Will new 600 and 800mm lenses autofocus on R/RP?
Started Jul 9, 2020 | Discussions
Jon555 Veteran Member • Posts: 7,714
Re: Yes and no
RDM5546 wrote:
Jon555 wrote:
rrc1967 wrote:
Jon555 wrote:
quiquae wrote:
John Sheehy wrote:
quiquae wrote:
Jon555 wrote:
They will definitely AF as-is, f/11 is fine for all DPAF, but I doubt you'll be able to add the extenders, especially the 2x, and have AF work (other than with a R5 or R6 that is).
Actually, I think you're wrong about that. Canon's official product pages for the extenders are now up, and they don't say anything about the extenders not working on R or RP.
It's not about the TC itself where there may be an issue; it is about the resulting open f-number. Canon says f/22 works on the R5 and R6, meaning that AF is reasonably fast and reliable by some standard. It is possible that the same f/22 will be more difficult for the R and RP, with more hunting in low light and low contrast.
EOS R actually has exactly the same low-light focusing spec (EV -6 @ F1.2) as R5, and only half a stop behind R6 (EV -6.5), which suggests that it shouldn't lag much the newer bodies in low-aperture focusing, if at all. But we'll see.
The question is will the R and RP focus at f/22, and I've never heard anything vaguely like that mentioned (just f/11, e./g. see the quote below). The issue is the size of the aperture rather than the amount of light you are getting.
"The AF points on the EOS R are compatible with maximum aperture f/11 at all AF positions (when used with a compatible lens and extender, such as the EF100-400mm f/4.5-5.6L IS II USM lens paired with a 2x extender). This makes AF possible even when shooting at a super-telephoto 800mm, dramatically expanding shooting possibilities for wildlife photographers."
F22 probably not. however, F22 is with a tele extender. F11 probably yes.
I seem to recall F16 being a limit, but to be honest after a while at this over the past week i'm lucky to remember my birthdate.
It still counts with an extender, take a f/5.6 lens and add a 2x you get f/11 and it won't AF on a DSLR that AFs to f/8.
AFAIK all Canon live-view went to f/11 (and possible a teeny bit more, 1/3 - 1/2 stop) prior to these cameras.
I was curious about the existing performance of the EOS R I now own. The EOS 5D mk IV only would focus or even try down to an f8 lens.
The EOS 5D only works with my f4 and f2.8 zoom lenses using my EF 2X iii , EF 2X and Sigma 2X extenders. For smaller aperatures it does not even try to focus. I only recently learned that my EOS R gives new life to smaller aperatures with the 2X extended lens. They work well at f5.6 and the 2X extender, f11/12 is a useful aperture on bright days.
The 2X iii is softer than the 1.4X extenders that I use more frequently but it still is useful if it can make the shot. Sometimes cropping the 1.4X is better though.
Some forum members may gag but I stackered two 2X extenders which is not easy to do. Both the 2X II and the Sigma 2001 2C have a small front so it is possible to stack behind the Canon EF 2X iii to create 4X to try with the EOS R to see how far it goes with small aperatures. I used it with my EF 100-400mm at 400mmm f5.6. The focus is not real fast but the EOS R does focus the 1600mm f22 attrocity.
I then tried the Sigma 150-600mm using the two stacked 2X TCs at 600mm f6.3 making a 2400mmf25.2 long lens. Amazing it still tries to focus and sometimes it locks on. I shot a picture of a brightly illuminated section of a distant palm tree successful. It want not crazy sharp but not real horrible especially for such an experiment. However, darker region of tree not in sunlight did not lock on focus.
My take away from this trial is the EOS R works well at low light and is better at using my 2X TCs than my EOS 5D Mk IV. I am sure this is only nonsense to the 100 ISO or bust sunrise shooting crowd. I am hoping the EOS R5 will have lower sensor noise shooting ISOs above 1600 like 3000 or 4500 ISO and make better shooting possible with longer , lighter and cheaper lenses having smaller apertures.
BTW I have stacked 1.4x and 2x extenders for ISS photography... they only go one way round though.
Also the 5DIV will focus to f/11 (at least ) in Live View mode.
Thanks for doing the testing... (I suspect Canon have some criteria for what is acceptable focusing, and it sounds like you're not getting there, but anything at all can be useful sometimes).
 Jon555's gear list:Jon555's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +31 more
RDM5546
RDM5546 Senior Member • Posts: 3,654
Re: Yes and no
Thanks for pointing out the operation of the 5DIV in live view.  I keep forgetting to try live view because for fast action I only trust the OVF and hopefully the EVF in the R5 when I use it.   I love the 5DIV and it is one my best action/wildlife cameras and my favorite of cropping small birds in motion.
The EVF in the the EOS R is more limited to slower wildlife or action but it sure focus nice as does the 5DIV when using the live view and rear screen.    The rear screen is not favorite for action though.
I have EF 1.4 and EF 1.4 iii as well as Sigm 1401 1.4 for three 1.4 total.  I prefer Canon TCs on Canon EF and Sigma TCs on Sigma EF lenses.     In 2X I have the same three series of TCs.
I do not have the EF 2.0 ii which I seen will work like the Sigma 2001 behind the EF 2X and 2Xiii TCs to stack for 4X TC.   The reverse sequence does not work
I tried before to use the EF 1.4X i & iiI TC to stack with the EF 2X i & iii TCs but not will work to stack.      I never bought the 1.4X ii or 2x II because I think they were better than what I had.  I am not sure the newer iii models are observably better than the original i  versions but a few forums have sworn so so I bought the iii upgrades in moment of weakness just like the weakness that drove me to use the Sigma TCs with Sigma lenses especially the heavy Sigma EF 120-300f2.8, 6.5 pounder really must be used on a monopod for lengthty shooting.
EOS R5 with AF II looks to be specs wise excellent for TCs and big lenses and crazy cropping of actions shots.  Hands on shooting is the real test.  I can not wait to try in on a red tailed hawk during a dive or high school football/basketball games.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
rrc1967 Senior Member • Posts: 1,984
Re: Yes and no
I did a MTF comparison article on the 600 and 800. while I can see the 600 - it does fall short of the 100-500, though a lot cheaper, lighter, etc.
however, the 800mm in my mind is a clear win over the 100-500 + 1.4x TC if you are always jammed up against the telephoto end.
RDM5546
Re: Yes and no
Did you have hands on access to the RF100-500?  What is the f number when the lens is at  400?  Is the f number of the RF100-500mm more or less than f5.6 at 400mm?
I am not surprised the RF 800f11 is better IQ than the more expensive zoom + the expensive 1.4X TC.  The zoom plus TC can zoom which is handy to enable you to use the zoom capability to find the subject at low focal length and then with the subject put in the center to frame to the 800mm equivalent FL.
This handy finding  by zooming can not be done with smaller,lighter and cheaper RF800 lens.  However small, light and cheap does sound good to me too.
Re: Yes and no
Hah. I wish. any testing of R's won't happen until the R5s though.  Even then, I pulled back on testing because I wasn't happy with the repeatable quality of the results, there was just too much measurement error that was mathematically unexplainable.
someone stated it's "around" 5.6 - supposedly 5.8.
I was. I mean we're talking $899 versus $3100 or so.
if say 80% of your shots are at 700mm with the TC, then get a 24-105 and a 800mm and call life good
Re: Yes and no
I have the mk II versions on the extenders. I think the 2x III seems a worthwhile improvement, although the 1.4x III doesn't seem much different. I just decided that as 2x was never fabulous I'd stay with what I had.
I hadn't thought about whether you could stack the I or III versions.
BTW the problem with the ISS is it's really teeny, hence I'm playing with stacking extenders, even with a 5Dsr and 800mm this is a pixel-level crop (I'm still working on exposure):
RDM5546
Re: Yes and no
Today I took more pictures using the EOS R with the Sigma 150-600 and the Canon EF 2X iii TC with the Sigma 2X 2001 TC stacked. The two TCs form a 4X TC (usually a horrible idea perhaps) and will add to the Sigma 150-600mm four f stops. When the Sigma is at 600mmf2.3 this combineation 2400mmf25.2.
Pretty dark you say? Here is an actual picture using two stacked 2X TCs.  I was surprised with hour the f25.2 2400mm lens worked so well in the the bright outside afternoon daylight
Note the transformer label on this power pole about 65 yards away from the shooter
1/500th f13 ISO 2000 (2400mm equivalent f25.2)
Compare with the same lens with only a 2X TC (the Sigma 2001)
1/2000 f13 at ISO 2000 (1200mm equiv f13)
This one is at 300mm with the Sigma 155-600 and a the Sigma 2x 2001 TC
1/500th f10 ISO 2000 (600mm equivalent FL f10)
John Sheehy Forum Pro • Posts: 26,688
Re: Yes and no
AF ability is not just about light quantity. It can be heavily dependent upon light geometry; the different angles from a which a source point hits different parts of the entrance pupil and reconverge at the sensor.
So, turning up the light can't compensate for losses in AF ability due to high open f-numbers.
Just about any DSLR, for example, can focus better on big black and white lines at f/5.6 indoors than at f/11 pointed straight at in direct sun, despite much higher light levels on the AF sensor for the latter.
Leonatwm New Member • Posts: 5
Re: Yes and no
Where did you focus at? If you look at the latch, it is the sharpest in the 300mm with 2x converter picture and fuzziest in the 600mm with two 2x converters picture.
Anyway, thanks for the info that EOS R autofocuses at F/26! That is very good to know!
