Using an M100 as a webcam
Started Jul 9, 2020 | Questions
theopwildebeest
theopwildebeest Regular Member • Posts: 225
Does anyone have an EOS M100 that they are using as a webcam for  Zoom, Skype, or FaceTime? The new Canon utility does not support the M100. I have looked everywhere for software solutions (on a Mac) and the only one that I found is made by Cascable. First I could not get it to recognize the camera. Then, after tweaking it, I got the camera recognized but there was no picture. Then, after disconnecting, I can not get it to reconnect.
Looking for something software related. I'd prefer not to buy more dongles or cables.
Thanks for your time.
 theopwildebeest's gear list:theopwildebeest's gear list
Nikon Z7 Nikon Z5 Nikon Z 24-70mm F4 Nikon Z 24-70mm F2.8 Nikon Z 40mm F2 +2 more
Canon EOS M100
Chris5437 Junior Member • Posts: 48
Re: Using an M100 as a webcam
I have previously setup an M3 as a webcam but after an April 2020 zoom update the workaround no longer functions. It may still work on Skype and Facetime.
You need 2 pieces of software and the correct cable.
  1. Install Camera Live.
  2. Open the 'camera live' folder, it should automatically put the 'camera live' icon on the desktop.
  3. Open the camera live program. It is just a really simple box. You don't need to do anything.
  4. Now connect the camera to the laptop and turn it on. It should appear automatically in the 'camera live folder',. You don't need to click anything. This just confirms that it is connected and functioning
  5. Next, install the 'CamTwist' software. Open the main file. Then in the folder right click (2-finger click) the 'camtwist.pkg' file. Then select 'open with' and 'installer (default)'. You will see a warning, don't worry its ok. Click open. Proceed with installation.
  6. Open the CamTwist software and follow my instructions in the picture below
  7. Note, if 'CamTwist' opens with a window called 'cam twist studio' you can just close it. If you want to see a preview of what it looks like, when in camtwist, click on 'View' in the top bar and then 'preview'. It just gives a small preview window to help line things up. I think its better to just use Zoom to preview.
  8. You will need to change the setting in Camtwist, particularly the selected maximum resolution.
I'd be interested to know if this still works. I have an M6ii now so don't need this workaround.
 Chris5437's gear list:Chris5437's gear list
Canon EOS M6 II Canon EF-M 22mm f/2 STM Sigma 150-600mm F5-6.3 | C Sigma 30mm F1.4 (E/EF-M mounts) Canon 70-300 F4-5.6 IS II
theopwildebeest
OP theopwildebeest Regular Member • Posts: 225
Thank you so much. I will give it a try and let you know!
theopwildebeest
I gave it a try. Immediately after showing up on Camera Live as connected, the Camera Live programs shuts down and then restarts. Once it restart, the same happens again. Tried an older version and this happens too. Looks like the M100 is not webcam material. Really sad as its a great size for it.
Thanks for the suggestion.
lumenite Senior Member • Posts: 1,208
According to the website, Camera Live does not support M100, but M200.
https://github.com/v002/v002-Camera-Live/blob/master/CAMERAS.md
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
Albert_L Forum Member • Posts: 84
Just an update I've learn from another group, seems with a current script, M100 as webcam / streaming is now possible with no shut down limit.
https://youtu.be/4GBQBLQeKUk
 Albert_L's gear list:Albert_L's gear list
Canon EOS M100 Canon EF-M 22mm f/2 STM Canon EF 50mm F1.8 STM Canon EF-M 15-45mm F3.5-6.3 IS STM 7artisans 12mm F2.8 +2 more
BrandonAllenson New Member • Posts: 1
I tried it with my M100 and it seems to work, just make sure you use the 13 (alpha) build for the camera live because when I tried it with the other versions, build 11, etc... It didn't work. Hope this helps.
Here's a tutorial on YouTube about doing this - https://youtu.be/czZNuZz5FYc
theopwildebeest
Thank you. I'll try it again.
SPIN M100 New Member • Posts: 1
Do i need to buy a usb to hdmi adapter for this to work ?
