67/77/82mm lenses and use 2 step-up rings.
 poipoipoi_2016's gear list:poipoipoi_2016's gear list
Sony RX100 V Sony a7R III Sony a7R V Sony 1.4x Teleconverter (2016) Sony FE 100-400mm F4.5-5.6 +9 more
