Reliabilty of m43 mirrorless cameras
Started Jul 8, 2020 | Discussions
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
8
I now have four m43 cameras that have been seriously overworked from as far back as 2009, the original G1, GX7, GX8 and Em1-mk2.
I have taken about a zillion shots with each, but they have all failed to let me down or break. What should I do ?
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Sony SLT-A77 Olympus E-M1 II Panasonic Lumix DMC-G1 +1 more
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
Albert Valentino Veteran Member • Posts: 9,768
Re: Reliabilty of m43 mirrorless cameras
If it ain’t broke, don’t fix it
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 Panasonic 8-18mm F2.8-4 +10 more
YWG Senior Member • Posts: 1,364
Start another Olympus is doomed thread?
I am looking at my ancient 14-54mm mkI. I think I must be the 3rd or 4th owner and the focus ring rubber has gone to melted tar. Picking it off gingerly like  a scab but the optics and other mechanics work fine. I guess it is a bit of luck as I know others have had ribbon cable failures over the years.
All my m43 cameras and lenses have lasted despite my abuse. E-M5 mki fell out of a helicopter, down river banks, on the trail. My 12mm doesn't look so good but still works and I think got a little sharper too (recentred)!
Same with my Canon gear. My 30D is 16 years old and resides with my little brother now. It doesn't get used often but did get a good workout under my reign!
 YWG's gear list:YWG's gear list
Canon PowerShot G5 X Olympus Stylus 1s Olympus E-M1 Olympus E-M1 II
Sranang Boi Senior Member • Posts: 2,860
You need to switch to FF is you want to buy a new camera every year.
 Sranang Boi's gear list:Sranang Boi's gear list
Panasonic Lumix DC-FZ1000 II Panasonic Lumix DMC-GX8 Panasonic G90 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +1 more
JDLaing50 Veteran Member • Posts: 3,169
5
Smash them with a hammer in protest.
 JDLaing50's gear list:JDLaing50's gear list
Sony RX1R II Leica M-P (Typ 240) Olympus PEN-F Panasonic Lumix DC-S1R OM-1 +12 more
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
A couple of years ago, an Oly E-PM1 - bought for some £40 - arrived with its date/time system not working, and unreviveable.... and my second GF7 [irresistible recently at £100] turns out to have a slight tilt in its Level Gauge.
Although hardly overworked, all of the other 8 or 9 were / are just fine... give or take me being unable to forgive Panasonic's decision to pair the GX1 with their 14/42PZ - which almost ended my M43 adventure in its infancy!
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus PEN E-P7 Olympus OM-D E-M10 IV
MHshooter
MHshooter Senior Member • Posts: 1,010
7
It's too late.  By not upgrading enough, you helped to kill Olympus.
techie takes pics Senior Member • Posts: 1,730
They failed to let you down.
They did not break as expected.
You need to take action. The human mind is not built to deal with such discrepancies.
Take that M1.2, put a lens on it for good measure, and hose it down.
 techie takes pics's gear list:techie takes pics's gear list
Olympus OM-D E-M10 II Olympus E-M5 III Olympus PEN E-P5 Olympus 40-150mm F2.8 Pro Olympus 12-40mm F2.8 Pro +8 more
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
smile and keep on shooting
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus 12-45mm F4 Pro Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +1 more
Hosing down an Olympus camera won't destroy it unfortunately.
millardmt Regular Member • Posts: 494
I would have sent them all back while still under warranty.
Lifesucks Contributing Member • Posts: 906
Damn it mines only got a trillion shots on it....
jf_tea Senior Member • Posts: 1,577
EM5 died after 45K shutter activations
I bought it in 2012. Took 45K pictures -- much less than gazillions
it died suddenly and never wanted to power on ever again.
All my other M4/3 cameras are fine, even the older GX1 and the GF1 that I had before and sold to a friend.
-JF
 jf_tea's gear list:jf_tea's gear list
Panasonic Lumix DMC-GX1 Pentax K-01 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +6 more
HRC2016 Veteran Member • Posts: 6,874
Oly = reliable
My Olympus gear has never failed. So that means I have no experience with Olympus repair service.
I've have two experiences with Panny's repair service. Both negative.
A big key is using your gear correctly.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-100mm F4.0 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Sigma 150-600mm F5-6.3 | C +2 more
Doxa750 Contributing Member • Posts: 903
I have found if your electronic won't fail during the first a few weeks of usage, it usually last a while.
I had Nikon D3000 that lasted for almost 5 years and it never failed.  I gave that along with some lenses to my brother to help funding his Sony FF purchase.  My Nikon D5300 also worked flawlessly for almost 2 years till I traded it for EM5 II.
It has been almost 2 years now and my EM5 II works just like day one.  A bit over 2 months ago, I bought a new EM1 III.  So I think I have several more years till I need to look for a new shiny camera body.
Cheers
 Doxa750's gear list:Doxa750's gear list
Olympus TG-6 OM-1 Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 17mm F1.2 Pro +8 more
daleeight Veteran Member • Posts: 3,199
Buy a FF body like the entire world says we have to do....
Dale
 daleeight's gear list:daleeight's gear list
Olympus E-M1 III Nikon Z7 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus M.Zuiko Digital ED 60mm F2.8 Macro +6 more
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
You will eventually find an answer. GAS makes inventive.
 cba_melbourne's gear list:cba_melbourne's gear list
Olympus PEN-F Olympus E-M5 II Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 III +16 more
Emsquared Forum Member • Posts: 69
I just got a G85 and the PZ14-42 is pretty nice on it with EFC shutter,  It was good with GX-7 E-shutter too.
 Emsquared's gear list:Emsquared's gear list
Panasonic Lumix DMC-G3 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Samyang 7.5mm F3.5 Fisheye +7 more
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
5
Find a stick abour 1cm in diameter and 60cm long.
With the stick, apply 3 or 4 good solid whacks to the back of your heead.
(I've never done this but I hear that you feel a real sense of relief when its over)
Cheers
Eric
(Any image that I post in a DPR forum may be editted and posted in a DPR forum)
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Olympus E-M1 Olympus E-M1 II Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX7 +73 more
kiwigirl
kiwigirl Senior Member • Posts: 1,934
FZ50 still works fine, so does TZ7.  Sold FZ20, GH3, GX1 and L1 - all still working perfectly when they left me.
Only camera that ever let me down began with "C....." but won't mention that name here lest I upset someone
 kiwigirl's gear list:kiwigirl's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-ZS3 Panasonic Lumix DC-ZS70 Panasonic G85 Panasonic GX850 +9 more
