Lightroom external keyboards
Ricardobuchnerfoto New Member • Posts: 2
Hi.
Back in the days of lr5, I was using a logitech g13 keypad with paddy to fast editing my thousands of wedding images.
The problem is that paddy is no longer being updated and it stopped working for LR newer versions.
I know I can stick with LR5, but newer cameras are not supported in LR older versions.
Is there a solution for this? I want a solution as good as I had with LR5 and paddy (processing hundreds of images in minutes, without touching the mouse), but in LR CC, so I can use newer cameras.
Thank you!
Dareshooter Veteran Member • Posts: 4,475
Re: Lightroom external keyboards
Have you heard about the Loupedeck ? I don't own one myself but a good friend of mine has one and he's over the moon with it.
irvcobb
irvcobb Regular Member • Posts: 411
Depending on your needs and computer skills, you might also look at MIDI2LR for Behringer X-Touch Mini.
 irvcobb's gear list:irvcobb's gear list
Panasonic Lumix DMC-FZ150 Canon EOS 77D Canon EF-S 55-250mm f/4-5.6 IS Tokina AT-X Pro 100mm f/2.8 Macro Sigma 17-70mm F2.8-4 DC Macro OS HSM +3 more
OP Ricardobuchnerfoto New Member • Posts: 2
Thank you for your suggestions! I will take a look on those.
