Wich compact to get!
pharoldo
pharoldo Forum Member • Posts: 68
Hello!
im debating wich compact to get. Im torn between the Leica CM or the Contax T3....
what do you guys think?
all the best
 pharoldo's gear list:pharoldo's gear list
Sony RX1R II Sony RX100 V Apple iPhone XS
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50)
Overrank Contributing Member • Posts: 856
Re: Wich compact to get!
pharoldo wrote:
Hello!
all the best
Nikon F75 + 1.8G lens and spend the remaining £800 on film
In terms of image quality/versatility there are many cheaper comparable options.  I think it will come down to which you prefer.
pharoldo
OP pharoldo Forum Member • Posts: 68
Unfortunatly i hate slr...
the minolta cle with voigtlander 40mm could be an option may be...
but realy wanted a compact autofocus camera with good imagequality
A Mju ii ?
There’s a review of high end compacts on emulsive - https://emulsive.org/reviews/camera-reviews/compact-camera-megatest-12-high-mid-and-low-end-35mm-point-and-shoot-head-to-head
If you don’t mind adjusting the shutter speed and aperture then a Leica CL with a 40mm is <£700, but make sure the meter works (or expect to pay less)
For the sort of money the Leica CM are going for you could get a Leica M2/M3 + 50mm which at least you can get fixed when it breaks.
CortoPA
CortoPA Forum Member • Posts: 67
A Mju ii ?
+1, I had mine since new (Olympus Infinity Stylus)
cdembrey
cdembrey Contributing Member • Posts: 628
pharoldo wrote:
Hello!
all the best
Kyocera who owned both Contax and Yashica made comparable Yashica's which sell for less.
I have a Yashica T3 with a Zeiss Tessar 35mm f/2.8 lens. https://camerapedia.fandom.com/wiki/Yashica_T3
I also have a Yashica T4 with a Zeiss Tessar 35mm, f/3.5 lens. https://camerapedia.fandom.com/wiki/Yashica_T4
They are both good cameras. I'd recommend either. BTW I bought both Yashica s about 10-12 years ago about +/- $100 USD. They are the only cameras I've bought that have appreciated in value.
Here' Terry Richard using his T4 https://www.youtube.com/watch?v=k8i3VETLflk
The road is long - Life is short - Drive safe.
 cdembrey's gear list:cdembrey's gear list
Canon EOS 40D +2 more
pharoldo
Does the yashica have exposure compensation?
what i really like about the cm and the t3 are the fast shutter that Reach 1/1000!
pharoldo
So decided for the Contax T3! Its more compact and the autofocus is better....
now i need to save up because it got crazy expensive! But it really is the best point and shoot in my opinion!
thank you and all the best!
Gesture Veteran Member • Posts: 7,355
Great idea.
bskbo Regular Member • Posts: 281
I wouldn’t do that. It’s way to expensive. And probably hard to fix if it fails. Better find a camera that’s good but not so hyped. What about a Minolta AF-C?
